Once again thank you and I am thinking maybe I should move my .wvd file to appdata devine folder:
Some pictures:Code:Microsoft Windows [Version 10.0.22000.2538] (c) Microsoft Corporation. All rights reserved. C:\Users\sheld\Desktop\devine\devine>devine env info / __ \/ ____/ | / / _/ | / / ____/ / / / / __/ | | / // // |/ / __/ / /_/ / /___ | |/ // // /| / /___ /_____/_____/ |___/___/_/ |_/_____/ ⠀ v3.3.1 Copyright © 2019-2024 rlaphoenix https://github.com/devine-dl/devine [Root Config] : C:\Users\sheld\AppData\Local\devine\devine.yaml [Cookies] : C:\Users\sheld\Desktop\devine\cookies [WVDs] : C:\Users\sheld\AppData\Local\devine\WVDs [Cache] : C:\Users\sheld\Desktop\devine\cache [Logs] : C:\Users\sheld\Desktop\devine\logs [Temp Files] : C:\Users\sheld\Desktop\devine\temp [Downloads] : C:\Users\sheld\Desktop\devine\downloads C:\Users\sheld\Desktop\devine\devine>devine dl -w s01e01 CTV cold-squad / __ \/ ____/ | / / _/ | / / ____/ / / / / __/ | | / // // |/ / __/ / /_/ / /___ | |/ // // /| / /___ /_____/_____/ |___/___/_/ |_/_____/ ⠀ v3.3.1 Copyright © 2019-2024 rlaphoenix https://github.com/devine-dl/devine Service Config loaded Failed to load Widevine CDM, C:\Users\sheld\Desktop\devine\WVDs\ANDROID_4464_l3.wvd does not exist or is not a file C:\Users\sheld\Desktop\devine\devine>
[Attachment 78233 - Click to enlarge]
[Attachment 78234 - Click to enlarge]
Results 1,291 to 1,320 of 1613
IDK. Works for me. You might need to post more info like your config file?
Code:(.venv) D:\Desktop\devine>devine search all4 defiance / __ \/ ____/ | / / _/ | / / ____/ / / / / __/ | | / // // |/ / __/ / /_/ / /___ | |/ // // /| / /___ /_____/_____/ |___/___/_/ |_/_____/ ⠀ v3.3.1 Copyright © 2019-2024 rlaphoenix https://github.com/devine-dl/devine Service Config loaded ────────────────────────────── Service: ALL4 ─────────────────────────────── Service is not Geoblocked in your region + Acquired tokens... Authenticated with Service ───────────────────────────── 1 Search Results ───────────────────────────── Defiance: Fighting the Far Right How Britain's Asian community stood tall against far-right violence and racist murders id: defiance-fighting-the-far-right -
stabbedbybrick, is it possible to have credentials for devine ALL4 and CTV be optional? Believe it or not, I still use freevine 0.6.2-beta from time to time (haha) and I can search and download on that without any credentials.
[Attachment 78235 - Click to enlarge]thank you I can finally download BBC 4K on Mac -
use correct ID
Code:devine search iP "The Hairy Bikers Go West"
[Attachment 78236 - Click to enlarge]
Code:devine dl --list-titles iP m001w3pw
[Attachment 78239 - Click to enlarge]Last edited by iamghost; 9th Apr 2024 at 05:21.
achilles: Thank you once again. I have made the corrections that you wrote about. It still doesn't work; so perhaps I have made a mistake in my editing of the devine.yaml file. Here is the code and a picture of the devine.yaml file:
[CODE][/Microsoft Windows [Version 10.0.22000.2538]
C:\Users\sheld\Desktop\devine>devine dl -w s01e01 CTV cold-squad
Failed to load Widevine CDM, ANDROID_4464_l3 does not exist or is not
a file
C:\Users\sheld\Desktop\devine>CODE]
[Attachment 78244 - Click to enlarge]
Thank you in advance. It is very kind of you to be so patient. -
Thanks achilles for replying.
I have these two lines in the beginning in devine.yaml file in C:\devine\devine folder
Is this causing the error - JSONDecodeError: Expecting value: line 2 column 1 (char 1)?Code:endpoints: login: https://api.channel4.com/online/v2/auth/token title: https://api.channel4.com/online/v1/views/content-hubs/{title}.json ....... -
Using
It's working fineHTML Code:devine dl -w s01e01 all4 https://www.channel4.com/programmes/defiance-fighting-the-far-right
[Attachment 78247 - Click to enlarge] -
Still getting - JSONDecodeError: Expecting value: line 2 column 1 (char 1)UsingIt's working fine..HTML Code:
Something with configuration. -
I honestly don't know what is causing the error.
All I can say is that I installed devine via "pip install devine" and what this does is install devine as an executable which is what I am running, and that works.
I see that in your error results, there is reference to "C:\devine\devine\core\service.py" which indicates that maybe you installed devine by downloading a zip file, doing a git clone, or something else similar. And because you are running devine as interpreted code, maybe one of your requirements is out of date. I can't say for sure if this is what is causing the issues, but all I can say is that I did an official pip install of devine and that seems to be working ok. -
Thanks for the reply.
I followed iamghost post for installation from here.
https://forum.videohelp.com/threads/411643-Freevine-A-downloader-for-free-streaming-se...42#post2730799
Indeed it used zip installation.
Followed all steps without any error until I executed channel 4 command.
Also how do I check the requirements are up to date? -
Poetry should have handled all that for you. And I just did another fresh install, this time from official github repo (downloaded as zip) and installed via poetry and it worked just fine.
Hmm... the next message I get is "Service is not Geoblocked in your region" (which doesn't show on your output). So maybe your error has something to do with your IP address, VPN use (or lack of use) or proxy settings. -
Hey, guys, just a friendly reminder of what I wrote earlier:
I don't really mind if you discuss Devine in here, but creating an official thread would probably be more helpful for users learning it for the first time.Originally Posted by stabbedbybrick -
stabbedbybrick, are credentials really needed for All4? I still have freevine 0.6.2-beta running and All4 works with no credentials at all.
It would be best to dedicate a new topic thread to "Devine". I will start one if no one else wants to launch one.
Back to Freevine; I am all up to date and every service I use as far as I know is working except PLUTO which is only giving me the option of descriptive audio or no audio as well. I don't know if it is just me as no one responded when I wrote about it. I was hoping to get some fresh movies off of Pluto TV at the beginning of April but I ran across that and found no use in downloading as descriptive audio isn't what I want and having no audio at all isn't my thing either.
achilles: I put "wvds" in lower case letters in the yaml but I got the same result as above that my Android CDM doesn't exists. Regardless I better stop discussing Devine here and I will wait a bit to see someone launch a thread dedicated to Devine and if they don't I will.
Also thank you achilles and everyone who has taken the time to guide me and I hope others learn along with me. I tend to be happy with smaller files like 480p and lately I have been getting some series from CTV at 360p to save on hard drive space and they look fine on a 24 inch TV.
It seems that Devine only has the capability to download very high quality files that my under 10 mbs DSL would take quite a while to download and if I do get it working and Freevine stops working these big files I will just encode down to a lower quality and smaller file size.
I think through time there will be more options in Devine and maybe they are already there.Last edited by Tom Saurus; 9th Apr 2024 at 15:32.
I don't use windows, but could you show a list of what's in that folder?[/QUOTE]
.git
cache
cookies
devine
downloads
logs
temp
WVDs
.deepsource.toml
.editorconfig
.gitattributes
.gitignore
.pre-commit-config.yaml
CHANGELOG.md
cliff.toml
CONFIG.md
CONTRIBUTING.md
LICENSE
poetry.lock
pyproject.toml
README.md -
Right, but should you be in c:\devine\devine\ rather than c:\devine\ ?
If you want to be able to run it from other places, you'll need to put it in the PATH.
Is Python installed and working fine?
edit: how did you install it?
UK Free to Air Downloader
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 691Last Post: 13th Nov 2025, 13:25 -
Video/Screenshot Guide to Freevine/N_m3u8DL-RE downloader for MacOS
By gwilliams1996 in forum Video Streaming DownloadingReplies: 16Last Post: 15th May 2024, 07:14 -
Forcing quality on streaming services
By qnufc in forum Video Streaming DownloadingReplies: 10Last Post: 8th Mar 2024, 18:27 -
Are we going to see all streaming services switching to L1 completely
By Loryanam2 in forum Video Streaming DownloadingReplies: 7Last Post: 5th Mar 2023, 08:37 -
Portable Streaming DownLoader for XMovies8?
By KermitJ in forum Video Streaming DownloadingReplies: 0Last Post: 27th Sep 2019, 11:44
