I ran some tests using python 3.9, 3.10, 3.11, 3.12 and they all work.
It's about as much support as one can expect. There's not much more I can do.
Results 181 to 210 of 1613
work fine now after uninstall vinetrimmer stuff (i used this to get 4K from iplayer)
I tried the new version that works with CBC. It works very well. I think I will buy Mulvad VPN for a six month term and check out what I can't access now. Thank you once again stabbedbybrick for all the work you put into making this program and improving along the way.
I have several other versions of your program on my Windows 11 computer as I got scared that I wouldn't get the new versions set up right. Now I think I should delete them all and just have the one as it seems to working just fine and even better than the previous versions were.
I do have a couple of questions though. In the settings file how can I set it up to name the files like this:
Name Of Show two blank spaces S01E01 two blank spaces Episode Name and nothing else after that
Also if there is more than one bit rate available for a resolution how could one select the lower bit rate? If it can't be done it is fine though because the day may come when one can't get smaller TVs and 360p and 480p may not look to good on the larger screens.
Thank you in advance and thanks once again for this terrific program. -
I wouldn't recommend Mullvad for this. It's a great VPN in terms of privacy and speeds, but not the best when it comes to being able to access streaming services in other countries, with many of their servers being actively blocked. For that purpose, I'd probably go for NordVPN or possibly Windscribe. Maybe others have more recommendations.
You currently can't have two blank spaces. Part of the cleanup process for names is to remove characters occurring twice next to each other, including blank spaces.
To select the lower version of a resolution, you can use this: "res=720:for=worst"
See "N_m3u8DL-RE --morehelp --select-video" for all options. -
I've discovered an anomaly with CH5 (My5) when it comes to one-offs.
I have a tendency initially to do
py freevine.py -t url
That gives me an idea of the structure that has been applied to a show (eg. S00, S01, Ep#, etc).
I tried:
py freevine -t https://www.channel5.com/show/the-greatest-tv-of-the-60s
and
py freevine -t https://www.channel5.com/show/the-greatest-tv-of-the-70-s
Both failed pretty spectacularly.
I tried the same with a Movie on My5. Exactly the same.
I then used
py freevine.py -m https://www.channel5.com/show/the-greatest-tv-of-the-60s
and yes, it works as a Movie, even though it is not a Movie lol
On the other UK downloaders (eg. ITVX, STV, All4, UKTV), performing -t on a Movie or one-off gives S00E00, S01E01, etc. In other words it accepts the -t (--titles) arument.
Basically, -t (--titles) doesn't work with one-off shows on My5. -
It's not a movie but the structure is the same, which is why it works as one. One-off episodes on Channel 5 that completely lack seasons are "built" like movies and I lazily kinda left it at that. I'll fix it eventually, but in the meantime you should be able to download all of them if you treat them as movies.
I got an adorable message where they wanted to know if it would be possible to add ABC so that they could download all episodes of Bluey for their kids. You can't really say no to that, can you?
So I've added ABC iView for our Australian friends. Up to 1080p and AAC audio.
It's only on the main branch at the moment, because I'm not sure how bug free it is. Australian VPN servers are really inconsistent for some reason, so I'm having trouble testing properly. -
wow!! more site.
download perfect fine
Code:20:29:16.582 INFO : Freevine v0.6.1-beta (20231027) 20:29:16.708 INFO : ABC iView 20:29:17.572 INFO : Annika: 2 Season(s), 7 Episode(s) 20:29:23.724 INFO : Annika S01E01 20:29:23.724 INFO : 1f567c61afea4f948212c0893938935c:56b432957ec7f66b14c0b204369ffea5 20:29:33.969 INFO : N_m3u8DL-RE (Beta version) 20230628 20:29:33.979 INFO : Loading URL: tmp\manifest.mpd 20:29:33.980 INFO : Content Matched: Dynamic Adaptive Streaming over HTTP 20:29:33.980 INFO : Parsing streams... 20:29:33.982 WARN : Writing meta json 20:29:33.987 INFO : Extracted, there are 10 streams, with 8 basic streams, 1 audio streams, 1 subtitle streams 20:29:33.988 INFO : Vid *CENC 1920x1080 | 3968 Kbps | video-avc1-5 | avc1.640028 | 1 Segment | ~47m06s 20:29:33.989 INFO : Vid *CENC 1280x720 | 3397 Kbps | video-avc1-3 | avc1.640028 | 1 Segment | ~47m06s 20:29:33.990 INFO : Vid *CENC 1280x720 | 2452 Kbps | video-avc1-4 | avc1.640028 | 1 Segment | ~47m06s 20:29:33.991 INFO : Vid *CENC 1024x576 | 1358 Kbps | video-avc1-2 | avc1.640028 | 1 Segment | ~47m06s 20:29:33.991 INFO : Vid *CENC 800x450 | 893 Kbps | video-avc1-1 | avc1.640028 | 1 Segment | ~47m06s 20:29:33.991 INFO : Vid *CENC 640x360 | 538 Kbps | video-avc1-7 | avc1.4D401E | 1 Segment | ~47m06s 20:29:33.992 INFO : Vid *CENC 512x288 | 422 Kbps | video-avc1-8 | avc1.4D401E | 1 Segment | ~47m06s 20:29:33.992 INFO : Vid *CENC 320x180 | 174 Kbps | video-avc1-6 | avc1.4D401E | 1 Segment | ~47m06s 20:29:33.992 INFO : Aud *CENC audio-und-mp4a | 137 Kbps | mp4a.40.2 | 2CH | 1 Segment | ~47m06s 20:29:33.993 INFO : Sub English | 1 Segment | ~47m06s 20:29:33.993 INFO : Parsing streams... 20:29:33.993 INFO : Selected streams: 20:29:33.994 INFO : Vid *CENC 1920x1080 | 3968 Kbps | video-avc1-5 | avc1.640028 | 1 Segment | ~47m06s 20:29:33.994 INFO : Aud *CENC audio-und-mp4a | 137 Kbps | mp4a.40.2 | 2CH | 1 Segment | ~47m06s 20:29:33.994 INFO : Sub English | 1 Segment | ~47m06s 20:29:33.994 WARN : Writing meta json 20:29:33.995 INFO : Save Name: Annika.S01E01.1080p.iV.WEB-DL.AAC2.0.H.264 20:29:33.995 WARN : MuxAfterDone is detected, binary merging is automatically enabled 20:29:35.194 INFO : Start downloading...Vid 1920x1080 | 3968 Kbps | video-avc1-5 | avc1.640028 20:29:35.229 INFO : Start downloading...Aud audio-und-mp4a | 137 Kbps | mp4a.40.2 | 2CH 20:29:35.370 INFO : Start downloading...Sub English 20:29:36.729 WARN : Reading media info... 20:29:38.600 INFO : NaN: Subtitle, webvtt 20:29:38.600 WARN : Extracting VTT(raw) subtitle... 20:29:38.609 INFO : Binary merging... 20:29:38.983 WARN : Type: cenc 20:29:38.983 WARN : PSSH(WV): CAESEB9WfGGv6k+UghLAiTk4k1waC2J1eWRybWtleW9zIhCb7z+Y7lBBCKl6AXS8zaXuKgJIRA== 20:29:38.984 WARN : KID: 1f567c61afea4f948212c0893938935c 20:29:38.984 INFO : Trying to search for KEY from text file... 20:29:38.985 INFO : OK 1f567c61afea4f948212c0893938935c:56b432957ec7f66b14c0b204369ffea5 20:29:38.985 WARN : Reading media info... 20:29:39.032 INFO : [0x1]: Video, h264 (High) (avc1), 1920x1080, 25 fps, 29 kb/s 20:29:39.041 WARN : Type: cenc 20:29:39.041 WARN : PSSH(WV): CAESEB9WfGGv6k+UghLAiTk4k1waC2J1eWRybWtleW9zIhAcK5NJCWZD8YZszXJeofm5KgJIRA== 20:29:39.042 WARN : KID: 1f567c61afea4f948212c0893938935c 20:29:39.042 INFO : Trying to search for KEY from text file... 20:29:39.043 INFO : OK 1f567c61afea4f948212c0893938935c:56b432957ec7f66b14c0b204369ffea5 20:29:39.043 WARN : Reading media info... 20:29:39.126 INFO : [0x2]: Audio, aac (LC) (mp4a), 27 kb/s 20:29:49.140 INFO : Binary merging... 20:29:49.175 INFO : Decrypting... 20:30:08.886 INFO : Binary merging... 20:30:09.318 INFO : Decrypting... 20:30:12.897 WARN : Annika.S01E01.1080p.iV.WEB-DL.AAC2.0.H.264.mp4 20:30:12.897 WARN : Annika.S01E01.1080p.iV.WEB-DL.AAC2.0.H.264.m4a 20:30:12.897 WARN : Annika.S01E01.1080p.iV.WEB-DL.AAC2.0.H.264.srt 20:30:12.897 WARN : Muxing to Annika.S01E01.1080p.iV.WEB-DL.AAC2.0.H.264.MUX.mkv 20:30:14.722 WARN : Cleaning files... 20:30:14.777 WARN : Rename to Annika.S01E01.1080p.iV.WEB-DL.AAC2.0.H.264.mkv 20:30:14.778 INFO : Done
Hi,
Stumbled across this when looking for a way to download from itvx/channel4. Is there a guide anywhere on how to set this up besides the requirements list on github, as never dealt with Python before so not able to get it working.
Thanks.
Here is the log from when trying to get 8 Out of 10 Cats Does Countdown titles.
Code:C:\Users\Eric\Downloads\freevine-main>py freevine.py -t https://www.channel4.com/programmes/8-out-of-10-cats-does-countdown 23:57:52.081 INFO : Freevine v0.6.1-beta (20231027) Traceback (most recent call last): File "C:\Users\Eric\Downloads\freevine-main\freevine.py", line 46, in <module> main() File "C:\Users\Eric\AppData\Local\Programs\Python\Python311\Lib\site-packages\click\core.py", line 1157, in __call__ return self.main(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\Eric\AppData\Local\Programs\Python\Python311\Lib\site-packages\click\core.py", line 1078, in main rv = self.invoke(ctx) ^^^^^^^^^^^^^^^^ File "C:\Users\Eric\AppData\Local\Programs\Python\Python311\Lib\site-packages\click\core.py", line 1434, in invoke return ctx.invoke(self.callback, **ctx.params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\Eric\AppData\Local\Programs\Python\Python311\Lib\site-packages\click\core.py", line 783, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\Eric\Downloads\freevine-main\freevine.py", line 39, in main Service = get_service(kwargs.get("url")) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\Eric\Downloads\freevine-main\utils\services.py", line 107, in get_service spec.loader.exec_module(service_module) File "<frozen importlib._bootstrap_external>", line 940, in exec_module File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed File "C:\Users\Eric\Downloads\freevine-main\services\channel4.py", line 39, in <module> from pywidevine.L3.decrypt.wvdecryptcustom import WvDecrypt File "C:\Users\Eric\AppData\Local\Programs\Python\Python311\Lib\site-packages\pywidevine\__init__.py", line 1, in <module> from .cdm import * File "C:\Users\Eric\AppData\Local\Programs\Python\Python311\Lib\site-packages\pywidevine\cdm.py", line 21, in <module> from pywidevine.device import Device File "C:\Users\Eric\AppData\Local\Programs\Python\Python311\Lib\site-packages\pywidevine\device.py", line 17, in <module> from pywidevine.license_protocol_pb2 import ClientIdentification, FileHashes, SignedDrmCertificate, DrmCertificate File "C:\Users\Eric\AppData\Local\Programs\Python\Python311\Lib\site-packages\pywidevine\license_protocol_pb2.py", line 5, in <module> from google.protobuf.internal import builder as _builder ImportError: cannot import name 'builder' from 'google.protobuf.internal' (C:\Users\Eric\AppData\Local\Programs\Python\Python311\Lib\site-packages\google\protobuf\internal\__init__.py)Last edited by Mashup; 29th Oct 2023 at 19:00.
Here's a problem with the iView downloader:
edit: in this file - "abciview.py", line 196, in get_playlist replace the "if streams["720"]:" with "if "720" in streams:" and it worksCode:D:\Utilities\WEB-DL-Tools\freevine-main> py .\freevine.py -c "https://iview.abc.net.au/show/games" 01:05:59.366 INFO : Freevine v0.6.1-beta (20231027) 01:05:59.982 INFO : ABC iView 01:06:04.514 INFO : The Games: 2 Season(s), 26 Episode(s) Traceback (most recent call last): File "D:\Utilities\WEB-DL-Tools\freevine-main\freevine.py", line 46, in <module> main() File "C:\Users\User123\AppData\Roaming\Python\Python310\site-packages\click\core.py", line 1130, in __call__ return self.main(*args, **kwargs) File "C:\Users\User123\AppData\Roaming\Python\Python310\site-packages\click\core.py", line 1055, in main rv = self.invoke(ctx) File "C:\Users\User123\AppData\Roaming\Python\Python310\site-packages\click\core.py", line 1404, in invoke return ctx.invoke(self.callback, **ctx.params) File "C:\Users\User123\AppData\Roaming\Python\Python310\site-packages\click\core.py", line 760, in invoke return __callback(*args, **kwargs) File "D:\Utilities\WEB-DL-Tools\freevine-main\freevine.py", line 40, in main Service(config, **kwargs) File "D:\Utilities\WEB-DL-Tools\freevine-main\services\abciview.py", line 54, in __init__ self.get_options() File "D:\Utilities\WEB-DL-Tools\freevine-main\services\abciview.py", line 268, in get_options self.download(download, title) File "D:\Utilities\WEB-DL-Tools\freevine-main\services\abciview.py", line 272, in download manifest, subtitle = self.get_playlist(stream.id) File "D:\Utilities\WEB-DL-Tools\freevine-main\services\abciview.py", line 196, in get_playlist if streams["720"]: KeyError: '720'Last edited by ampersand; 29th Oct 2023 at 21:00.
Make sure you're using the version of protobuf specified in requirements.txt: protobuf==3.19.5. You can see which version you have installed with "pip freeze".
As for guide, running "py freevine.py --help" will give you a pretty detailed set of instructions. If you're brand new to Python and N_m3u8DL-RE it might take a bit of trial and error, but in the end it's basically just running the correct commands, and you've seem to figured that out already so it shouldn't be a problem for you.
Ah, good catch. It should be "if streams.get("720")" to properly check if the HD key exist. I cannot tell you how many times I've made this stupid error.Originally Posted by ampersand
Appreciate the help! -
I'm not completely new to Python, just been awhile so understand the basics but just can't seem to get this to work. Have all the requirements in the same folder, and sure i've got the requirements installed, including the right version as seen, just hitting the same error each time.
Code:C:\Users\Eric>pip freeze anyio==4.0.0 beautifulsoup4==4.12.2 certifi==2023.7.22 charset-normalizer==3.2.0 click==8.1.7 colorama==0.4.6 construct==2.8.8 google==3.0.0 h11==0.14.0 httpcore==0.18.0 httpx==0.25.0 idna==3.4 lxml==4.9.3 markdown-it-py==3.0.0 mdurl==0.1.2 protobuf==3.19.5 pycryptodome==3.19.0 pycryptodomex==3.19.0 Pygments==2.16.1 pymp4==1.4.0 pyperclip==1.8.2 pywidevine==1.6.0 PyYAML==6.0.1 requests==2.31.0 rich==13.6.0 six==1.16.0 sniffio==1.3.0 sortedcontainers==2.4.0 soupsieve==2.5 uncurl==0.0.11 Unidecode==1.3.7 urllib3==2.0.5 vtt-to-srt3==0.2.0.1
Okay. I've never encountered this particular error, but based on some searching it looks like it's trying to import something (builder) that doesn't exist in this version of Protobuf.
This workaround seem to work for others with the same issue. I'm still not sure why it's happening to begin with, but could be worth a try. Maybe some leftover cache from a previous installation? -
@Mashup
try pip uninstall pywidevineLast edited by iamghost; 30th Oct 2023 at 04:18.
I completely missed the pywidevine installation. It seems likely that the traces of the protobuf version in that package would cause a conflict with the older version.
As a general rule, you should always run python projects in localized environments to avoid version conflicts. I should probably add it to the readme. -
Thank you so much for your work here. This is brilliant.
If you get really bored and want to consider adding any other Aussie FTA networks, these are the sites
7Plus
https://7plus.com.au/
SBS on Demand
https://www.sbs.com.au/ondemand/
9Now
https://www.9now.com.au/
10Play
https://10play.com.au/
9Now would be the one that would make my wife (and more me by extension) a happy camper. -
This was the issue, uninstalling allowed the command to go through and list all episodes.
Now when I run the following to download.
It's giving me the error below;Code:py freevine.py -c https://www.channel4.com/programmes/8-out-of-10-cats-does-countdown
I have generated the device_client_id_blob.bin and device_private_key.pem and put them in freevine-main\pywidevine\L3\cdm\devices\android_generic folder. I have looked through the pages and generated the files again, but same issue, any idea what i'm doing wrong?Code:no client ID blob available for this device Traceback (most recent call last): File "C:\Users\Eric\Desktop\freevine-main\freevine.py", line 46, in <module> main() File "C:\Users\Eric\AppData\Local\Programs\Python\Python311\Lib\site-packages\click\core.py", line 1157, in __call__ return self.main(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\Eric\AppData\Local\Programs\Python\Python311\Lib\site-packages\click\core.py", line 1078, in main rv = self.invoke(ctx) ^^^^^^^^^^^^^^^^ File "C:\Users\Eric\AppData\Local\Programs\Python\Python311\Lib\site-packages\click\core.py", line 1434, in invoke return ctx.invoke(self.callback, **ctx.params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\Eric\AppData\Local\Programs\Python\Python311\Lib\site-packages\click\core.py", line 783, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\Eric\Desktop\freevine-main\freevine.py", line 40, in main Service(config, **kwargs) File "C:\Users\Eric\Desktop\freevine-main\services\channel4.py", line 51, in __init__ self.get_options() File "C:\Users\Eric\Desktop\freevine-main\services\channel4.py", line 306, in get_options self.download(download, title) File "C:\Users\Eric\Desktop\freevine-main\services\channel4.py", line 315, in download keys = self.local_cdm(pssh, license_url, manifest, token, stream.data) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\Eric\Desktop\freevine-main\services\channel4.py", line 67, in local_cdm lic = self.get_license( ^^^^^^^^^^^^^^^^^ File "C:\Users\Eric\Desktop\freevine-main\services\channel4.py", line 91, in get_license "message": base64.b64encode(challenge).decode("utf8"), ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\Eric\AppData\Local\Programs\Python\Python311\Lib\base64.py", line 58, in b64encode encoded = binascii.b2a_base64(s, newline=False) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ TypeError: a bytes-like object is required, not 'int'
I appreciate the help. -
Hi, thanks for making this tool! I'm trying to download a Roku channel series which basically seems to be the only real HD source but am getting an error although the titles list is loading fine. Could you please help (I used Python 3.12 but that doesn't seem to be the issue)? Here's the log:
Code:python freevine.py --complete https://therokuchannel.roku.com/details/f259a3ae901e5a51a5704cb3a7d69445/robocop-alpha-commando 21:08:13.153 INFO : Freevine v0.6.1-beta (20231027) 21:08:13.278 INFO : The Roku Channel 21:08:16.873 INFO : RoboCop: Alpha Commando (1998): 1 Season(s), 40 Episode(s) no client ID blob available for this device Traceback (most recent call last): File "C:\freevine\freevine.py", line 46, in <module> main() File "C:\Users\USER\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 1157, in __call__ return self.main(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\USER\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 1078, in main rv = self.invoke(ctx) ^^^^^^^^^^^^^^^^ File "C:\Users\USER\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 1434, in invoke return ctx.invoke(self.callback, **ctx.params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\USER\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 783, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\freevine\freevine.py", line 40, in main Service(config, **kwargs) File "C:\freevine\services\roku.py", line 50, in __init__ self.get_options() File "C:\freevine\services\roku.py", line 250, in get_options self.download(download, title) File "C:\freevine\services\roku.py", line 263, in download else local_cdm(pssh, lic_url, self.client) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\freevine\utils\cdm.py", line 15, in local_cdm response = client.post(url=lic_url, data=wvdecrypt.get_challenge()) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\USER\AppData\Local\Programs\Python\Python312\Lib\site-packages\httpx\_client.py", line 1132, in post return self.request( ^^^^^^^^^^^^^ File "C:\Users\USER\AppData\Local\Programs\Python\Python312\Lib\site-packages\httpx\_client.py", line 801, in request request = self.build_request( ^^^^^^^^^^^^^^^^^^^ File "C:\Users\USER\AppData\Local\Programs\Python\Python312\Lib\site-packages\httpx\_client.py", line 358, in build_request return Request( ^^^^^^^^ File "C:\Users\USER\AppData\Local\Programs\Python\Python312\Lib\site-packages\httpx\_models.py", line 339, in __init__ headers, stream = encode_request( ^^^^^^^^^^^^^^^ File "C:\Users\USER\AppData\Local\Programs\Python\Python312\Lib\site-packages\httpx\_content.py", line 205, in encode_request return encode_content(data) ^^^^^^^^^^^^^^^^^^^^ File "C:\Users\USER\AppData\Local\Programs\Python\Python312\Lib\site-packages\httpx\_content.py", line 133, in encode_content raise TypeError(f"Unexpected type for 'content', {type(content)!r}") TypeError: Unexpected type for 'content', <class 'int'> -
Hi,
I've tried to download it using your command and it does work fine (using KeepSolid VPN from the UK). Unfortunately, though it does download, you only get SD (480).
Peter
19:05:15.525 INFO : Parsing streams...
19:05:15.531 INFO : Selected streams:
19:05:15.531 INFO : Vid *CENC 640x480 | 1013 Kbps | 1 | 23.976 | avc1.64001E | 668 Segments | ~22m16s
19:05:15.532 INFO : Aud *CENC 6 | 128 Kbps | mp4a.40.5 | eng | 2CH | 668 Segments | ~22m16s
19:05:15.534 INFO : Sub 7 | eng | stpp | 668 Segments | ~22m16s
19:05:15.534 WARN : Writing meta json
19:05:15.546 INFO : Save Name: RoboCop.Alpha.Commando.S01E01.Justice.Reborn.Part. 1.480p.ROKU.WEB-DL.AAC2.0.H.264
19:05:15.547 WARN : MuxAfterDone is detected, binary merging is automatically enabled
19:05:15.551 INFO : Start downloading...Sub 7 | eng | stpp
19:05:15.551 INFO : Start downloading...Aud 6 | 128 Kbps | mp4a.40.5 | eng | 2CH
19:05:15.551 INFO : Start downloading...Vid 640x480 | 1013 Kbps | 1 | 23.976 | avc1.64001E
19:05:15.995 WARN : Reading media info... -
On ABC IView having the AD stream issue on an episode of The Control Room.
The audio in N_m3u8DL-RE shows 13:00:31.567 INFO : Aud *CENC audio-en-mp4a-2 | 137 Kbps | mp4a.40.2 | en | 2CH | 1 Segment | ~56m31s
13:00:31.569 INFO : Aud *CENC audio-en-mp4a-1 | 137 Kbps | mp4a.40.2 | en | 2CH | 1 Segment | ~56m31s
Tried most of the suggestions in this thread and the one that worked track: "for=best2" gives both the normal and AD tracks. In VLC it's easy to change the audio to the correct one, but how do I get it to work without the AD track.
https://iview.abc.net.au/video/ZW3307A001S00 -
it looks like iview puts the audio track type in the adaptaptionset label and not in the representation part.Code:
<!-- Audio --> <AdaptationSet mimeType="audio/mp4" startWithSAP="1" segmentAlignment="true" lang="en" label="English" subsegmentAlignment="true" subsegmentStartsWithSAP="1"> --removed-encryption-part-- <Representation id="audio-en-mp4a-1" codecs="mp4a.40.2" bandwidth="137379" audioSamplingRate="44100"> <AudioChannelConfiguration schemeIdUri="urn:mpeg:dash:23003:3:audio_channel_configuration:2011" value="2"/> <BaseURL>audio-en-0.mp4</BaseURL> <SegmentBase indexRange="1841-22224"> <Initialization range="0-1840"/> </SegmentBase> </Representation> </AdaptationSet> <AdaptationSet mimeType="audio/mp4" startWithSAP="1" segmentAlignment="true" lang="en" label="English Audio Description" subsegmentAlignment="true" subsegmentStartsWithSAP="1"> <Role schemeIdUri="urn:mpeg:dash:role:2011" value="alternate"/> <Accessibility schemeIdUri="urn:tva:metadata:cs:AudioPurposeCS:2007" value="1"/> --removed-encryption-part-- <Representation id="audio-en-mp4a-2" codecs="mp4a.40.2" bandwidth="137419" audioSamplingRate="44100"> <AudioChannelConfiguration schemeIdUri="urn:mpeg:dash:23003:3:audio_channel_configuration:2011" value="2"/> <BaseURL>audio-en-1.mp4</BaseURL> <SegmentBase indexRange="1841-22224"> <Initialization range="0-1840"/> </SegmentBase> </Representation> </AdaptationSet>
if they follow the same formula with id "audio-en-mp4a-1" being normal audio and id "audio-en-mp4a-2" being the audio descriptive track, you could use this argument with n_m3u8dl-re
it looks like diazole has already put in a request with n_m3u8dl-re to add support for the role scheme but we'll have to wait for the next release to use itCode:--select-audio id=-1
Hi! Just wanted to say what an awesome app! Friend put me onto it and I've been having a good play! I have a couple of questions if that's ok
Firstly this morning I went to download two Channel4 shows that have new episodes, Help we bought a village and A Place in the sun, for some reason Freevine doesn't find the new episodes even though they're clearly there on the channel4 website and can be played etc.
Secondly, with My5 there's been a few times the Mpd URL changed and to get 1080p requires a little more tweaking, I believe My5 has 4 different URL types that need little tweaks to get 1080p rather than just 720p, for example there's 3 episodes of Bargain Loving Brits in The Sun series 10 that freevine can only download in 720p rather than the available (with little tweaks) 1080p, s10e15, s10e20, s10e21 also for example some older series of shows e.g. series 3&4 of Police Interceptors I tried so far as only downloadable in 720p but with another my5 script (which manipulates the mpd link to "fix" it) 1080p is possible.
Hope these aren't too much hassle to answer/fix, love the app, thanks again
Edit: I wasn't sure if for security reasons it's best not to link directly to the shows I mentioned, hence not linking to them...
Edit2: Just downloaded last night's Killer at the Crime Scene (s03e10) from My5 and it's also only 720p for some reason.Last edited by Grimbarian; 31st Oct 2023 at 03:54.
I think I see what the problem is. Channel4 has a habit of storing episodes that aren't always available, like episodes that doesn't "air" for another week or were available at one point but has since been removed. And the script currently picks those up when looping through the API, which it won't be able to download because they aren't actually there. I don't know if that makes any sense to you, but it should hopefully be an easy fix.
In the meantime, you can download single episodes by URL as well, which works fine for the latest episodes:
Code:python freevine.py EPISODE_URL
Yeah, the way it looks for and edits the URL can definitely be improved. I don't use My5 enough to catch these things myself, so feedback is always appreciated. I'll take a look and see if I can come up with a better solution to grab all versions. -
UK Free to Air Downloader
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 725Last Post: 17th Jan 2026, 04:14 -
Video/Screenshot Guide to Freevine/N_m3u8DL-RE downloader for MacOS
By gwilliams1996 in forum Video Streaming DownloadingReplies: 16Last Post: 15th May 2024, 07:14 -
Forcing quality on streaming services
By qnufc in forum Video Streaming DownloadingReplies: 10Last Post: 8th Mar 2024, 18:27 -
Are we going to see all streaming services switching to L1 completely
By Loryanam2 in forum Video Streaming DownloadingReplies: 7Last Post: 5th Mar 2023, 08:37 -
Portable Streaming DownLoader for XMovies8?
By KermitJ in forum Video Streaming DownloadingReplies: 0Last Post: 27th Sep 2019, 11:44
