Ah, crap. It starts at 00 when it shouldn't, resulting in everything being shifted one place. Everything is still the correct episode according to its name, though. So S07E02 is the Wednesday episode, S07E04 is Monday etc. It's just that they're ordered incorrectly for these particular shows. So at the very least, you'll get the episode you're after in the end if you go by name. I guess that's a step forward.
I'll take a look at it at some later time. Dealing with this nightmare of a service is making me tired.
This is the first search result and it works perfectly fine: https://www.bbc.co.uk/iplayer/episodes/b006mj2y/antiques-roadshowOriginally Posted by sipho
Try StreamFab Downloader and download streaming video from Youtube, Netflix, Amazon! Download free trial.
Results 61 to 90 of 464
It worked for me, I did a search for antiques roadshow and I got https://www.bbc.co.uk/iplayer/episodes/b006mj2y/antiques-roadshow
I've tried it on both today's v0.5.4-beta and on the previous v0.5.3-beta
And I can confirm subs are now good to go when I choose option to have them separate.
And
py freevine.py -t https://www.bbc.co.uk/iplayer/episodes/b006nb9z/bargain-hunt
is no longer throwing up a shit load of E00's
Very good stabbedbybrick.Last edited by deccavox; 1st Oct 2023 at 20:09.
I ran across another what I am terming a "dud" file on CTV with "21 Jump Street S04E11". I went to the Browser and looked it up you hover your mouse cursour over the thumbnail for the video and it doesn't change to a hand to select it like the other files do. Seasons 1, 2, 3 and 5 had no such dud files when it comes to 21 Jump Street.
Your scripts are superb stabbedbybrick but I have a little niggle.
I hate dots in filenames separating individual words.
Now I thought the config.yaml settings could provide the solution.
I had already changed to this:
Code:filename: series: "{title}.{number}.{name}.{resolution}" movies: "{title}.{year}.{resolution}"
So, I tried
Code:filename: series: "{title} {number} {name} [{resolution}]" movies: "{title} ({year}) [{resolution}]"
here's an example:
Home.and.Away.S25E2497.Tuesday.3.October.[1080p].mp4
It even puts dots within the {name} lolLast edited by deccavox; 3rd Oct 2023 at 05:47.
@deccavox:
Yes, that's by design. You can re-arrange and remove sections from the filename, but any empty spaces are replaced by dots. Even within the the {name}. Removing spaces from filenames has been the standard since forever, and dots are used as separator because it's been the scene/P2P convention for 40 years and is the format most peoples' library will look like if they've ever downloaded anything of quality from FTP/torrent/DDL/etc. Using misplaced spaces and odd characters are considered "dirty" and might even cause issues when using any 3rd party tools. Using dots guarantees that whatever you do, the filename won't cause any errors since every system or piece of software dealing with media files in any way will be built on that conventional filename.
I can put it on the list for possible cosmetic changes, but in all honesty, I don't think I'll ever change it.
In other news, it's come to my attention that Channel4 will serve up the descriptive audio track in random ways, even when specifying otherwise. If anyone here uses it and have gotten the AD track even when specifying "id=audio_eng=128000" in the config file, I'd love to see some examples. Because I can't seem to reproduce it. Everything I download comes with the correct standard audio track.
Thank you. -
Changing that config line will definitely cause the correct track to be downloaded.
But for certain episodes of certain shows, the manifest has the AD track flagged as default.
When you select -a for those episodes the AD track is the first ID and has the default track tag. -
Couldn't resist this, sorry!
Universal video-file naming convention in the real World.
[Attachment 74156 - Click to enlarge]
I was looking for the 1990's film ChocolatWant to PM me? Just ask in the forum first. -
In other news python module httpx==0.25.0 is to be avoided.
All I can say is that the scene and internal groups are behind over 90% of everything that gets released, have been for decades, and they all follow the same conventions. I chose to do the same because, similar to how you should program with as much accessibility as possible in mind, using the same file naming as the vast, vast majority of pirated content out there simply makes the most sense in that regard. You might not like it for whatever reason, but with the staggering amount of these releases that exist it in this format it is objectively the most common way of naming video files.
That being said, people can do whatever they want. I like it this way.
And regarding httpx, I currently use it for everything except some singular instances on a couple of services where reading the manifests caused an issue. Which is probably why I haven't noticed any problems with the version. And Requests is neither old or incapable of connection pooling. You use the Session class just like the Client class in httpx. Pretty much the only reason I’m using httpx to begin with is because it comes with async, which I use for a couple of services. The overall difference in speed between the two libraries are imperceptible at best on such a small scale, and Requests is a lot more stable. It's going to be a while before it can be considered replaced. -
@stabbedbybrick,
You should stick to the universal naming convention. For those wanting spaces, there is this utility which runs in every OS, which rename your episodes. It is called : Rename My TV Series. I have been using it for years now in Plex so it can download correctly all the metadata.
https://www.tweaking4all.com/home-theatre/rename-my-tv-series-v2/ -
BBC are so maddening with their numbering. There's already been some examples highlighted above. But how about this one. You'd expect a single series would be series 1 (S01). Just like this one:
Code:https://www.bbc.co.uk/iplayer/episodes/p0gd25kn/union-with-david-olusoga 12:13:36.041 INFO : Union.with.David.Olusoga.S01E01.The.Making.of.Britain 12:13:36.042 INFO : Union.with.David.Olusoga.S01E02.Creating.Britishness 12:13:36.042 INFO : Union.with.David.Olusoga.S01E03.The.Two.Nations 12:13:36.043 INFO : Union.with.David.Olusoga.S01E04.Union.and.Disunion
Code:https://www.bbc.co.uk/iplayer/episodes/b00yyc7b/story-of-ireland 12:21:59.902 INFO : Story.of.Ireland.S00E01.Age.of.Invasions 12:21:59.903 INFO : Story.of.Ireland.S00E02.The.Age.of.Conquest 12:21:59.903 INFO : Story.of.Ireland.S00E03.The.Age.of.Revolution 12:21:59.904 INFO : Story.of.Ireland.S00E04.The.Age.of.Union 12:21:59.905 INFO : Story.of.Ireland.S00E05.Age.of.Nations
Conclusion: make sure you perform a 'py freevine.py -t URL' before downloading stuff.
Performing a download on the latter using s01 instead of s00 will get you nowhere.
@stabbedbybrick. This is absolutely no reflection on you. It's the madness of the BBC. -
I've been lurking for a while but just registered to say a big thanks to stabbedbybrick for putting a lot of work into this.
I genuinely don't understand what the issue is with the filenames, though?
Unless something changed in the latest versions (I haven't updated), it's what everyone else is using anyways and Plex/Kodi are able to understand that just fine! So color me confused... -
It's on me a little bit, though, since this is how the program works. The problem is that when you're collecting seasons and episodes in an object oriented way like this where you iterate through all the data, you need to find the correlating numbers somehow. If it's a well-designed API, there will be clear and consistent entries for all numbers, titles, data etc for all shows. But for sites like BBC, there is no consistency. The entries change from title to title, and some of them don't have anything to "grab on to" at all. Normally, "00" is meant for specials and extras that are outside of the main show. But with BBC shows that don't have those clear distinctions, the program interprets that as a special and assigns it 00. Same thing with episodes. Which means you have to rely on a bunch of regex and "if else" type of programming, which is really annoying.
If this was a single script meant for only BBC it wouldn't be as difficult to manage. But since I've tried to make Freevine as modular as possible where many functions are serving all streaming services, it makes it a lot more difficult to incorporate changes that don't follow the regular pattern.
But I have it on the list of fixes to be made. At least the actual downloading works correctly. -
Running this command to download a BBC episode.
Code:freevine.py -i -e S01E01 https://www.bbc.co.uk/iplayer/episodes/p0g5h206/boiling-point
Code:File "D:\GitHub\freevine\services\bbc.py", line 284, in clean_subtitles f.write(srt) File "C:\Program Files\Python310\lib\encodings\cp1252.py", line 19, in encode return codecs.charmap_encode(input,self.errors,encoding_table)[0] UnicodeEncodeError: 'charmap' codec can't encode character '\u2015' in position 30987: character maps to <undefined>
Other episodes worked fine, just the first episode.
I was able to fix the problem by changing line 283 in bbc.py to this.
Code:with open(self.save_path / f"{filename}.srt", "w", encoding='utf-8') as f:
Utf-8 is the default encoding and shouldn't even be needed to specify. But it if does fix the problem, I guess it does matter in some cases. I'll keep that in mind for the future, thank you.
I've been busy with life stuff and haven't had any time to work on it, but next update should hopefully fix some of these growing pains. -
Small update! (20231008)
You should now be able to customize the file names pretty much however you want. Dots, dashes, underscores, spaces, parentheses, and square brackets are allowed. Each keyword in curly brackets represent a section of the file name, use them however you see fit. I'm sure some of you will be able to break this somehow, just let me know.
NOTE: {year} can be unreliable for series since it's completely up the service API, so if you need to have it included it's recommended to just add it manually with whatever year fits.
BBC iPlayer season and episode number are slightly improved. Shows without any clear numbering should now at least be ordered according to how they're posted on the site. If they appear out of order, it's not my choice. First episodes of seasons for these particular shows might display as E00, but it's how it has to be for now. For any normal shows, the "00" will indicate that it's a special season or episode.
I also added an additional download path to separate movies and series. -
New update! (20231010)
You can now download episodes directly by URL (Pluto TV not yet supported):
Code:python freevine.py EPISODE_URL python freevine.py --quality EPISODE_URL python freevine.py --info EPISODE_URL
Fresh hmac and aes keys are fetched remotely each session, so there's no need to hardcode them in or update them yourself.
They are automatically updated on a regular basis, so they never expire. -
Very good stabby and thanks.
One I meant to mention to you. With ITVX and Emmerdale.
Try this: py freevine.py -t https://www.itv.com/watch/emmerdale/Ya0524
You get:
Code:20:08:51.920 INFO : ITV 20:08:52.088 INFO : Emmerdale: 1 Season(s), 32 Episode(s) 20:08:52.089 INFO : Emmerdale S52E9779 20:08:52.089 INFO : Emmerdale S52E9780 20:08:52.089 INFO : Emmerdale S52E9781 20:08:52.090 INFO : Emmerdale S52E9782 20:08:52.090 INFO : Emmerdale S52E9784 20:08:52.090 INFO : Emmerdale S52E9785 20:08:52.091 INFO : Emmerdale S52E9786 20:08:52.091 INFO : Emmerdale S52E9787 20:08:52.091 INFO : Emmerdale S52E9788 20:08:52.092 INFO : Emmerdale S52E9790 20:08:52.092 INFO : Emmerdale S52E9791 20:08:52.092 INFO : Emmerdale S52E9792 20:08:52.093 INFO : Emmerdale S52E9793 20:08:52.093 INFO : Emmerdale S52E9793 20:08:52.093 INFO : Emmerdale S52E9794 20:08:52.093 INFO : Emmerdale S52E9794 20:08:52.094 INFO : Emmerdale S52E9796 20:08:52.094 INFO : Emmerdale S52E9796 20:08:52.094 INFO : Emmerdale S52E9797 20:08:52.095 INFO : Emmerdale S52E9797 20:08:52.096 INFO : Emmerdale S52E9798 20:08:52.096 INFO : Emmerdale S52E9798 20:08:52.099 INFO : Emmerdale S52E9799 20:08:52.099 INFO : Emmerdale S52E9799 20:08:52.100 INFO : Emmerdale S52E9800 20:08:52.101 INFO : Emmerdale S52E9800 20:08:52.101 INFO : Emmerdale S52E9802 20:08:52.102 INFO : Emmerdale S52E9802 20:08:52.103 INFO : Emmerdale S52E9803 20:08:52.103 INFO : Emmerdale S52E9803 20:08:52.104 INFO : Emmerdale S52E9804 20:08:52.105 INFO : Emmerdale S52E9804
You get similar with Corronation Street.
Using STV player instead, you don't get the duplicate episodes. They're all S00 though
UK Free to Air Downloader
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 70Last Post: 19th Nov 2023, 10:32 -
Are we going to see all streaming services switching to L1 completely
By Loryanam2 in forum Video Streaming DownloadingReplies: 7Last Post: 5th Mar 2023, 08:37 -
4K Video Downloader free or money?
By Jomapil1 in forum Video Streaming DownloadingReplies: 8Last Post: 29th Sep 2020, 11:33 -
Portable Streaming DownLoader for XMovies8?
By KermitJ in forum Video Streaming DownloadingReplies: 0Last Post: 27th Sep 2019, 11:44 -
Simplest and quickest free video downloader ?
By arcadianne in forum Newbie / General discussionsReplies: 28Last Post: 27th Feb 2019, 21:29
