    Apr 2002
    England
    Hi every one I have ripped and burnt dvds before using dvd2svcd
    on windows 98 and never had problems..
    I installed win xp pro on my sys last night I new I had to download the
    xp aspi layer drivers so I did
    now when I boot up dvd2svcd the message analyzing vidio please wait
    comes up. But it stays on and when I try to rip and convert I get a message --I/O error-2147286263
    In the windows aspi about box it reads
    components aspi32.sys version 4.7
    wowpost.exe not installed
    winaspi.dll not installed
    winaspi32.dll vrsion 4.7
    Any ideas thanx keith....
    Feb 2001
    Sutton Coldfield West Midlands UK
    Try installing Compel WinASPI v4.60 (1021)
    at
    http://www.softdeko.8m.com/dvd_ripper_software.htm
    PN
    Feb 2001
    Looking through Google hits on "Compel WinASPI" I can see that it says that Compel is not for XP. Suggest you folloow some of these hits, there may be a clue.
    PN
  4. the aspi layer 4.70 does't work on or did not work on my xp too.
    so if you have nero go in side the folder right click on the wnaspi 32.dll
    and copy it. then go to your systems 32 folder and paste it.
    delete the aspi 4.70 layer first.
  5. this is a dvd or .avi? Reason I ask is that error code looks like it's an .avi file. Read dvd2svcd advanced reference MISC section to find out.
    try installing forceaspi 1.7
    http://www.doom9.org/software2.htm
  6. Forceaspi 1.7 definitely works for me! Good luck!
  7. Anonymous
    Guest
    Intsall Ver 4.6 Using Force Apsi.......I had a similar problem 8)
  8. I had a problem with ASPI after installing PowerDVD XP. prior to the install Smartripper worked fine, but after it was unable to unlock DVD's due to ASPI problems
    I used the system restore wizard in XP Pro to restore back prior to installing Pdvd XP and guess what - the problem disappeared. My suggestion to anyone having these problems - look to any recently installed programs, and use the restore wizard in XP.
    Worked for me.....
