Hi,
Running Freevine on Windows 11 for the first time as per:
freevine.py get --episode S09E01 https://uktvplay.co.uk/shows/qi-xl/series-9/episode-1/6338039604112
Runs and grabs key, but fails to start download as per:
Error: Got unexpected extra argument (https://uktvplay.co.uk/shows/qi-xl/series-9/episode-1/6338039604112)
(freevine) C:\Users\vwroc\freevine\Scripts>freevine.py get --episode S09E01 https://uktvplay.co.uk/shows/qi-xl/series-9/episode-1/6338039604112
❯_freevine v1.1.8
16:50:48.508 INFO : UKTV Play
16:50:48.939 INFO : QI XL: 6 Season(s), 79 Episode(s)
16:50:49.317 INFO : QI XL S09E01 I-Spy
16:50:49.317 INFO : c7146bcb9144422790bb4457e0f63bfc:8e0c1ea951c74b918 168f21cd5e4953e
Unrecognized command or argument '--no-log'.
Any advice to resolve appreciated.
Cheers
Steve
Results 1,141 to 1,170 of 1613
@stabbedbybrick - I joined the forum to say thank you. This is incredible coding, works perfectly!
Keep up the good work! Cheers
@SaintyUK:
Thank you. Glad you're enjoying it
Can you add Rakuten? I've tried doing it myself but I can't intercept the android requests, my http toolkit certificate keeps getting rejected by the Rakuten app.
Use Magisk Delta. If you already have magisk installed, uninstall it completely. And use Kitune Mask (magisk delta) enable magiskhide and select Rakuten. No need for shimiko to be installed or used with Delta, it works better at hiding apps. (Also, make sure you have developer options turned off on your device settings, spof bootloader enabled too, and hide the magisk app.)
Use Momo https://github.com/apkunpacker/MagiskDetection/blob/main/Momo-v4.4.1.apk
or
Securify https://github.com/RabehX/Securify/releases
to see what tell tales you're rooted device is giving away, because, believe me your device is giving away a lot of details.
Out of curiosity, what integrity level is your device passing? (Basic, device or hardware?) -
because you using pc browser, it need script to fetch mpd for andriod tv
pc and andriod tv is different endpoint
freevine
andriod tvCode:api: "https://graph.ibl.api.bbc.co.uk/" media: "https://open.live.bbc.co.uk/mediaselector/6/select/version/2.0/mediaset/{client}/vpid/{vpid}/" playlist: "https://www.bbc.co.uk/programmes/{pid}/playlist.json" base: "b4-thdow-bbc.live.bidi.net.uk"
Code:metadata = 'https://graph.ibl.api.bbc.co.uk/' playlist = 'https://www.bbc.co.uk/programmes/{pid}/playlist.json' manifest = 'https://securegate.iplayer.bbc.co.uk/mediaselector/6/select/version/2.0/vpid/{vpid}/format/json/mediaset/{mediaset}/proto/https'
[Attachment 77882 - Click to enlarge]Last edited by iamghost; 23rd Mar 2024 at 14:24.
Struggling to get few episodes of "My5 - Ben Fogle: New Lives in the Wild".
I am up-to-date with freevine, etc.
(but noticed new version of Shaka-Packager and not yet upgraded)
https://github.com/shaka-project/shaka-packager/releases/tag/v3.0.3
S04E05.Rum.Scotland - MISSING from MENU, available via direct link
https://www.channel5.com/show/ben-fogle-new-lives-in-the-wild/season-4/scotland
but as expected, it ends with error:Code:python3 freevine.py get -e S04E05 https://www.channel5.com/ben-fogle-new-lives-in-the-wild/ --proxy uk
KeyError: 'episodes'
Same for other episode
S15E01.Ullapool.Scotland - MISSING from MENU, available via direct link
https://www.channel5.com/show/ben-fogle-new-lives-in-the-wild/season-15/episode-1KeyError: 'episodes'Code:python3 freevine.py get -e S15E01 https://www.channel5.com/ben-fogle-new-lives-in-the-wild/ --proxy uk
Two episodes from Scotland ......
And the latest episode is also not possible to download
Ben.Fogle.New.Lives.in.the.Wild.S18E09.Thailand - Unable to download
https://www.channel5.com/show/ben-fogle-new-lives-in-the-wild/season-18/thailand-paul-revisited
and also finishes with error:Code:python3 freevine.py get -e S18E09 https://www.channel5.com/ben-fogle-new-lives-in-the-wild/ --proxy uk
Also been checking if Season 9 will appear, but no luck,
tried direct link, but that does not work
https://www.channel5.com/show/ben-fogle-new-lives-in-the-wild/season-9Last edited by pssh; 26th Mar 2024 at 16:01.
@pssh:
S04E05 and S15E01 have both been removed and aren't listed on their API. I don't know why they were removed, but that's how it is on these services.
As for S18E09, it works just fine:
Code:Ben Fogle: New Lives in the Wild S18E09 Paul Ferber Revisited 9d289b3b59bf42729c121ac64020b5e3:de10cb3b5bb305a0faa6befb20d7ca1f 80b71afc295b17c5a6b77a634b3323bf:de10cb3b5bb305a0faa6befb20d7ca1f https://akadash0.akamaized.net/hydra/C5472060009/C5472060009A/20240301034259/C5472060009.mpd
@pssh Looking at My5 website, it can clearly be seen that those episodes are not available to stream (they are totally missing from their listing, ie. they are just not there to be seen). If they are missing, obviously they cannot be either streamed or downloaded in any way. That is the same on any web streaming site.
Is there a way to "add" things to the cache without actually downloading them?
ie wanting to use -c in a list but not worried about the previous multiple seasons of a show -
Can you please let me know how to update freevine in linux ive tried this
git clone https://github.com/stabbedbybrick/freevine.git freevine
bash /update/update.sh
it has a freevine dir in update directory with it all in
Updates available from remote repository.
fatal: not a git repository (or any of the parent directories): .git
Repository updated and local changes reapplied.
Press Enter to exit
This is running under termux as per A_n_g_e_l_a's post on how to get it working on an android phone works fine apart from cant see how it updates
Thanks for looking -
10:39:45.156 INFO : My5 TV
10:39:45.156 INFO : + Adding service profile
10:39:47.610 INFO : Ben Fogle: New Lives in the Wild S18E10
10:39:47.610 INFO : ca04d9c25bfb48b4829c6af5fdfefa16:85462731e814b1488 439e9a643d91325
10:39:47.610 INFO : 8b0426d8b54b6f146552576dfdd7d19f:85462731e814b1488 439e9a643d91325
10:39:48.276 INFO : N_m3u8DL-RE (Beta version) 20231113
10:39:48.295 INFO : Loading URL: https://akadash0.akamaized.net/hydra/C5472060010/C5472060010A/20240321200127/C5472060010.mpd
10:39:48.379 INFO : Content Matched: Dynamic Adaptive Streaming over HTTP
10:39:48.379 INFO : Parsing streams...
10:39:48.382 WARN : Writing meta json
10:39:48.384 INFO : Extracted, there are 12 streams, with 9 basic streams, 2 audio streams, 1 subtitle streams
10:39:48.385 INFO : Vid *CENC 1920x1080 | 6000 Kbps | 1 | 25 | avc1.640028 | 1 Segment | ~45m05s
10:39:48.385 INFO : Vid *CENC 1280x720 | 4500 Kbps | 2 | 25 | avc1.64001f | 1 Segment | ~45m05s
10:39:48.386 INFO : Vid *CENC 1280x720 | 2800 Kbps | 3 | 25 | avc1.64001f | 1 Segment | ~45m05s
10:39:48.386 INFO : Vid *CENC 832x468 | 1500 Kbps | 4 | 25 | avc1.64001e | 1 Segment | ~45m05s
10:39:48.386 INFO : Vid *CENC 640x360 | 1200 Kbps | 5 | 25 | avc1.64001e | 1 Segment | ~45m05s
10:39:48.386 INFO : Vid *CENC 640x360 | 800 Kbps | 6 | 25 | avc1.64001e | 1 Segment | ~45m05s
10:39:48.387 INFO : Vid *CENC 640x360 | 480 Kbps | 7 | 25 | avc1.64001e | 1 Segment | ~45m05s
10:39:48.387 INFO : Vid *CENC 640x360 | 360 Kbps | 8 | 25 | avc1.64001e | 1 Segment | ~45m05s
10:39:48.387 INFO : Vid *CENC 320x180 | 160 Kbps | 9 | 25 | avc1.64000c | 1 Segment | ~45m05s
10:39:48.387 INFO : Aud *CENC 10 | 96 Kbps | mp4a.40.2 | en | 2CH | 1 Segment | Main | ~45m05s
10:39:48.388 INFO : Aud *CENC 11 | 32 Kbps | mp4a.40.5 | en | 1CH | 1 Segment | Main | ~45m05s
10:39:48.388 INFO : Sub 12 | en | 1 Segment | Subtitle | ~45m05s
10:39:48.388 INFO : Parsing streams...
10:39:48.388 INFO : Selected streams:
10:39:48.389 INFO : Vid *CENC 1280x720 | 4500 Kbps | 2 | 25 | avc1.64001f | 1 Segment | ~45m05s
10:39:48.389 INFO : Aud *CENC 10 | 96 Kbps | mp4a.40.2 | en | 2CH | 1 Segment | Main | ~45m05s
10:39:48.389 INFO : Sub 12 | en | 1 Segment | Subtitle | ~45m05s
10:39:48.389 WARN : Writing meta json
10:39:48.390 INFO : Save Name: Ben.Fogle.New.Lives.in.the.Wild.S18E10.720p.MY5.WE B-DL.AAC2.0.H.264 -
You're not using the complete URL: https://www.channel5.com/show/ben-fogle-new-lives-in-the-wild/
I see,
AppleTV has the episodes (S04E05.Rum.Scotland / S15E01.Ullapool.Scottish.Highlands) missing as well
and some others that are available on My5 ....and Amz only offers limited seasons (S05,06,07,10,12,13).
Thanx for checking ... I wonder why two of episodes (both from Scotland) are missing ... -
UK Free to Air Downloader
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 691Last Post: 13th Nov 2025, 13:25 -
Video/Screenshot Guide to Freevine/N_m3u8DL-RE downloader for MacOS
By gwilliams1996 in forum Video Streaming DownloadingReplies: 16Last Post: 15th May 2024, 07:14 -
Forcing quality on streaming services
By qnufc in forum Video Streaming DownloadingReplies: 10Last Post: 8th Mar 2024, 18:27 -
Are we going to see all streaming services switching to L1 completely
By Loryanam2 in forum Video Streaming DownloadingReplies: 7Last Post: 5th Mar 2023, 08:37 -
Portable Streaming DownLoader for XMovies8?
By KermitJ in forum Video Streaming DownloadingReplies: 0Last Post: 27th Sep 2019, 11:44
