Works fine in devine with us vpn proxy
Code:devine dl PLUTO https://pluto.tv/us/on-demand/movies/65bd2ad770ac44001
[Attachment 80086 - Click to enlarge]389c4f2
Results 1,471 to 1,500 of 1616
Thank you, I am new to these topics. I just managed to get Freevine working; I didn't know about Devine.
UKTV Play has become U today.
So to get UKTV/U working again
open up where you have installed freevine.
Go to the following folder:
freevine/utils/settings
Open up 'services.json' with your favourite text editor.
Go to line 146:
Change:
to:Code:"uktvplay.co.uk": {
Click save.Code:"u.co.uk": {
U/UKTV will work again.
Keeping Freevine alive
Nice work, equalizer
I'm sure it's appreciated. And I had no idea they were rebranding so thanks for the heads up! -
Thank you The Equalizer as that is probably one of the U.K. services that I actually got to work and there are probably more shows I want to check out.
It worked well and there are more shows for me to check out which I am very pleased about as I wanted some new shows to enjoy.Last edited by Tom Saurus; 6th Jul 2024 at 09:43.
RTE also offers "Photo Cover":
"Vid 17 Kbps | img=17000 | jpeg | 282 Segments | Main | ~01h52m48s"
is there any way to include it in the download?
This is my go to command for RTE:
Code:python3 freevine.py get -t -m https://www.rte.ie/player/movie/the-black-stallion/295058984418 python3 freevine.py get -i -m https://www.rte.ie/player/movie/the-black-stallion/295058984418 --proxy ie python3 freevine.py get -sv best -sa best -ss all -m https://www.rte.ie/player/movie/the-black-stallion/295058984418 --proxy ie
INFO : Vid *CENC 1920x1080 | 6007 Kbps | video=6007000 | avc1.644028 | 3373 Segments | Main | ~01h52m25s
INFO : Vid *CENC 1280x720 | 3839 Kbps | video=3839000 | avc1.64401F | 3373 Segments | Main | ~01h52m25s
INFO : Vid *CENC 960x540 | 2261 Kbps | video=2261000 | avc1.64401F | 3373 Segments | Main | ~01h52m25s
INFO : Vid *CENC 768x432 | 1407 Kbps | video=1407000 | avc1.64401E | 3373 Segments | Main | ~01h52m25s
INFO : Vid *CENC 640x360 | 841 Kbps | video=841000 | avc1.64401E | 3373 Segments | Main | ~01h52m25s
INFO : Vid *CENC 480x270 | 469 Kbps | video=469000 | avc1.644015 | 3373 Segments | Main | ~01h52m25s
INFO : Vid *CENC 416x234 | 113 Kbps | video=113000 | avc1.64400D | 3373 Segments | Main | ~01h52m25s
INFO : Vid 17 Kbps | img=17000 | jpeg | 282 Segments | Main | ~01h52m48s
INFO : Aud *CENC audio=128000 | 128 Kbps | mp4a.40.2 | 2CH | 3400 Segments | Main | ~01h52m25s
INFO : Aud *CENC audio=96000 | 96 Kbps | mp4a.40.2 | 2CH | 3400 Segments | Main | ~01h52m25s
INFO : Aud *CENC audio=64000 | 64 Kbps | mp4a.40.2 | 2CH | 3400 Segments | Main | ~01h52m25s
INFO : Sub textstream=1000 | wvtt | 3330 Segments | Subtitle | ~01h51m00s
INFO : Sub textstream_eng=1000 | en | stpp.ttml.im1t | 3330 Segments | Subtitle | ~01h51m00s
INFO : Sub 2515138752 | 1 Segment | Subtitle | ~01h52m25s
I have checked the manual for Video:
Code:N_m3u8DL-RE --morehelp select-video More Help: --select-video Select video streams by regular expressions. OPTIONS is a colon separated list of: id=REGEX:lang=REGEX:name=REGEX:codec=REGEX:res=REGEX:frame=REGEX segsMin=number:segsMax=number:ch=REGEX:range=REGEX:url=REGEX plistDurMin=hms:plistDurMax=hms:role=string:for=FOR * for=FOR: Select type. best[number], worst[number], all (Default: best) Examples: # select best video -sv best # select 4K+HEVC video -sv res="3840*":codec=hvc1:for=best # Select best video with duration longer than 1 hour 20 minutes 30 seconds -sv plistDurMin="1h20m30s":for=best -sv role="main":for:best
Would it be perhaps:
Code:-sv best1,worst1
Would have to mess around with FFmpeg (not sure how to mux Video/JPEG = cover art/ thumbnail/artwork into MP4 Container)
and I thought N_m3u8DL-RE would be able to do so for me, selecting the right option ...
Quick search point out to:
So looks like MP4 container supports cover art/ thumbnail/artwork....Code:ffmpeg -i sample.mp4 -i sample.png -map 0 -map 1 -c copy \ -disposition:v:1 attached_pic sample_w_artwork.mp4 -
Hi Chaps,
Does anyone know if tu.bi is still working in free.vine please?? U.k or U.s?? -
I still haven't gotten around to getting Devine working so I'm using YT-DLP with Tubi:
For example.Code:yt-dlp --downloader aria2c --external-downloader-args "-j 32" --cookies D:\Videos\tubitv.com-cookies.txt https://tubitv.com/tv-shows/544901/s11-e01 -o "The.Block.AU.S13E01.720p.mp4"
Thanks Grimbarian,
Sorry for the late reply.... appreciate the advice with yt.... -
I tried CTV this morning and it did not work with Freevine is this the case with others as well?
Thankfully it is fine after all; it was an issue with my NordVPN.Last edited by Tom Saurus; 8th Aug 2024 at 07:54.
hello
I try to use the script I installed the modules with the requirement.txt
put the path of mkvmerge mp4extract I use python 3.7 I created the WVD folder and put the files inside and it seems to me that I have errors when I want to download this video
[Attachment 81680 - Click to enlarge] -
ok i appologize im use python 3.12
[Attachment 81691 - Click to enlarge]Last edited by diesel; 21st Aug 2024 at 09:31.
I have just tested freevine for the first time with (freshly installed)
Python 3.12 and can't detect any problem:
[Attachment 81693 - Click to enlarge]
Sorry, but only someone who knows a bit about Python will be able to help you.
Was there an error when installing the requirements?
pip install rich --upgrade -
I made this command it's already better I'm missing mkvmerge apparently its resolved thank you very much Germania
on the other hand I have to type python freewine.py
how to place the command in shortcuts to use the freewine - get command as you doLast edited by diesel; 21st Aug 2024 at 12:51.
arf error merge mkv
Code:aites.Entrer.LAccuse.S01E79.Myriam.Badaoui.la.menteuse.et.le.juge.(affaire.outreau).720p.PLUTO.WEB-DL.AAC2.0.H.264.MUX.mkv 20:03:43.307 ERROR: Mux failed 20:03:43.307 ERROR: Failed Traceback (most recent call last): File "C:\Users\sebastien\desktop\freevine-main\services\pluto\pluto.py", line 418, in download subprocess.run(args, check=True) File "C:\Users\sebastien\AppData\Local\Programs\Python\Python312\Lib\subprocess.py", line 571, in run raise CalledProcessError(retcode, process.args, subprocess.CalledProcessError: Command '[WindowsPath('N_m3u8DL-RE.EXE'), WindowsPath('tmp/manifest.m3u8'), '-mt', '--auto-subtitle-fix', 'true', '--thread-count', '16', '--save-name', 'Faites.Entrer.LAccuse.S01E79.Myriam.Badaoui.la.menteuse.et.le.juge.(affaire.outreau).720p.PLUTO.WEB-DL.AAC2.0.H.264', '--save-dir', WindowsPath('downloads/Faites Entrer LAccuse/Season 01'), '--tmp-dir', 'temp', '--no-log', '-sv', 'for=best', '-sa', 'for=best', '-ss', 'all', '--base-url', 'http://silo-hybrik.pluto.tv.s3.amazonaws.com/340_pluto/clip/66582125fe060c0013befe1e_Faites_Entrer_LAccuse_FR_Myriam_Badaoui_la_menteuse_et_le_juge_affaire_outreau_S1E79/720pDRM/20240529_234806/hls/0-end/', '-M', 'format=mkv:muxer=mkvmerge:skip_sub=false']' returned non-zero exit status 1. During handling of the above exception, another exception occurred: Traceback (most recent call last): File "C:\Users\sebastien\desktop\freevine-main\freevine.py", line 15, in <module> cli() File "C:\Users\sebastien\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 1157, in __call__ return self.main(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\sebastien\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 1078, in main rv = self.invoke(ctx) ^^^^^^^^^^^^^^^^ File "C:\Users\sebastien\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 1688, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\sebastien\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 1434, in invoke return ctx.invoke(self.callback, **ctx.params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\sebastien\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 783, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\sebastien\desktop\freevine-main\utils\commands.py", line 90, in get Service(config, **kwargs) File "C:\Users\sebastien\desktop\freevine-main\services\pluto\pluto.py", line 67, in __init__ self.get_options() File "C:\Users\sebastien\desktop\freevine-main\services\pluto\pluto.py", line 392, in get_options self.download(download, title) File "C:\Users\sebastien\desktop\freevine-main\services\pluto\pluto.py", line 420, in download raise ValueError(f"{e}") ValueError: Command '[WindowsPath('N_m3u8DL-RE.EXE'), WindowsPath('tmp/manifest.m3u8'), '-mt', '--auto-subtitle-fix', 'true', '--thread-count', '16', '--save-name', 'Faites.Entrer.LAccuse.S01E79.Myriam.Badaoui.la.menteuse.et.le.juge.(affaire.outreau).720p.PLUTO.WEB-DL.AAC2.0.H.264', '--save-dir', WindowsPath('downloads/Faites Entrer LAccuse/Season 01'), '--tmp-dir', 'temp', '--no-log', '-sv', 'for=best', '-sa', 'for=best', '-ss', 'all', '--base-url', 'http://silo-hybrik.pluto.tv.s3.amazonaws.com/340_pluto/clip/66582125fe060c0013befe1e_Faites_Entrer_LAccuse_FR_Myriam_Badaoui_la_menteuse_et_le_juge_affaire_outreau_S1E79/720pDRM/20240529_234806/hls/0-end/', '-M', 'format=mkv:muxer=mkvmerge:skip_sub=false']' returned non-zero exit status 1. -
ok thank you
[Attachment 81698 - Click to enlarge]
[Attachment 81700 - Click to enlarge]
its good ? -
I wrote: put mkvmerge in freevine dir
not install MKVToolNix in any freevine subdirectory
Please don't make it more complicated than necessary ..
.. you need only to copy mkvmerge.exe + ffmpeg.exe in the same directory as freevine.py
et voilà - c'est si simple -
it's better thank you on the other hand I don't understand how to launch freevine.py without python
[Attachment 81701 - Click to enlarge]Last edited by diesel; 21st Aug 2024 at 15:48.
assoc .py=Python.File
https://www.wikihow.com/Open-a-Python-File#/Image:Open-a-Python-File-Step-15.jpg
UK Free to Air Downloader
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 844Last Post: 30th Aug 2026, 06:29 -
Video/Screenshot Guide to Freevine/N_m3u8DL-RE downloader for MacOS
By gwilliams1996 in forum Video Streaming DownloadingReplies: 16Last Post: 15th May 2024, 06:14 -
Forcing quality on streaming services
By qnufc in forum Video Streaming DownloadingReplies: 10Last Post: 8th Mar 2024, 17:27 -
Are we going to see all streaming services switching to L1 completely
By Loryanam2 in forum Video Streaming DownloadingReplies: 7Last Post: 5th Mar 2023, 07:37 -
Portable Streaming DownLoader for XMovies8?
By KermitJ in forum Video Streaming DownloadingReplies: 0Last Post: 27th Sep 2019, 10:44
