Is there a way just to select one (.vtt) subtitle track from rte? all 3 are the same, just different formats, and vtt seems to include the color brackets.
Results 1,111 to 1,140 of 1613
I have tried using the Windows terminal (powershell). Still the same error.
But, I've found the reason for it. It seems to be to do with filenames.
In the config.yaml, I use
filename:
series: "{title} S{season}E{episode} {name} [{resolution}]"
movies: "{title} ({year}) [{resolution}]"
That has worked with every UK channel so far.
You use:
filename:
series: "{title}.S{season}E{episode}.{name}.{resolution}.{ service}.WEB-DL.{audio}.H.264"
movies: "{title}.{year}.{resolution}.{service}.WEB-DL.{audio}.H.264"
There's actually not that much difference between the two except you have dot separators and extra stuff added. I tried yours. It worked fine. I tried mine, replacing the space separators with dots. Still the same 'color' error. After a few experiments, it's the square brackets [] it doesn't like that I have around the resolution. If I use parentheses (), it's OK. So, for some reason [] works fine with all other channels apart from RTE.
Is there any obvious explanation? Could you possibly adjust the code to accept square brackets? -
Nice work figuring out the culprit. I still have no idea what the reason is and why you have this error when I don't:
Code:15:30:57.485 INFO : Decrypting... 15:31:12.408 WARN : Fair City E12 [1080p].mp4 15:31:12.408 WARN : Fair City E12 [1080p].m4a 15:31:12.409 WARN : Fair City E12 [1080p].copy.srt 15:31:12.409 WARN : Fair City E12 [1080p].en.srt 15:31:12.410 WARN : Fair City E12 [1080p].srt 15:31:12.410 WARN : Muxing to Fair City E12 [1080p].MUX.mkv 15:31:20.331 WARN : Cleaning files... 15:31:20.504 WARN : Rename to Fair City E12 [1080p].mkv 15:31:20.505 INFO : Done
Can mp4decrypt be ran on a Pi3? I'm using the 'Lite' Debian 64bit OS
Code:19:54:58.614 ERROR: An error occurred trying to start process '/media/freevine/mp4decrypt' with working directory '/media/freevine'. Exec format error
It's all very strange if you cannot reproduce it. My mkvmerge.exe was a little out of date, but updating that did nothing. I've even used your exact config.yaml except for square brackets around your {resolution}, still the same.
On another note. I normally have my config.yaml setup so that it defaults to, for subs, no_mux: "true".
Is it possible to have an extra option for the command line to reverse this, eg: --sub-mux. You seem to have all the other options covered at command line level apart from this one. -
I have an issue with cbs from a proxy
Code:13:07:19.425 INFO : CBS 13:07:19.427 INFO : + Adding service profile 13:07:19.630 INFO : + Adding Hola proxy location: US Traceback (most recent call last): File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\urllib3\connectionpool.py", line 712, in urlopen self._prepare_proxy(conn) File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\urllib3\connectionpool.py", line 1012, in _prepare_proxy conn.connect() File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\urllib3\connection.py", line 419, in connect self.sock = ssl_wrap_socket( ^^^^^^^^^^^^^^^^ File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\urllib3\util\ssl_.py", line 449, in ssl_wrap_socket ssl_sock = _ssl_wrap_socket_impl( ^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\urllib3\util\ssl_.py", line 493, in _ssl_wrap_socket_impl return ssl_context.wrap_socket(sock, server_hostname=server_hostname) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\ssl.py", line 455, in wrap_socket return self.sslsocket_class._create( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\ssl.py", line 1046, in _create self.do_handshake() File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\ssl.py", line 1321, in do_handshake self._sslobj.do_handshake() ssl.SSLEOFError: [SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1000) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\requests\adapters.py", line 486, in send resp = conn.urlopen( ^^^^^^^^^^^^^ File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\urllib3\connectionpool.py", line 799, in urlopen retries = retries.increment( ^^^^^^^^^^^^^^^^^^ File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\urllib3\util\retry.py", line 592, in increment raise MaxRetryError(_pool, url, error or ResponseError(cause)) urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='www.cbs.com', port=443): Max retries exceeded with url: /shows/video/5o3H2I9ypVZsb8fwIEWoDlTsftOKTWpN/ (Caused by SSLError(SSLEOFError(8, '[SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1000)'))) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "C:\freevine\freevine.py", line 15, in <module> cli() File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 1157, in __call__ return self.main(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 1078, in main rv = self.invoke(ctx) ^^^^^^^^^^^^^^^^ File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 1688, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 1434, in invoke return ctx.invoke(self.callback, **ctx.params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 783, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\freevine\utils\commands.py", line 90, in get Service(config, **kwargs) File "C:\freevine\services\cbs\cbs.py", line 51, in __init__ self.get_options() File "C:\freevine\services\cbs\cbs.py", line 216, in get_options downloads, title = get_downloads(self) ^^^^^^^^^^^^^^^^^^^ File "C:\freevine\utils\options.py", line 160, in get_downloads downloads, title = stream.get_episode_from_url(stream.episode) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\freevine\services\cbs\cbs.py", line 181, in get_episode_from_url r = self.client.get(url) ^^^^^^^^^^^^^^^^^^^^ File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\requests\sessions.py", line 602, in get return self.request("GET", url, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\requests\sessions.py", line 589, in request resp = self.send(prep, **send_kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\requests\sessions.py", line 703, in send r = adapter.send(request, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\requests\adapters.py", line 517, in send raise SSLError(e, request=request) requests.exceptions.SSLError: HTTPSConnectionPool(host='www.cbs.com', port=443): Max retries exceeded with url: /shows/video/5o3H2I9ypVZsb8fwIEWoDlTsftOKTWpN/ (Caused by SSLError(SSLEOFError(8, '[SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1000)'))) Press any key to continue . . .
Video url https://www.cbs.com/shows/video/5o3H2I9ypVZsb8fwIEWoDlTsftOKTWpN/
Same error with ep with VPNLast edited by PSXman_uk; 12th Mar 2024 at 07:14.
Muxing everything is default behavior so there's no need to have it as an option. Setting the subtitle no_mux option to false in config and then using --sub-no-mux when needed seems like a better solution.
Originally Posted by PSXman_uk -
its only that url after further testing all the other normal ones seem to work fine not a big deal just errors.
Code:https://vod-gcs-cedexis.cbsaavideo.com/intl_vms/2024/02/29/2313106499803/2613062_cenc_dash/stream.mpd Key=20248ba2e9c14135a4149d476a063566:63cdad75ee901ab1e51403ec99b15ebe
Weird one thatLast edited by PSXman_uk; 12th Mar 2024 at 14:34.
Back to the square bracket issue in the final filename.
After further investation I've found if we download multiple streams of the same thing, whether that 'thing' be audio or subs, I get that 'color' error. For instance, with RTE, it automatically downloads multiple subs streams. That causes the problem. Just selecting one stream in the CL solves the problem (more on that later).
It's not just subs. Take Channel 4, Screw S01E01 which has two audio streams: 'audio=128000' and 'audio_eng=128000'. Normally we have the config set to download the 'best' one only, so we don't see any problem. But try downloading both of them by setting audio options in config to "for=best2":
Code:py freevine.py get --no-cache -e https://www.channel4.com/programmes/screw/on-demand/68619-001
With regard to RTE and which subs stream to select.
There's a suggestion above to use the '-ss id=textstream=1000' subs stream.
However,
Code:py freevine.py get --no-cache -ss id=textstream=1000 -e https://www.rte.ie/player/series/fair-city/SI0000000564?epguid=IH10002398-24-0013
using '-ss id=textstream_eng=1000':
Code:py freevine.py get --no-cache -ss id=textstream_eng=1000 -e https://www.rte.ie/player/series/fair-city/SI0000000564?epguid=IH10002398-24-0013
Yes, it yields the same error:
Code:N_m3u8DL-RE -M format=mp4 --auto-select --auto-subtitle-fix --thread-count 16 --del-after-done --save-dir ./Finished --tmp-dir ./ -mt --key 9dfcf0625c1091550a83b17ac8f75505:5dda52c3a681dbc74193502815a9b1d8 "https://vod.rte.ie/rte/vod-d/RTE_Prod_-_Prod/65/1016/IH10002398-24-0013/M3814629-1709830184232.ism/.mpd?filter=systemBitrate%3C%3D7000000&hls_fmp4=true&available=1710104400&expiry=1712692800&ip=82.46.151.107&token1=b0f7a7b5f9ee5e5f4690c843b9aa6e6ee210c3ee8bc5f2f1a99a8ee70412cef9" --save-name "Fair City [1080p]"
So, conclusion: if you download multiple streams of subs or multiple streams of audio, and having square brackets in the end filename, N_m3u8DL-RE does not like it and will not mux. Certainly on a Windows system, anyway.
I guess I'll stick with parenthesis () lol. -
I've tried on both Windows and Linux and have no problems with any of this. The error seem specific to your setup and N_m3u8DL-RE. You could open an issue on their github and see if they can bring some clarity.
Either way, this is outside the scope of Freevine and unfortunately not something I can fix for you. -
I've solved it. I, like many others, was still using the N_m3u8DL-RE release from Jun 28, 2023. I've now downloaded the new pre-release version as described in https://github.com/stabbedbybrick/freevine/releases/tag/v1.1.8
The square brackets in filename problem no longer exists with that.
@stabbedbybrick I assume that you are using that version, so could not reproduce the problem.
Many thanks to AlwaysDistracted for helping me to solve this.
I will say, it has produced other problems though. Avast AV would not let me download the zip file (possible malware). Even disabling Avast I still couldn't download it. I had to source it from another PC that had downloaded it. I ran both an Avast & Malwarebytes scan on it and they detected no issues. However, using it, again Avast kicks in. I've now added it as an exception in Avast.
I am assuming it is safeLast edited by deccavox; 15th Mar 2024 at 17:58.
Ah, damn. I've been using that build of N_m3u8DL-RE for months, so I totally forgot about it not being standard and didn't think it could be the reason. But glad to hear you figured it out. My best guess for the initial bug is that the brackets are somehow interpreted as markdown, where [ ] are used to display things like styles, links, etc. Which they seemed to have fixed since.
If you're worried about it being safe, it's pretty easy to build it yourself. Just fork their repository and run their workflow. -
Has anyone tried getting an episode of Station Eleven from CBC? I think the URL was https://gem.cbc.ca/station-eleven, but I'm nowhere near my laptop to check.
Other CBC shows are fine, but this one didn't work when I tried it (but it did play in a browser). -
python freevine.py get -e ep https://gem.cbc.ca/station-eleven standard mode doesn't like the url needs the episode number.
ie S01E01 -
Thanks, I'll grab the latest from github and try it again. User error
Edit: I've almost finished watching this in the browser, but I did try the latest from github, (same issue):
Code:py freevine.py get --proxy ca -e s01e08 https://gem.cbc.ca/station-eleven ❯_freevine v1.1.8 ←[4m←[32mINFO←[0m : ←[1mCBC Gem←[0m ←[4m←[32mINFO←[0m : + Adding service profile ←[4m←[32mINFO←[0m : + Adding Hola proxy location: CA ←[4m←[32mINFO←[0m : Using cached login tokens ←[4m←[32mINFO←[0m : + New access tokens placed in cache Traceback (most recent call last): File "E:\freevine\lib\site-packages\requests\models.py", line 971, in json return complexjson.loads(self.text, **kwargs) File "C:\Users\b\AppData\Local\Programs\Python\Python310\lib\json\__init__.py", line 346, in loads return _default_decoder.decode(s) File "C:\Users\b\AppData\Local\Programs\Python\Python310\lib\json\decoder.py", line 337, in decode obj, end = self.raw_decode(s, idx=_w(s, 0).end()) File "C:\Users\b\AppData\Local\Programs\Python\Python310\lib\json\decoder.py", line 355, in raw_decode raise JSONDecodeError("Expecting value", s, err.value) from None json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "E:\freevine\freevine.py", line 15, in <module> cli() File "E:\freevine\lib\site-packages\click\core.py", line 1157, in __call__ return self.main(*args, **kwargs) File "E:\freevine\lib\site-packages\click\core.py", line 1078, in main rv = self.invoke(ctx) File "E:\freevine\lib\site-packages\click\core.py", line 1688, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) File "E:\freevine\lib\site-packages\click\core.py", line 1434, in invoke return ctx.invoke(self.callback, **ctx.params) File "E:\freevine\lib\site-packages\click\core.py", line 783, in invoke return __callback(*args, **kwargs) File "E:\freevine\utils\commands.py", line 90, in get Service(config, **kwargs) File "E:\freevine\services\cbc\cbc.py", line 61, in __init__ self.get_options() File "E:\freevine\services\cbc\cbc.py", line 425, in get_options downloads, title = get_downloads(self) File "E:\freevine\utils\options.py", line 163, in get_downloads content, title = stream.get_content(stream.url) File "E:\freevine\services\cbc\cbc.py", line 406, in get_content content = self.get_series(url) File "E:\freevine\services\cbc\cbc.py", line 232, in get_series data = self.get_data(url) File "E:\freevine\services\cbc\cbc.py", line 229, in get_data return self.client.get(url).json() File "E:\freevine\lib\site-packages\requests\models.py", line 975, in json raise RequestsJSONDecodeError(e.msg, e.doc, e.pos) requests.exceptions.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
it looks like your current issue is with your cached tokens, try deleting them from the cbc profile.yaml file and then try again.
but the problem for station-eleven seems to be that 1080p is not available so it errors out on the try/except on line 333 of cbc.py when the request to the smooth url fails with an error code 400. this might be something for stabby to look at.
Code:>py freevine.py get -e s01e07 https://gem.cbc.ca/station-eleven ❯_freevine v1.1.8 12:45:42.518 ←[4m←[32mINFO←[0m : ←[1mCBC Gem←[0m 12:45:42.519 ←[4m←[32mINFO←[0m : + Adding service profile 12:45:42.526 ←[4m←[32mINFO←[0m : Cache is empty, aquiring new login tokens... 12:45:43.850 ←[4m←[32mINFO←[0m : + New login tokens placed in cache 12:45:48.016 ←[4m←[32mINFO←[0m : + New access tokens placed in cache 12:45:50.043 ←[4m←[32mINFO←[0m : Station Eleven: 1 Season(s), 10 Episode(s) Traceback (most recent call last): File "C:\freevine\freevine.py", line 15, in <module> cli() File "C:\freevine\venv\lib\site-packages\click\core.py", line 1157, in __call__ return self.main(*args, **kwargs) File "C:\freevine\venv\lib\site-packages\click\core.py", line 1078, in main rv = self.invoke(ctx) File "C:\freevine\venv\lib\site-packages\click\core.py", line 1688, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) File "C:\freevine\venv\lib\site-packages\click\core.py", line 1434, in invoke return ctx.invoke(self.callback, **ctx.params) File "C:\freevine\venv\lib\site-packages\click\core.py", line 783, in invoke return __callback(*args, **kwargs) File "C:\freevine\utils\commands.py", line 90, in get Service(config, **kwargs) File "C:\freevine\services\cbc\cbc.py", line 61, in __init__ self.get_options() File "C:\freevine\services\cbc\cbc.py", line 437, in get_options self.download(download, title) File "C:\freevine\services\cbc\cbc.py", line 440, in download mpd_url, m3u8, audio = self.get_playlist(stream.data) File "C:\freevine\services\cbc\cbc.py", line 396, in get_playlist return self.get_hls(response.get("url")) File "C:\freevine\services\cbc\cbc.py", line 335, in get_hls r.raise_for_status() File "C:\freevine\venv\lib\site-packages\requests\models.py", line 1021, in raise_for_status raise HTTPError(http_error_msg, response=self) requests.exceptions.HTTPError: 400 Client Error: Bad Request for url: https://cbcrcott-drm-gem.akamaized.net/85b62b72-cd6d-4787-b4c8-badb95368b22/CBC_STATIONELEVEN_S01E07.ism/manifest(filter=QualityLevels(5999999)/Manifest(video,type=keyframes)
There's something off with this show. Can you really play this in browser? Every browser I try returns a media error and a 403 response code. And when looking at the response in the code, it returns an .mpd without hmac, when it should return a .m3u8 with an hmac, so it fails to read the original manifest even in browser.
All other shows are working as expected, so they've messed something up with this one. If you really can play this show, I'm thoroughly puzzled. -
Yes, it plays in the browser, but not easily. It's the only time I've ever needed to use hola, and that only worked with -proxy-type lum.
When it plays in the browser you can see that widevine is used (I didn't think other shows on CBC used widevine).
I tried uncommenting the 'proxy-type' and 'lum' lines in your script, that might have been when I saw the 400 error. Putting the manifest into yt-dlp shows that it is only 720p as ElCap said. -
Okay, after some testing it turns out that this particular show is indeed encrypted and have a much more aggressive geo block. I don't know if it's just a one-off or if it's a sign of things to come, but it's at least confirmed for Station Eleven. Handling the encryption is no problem, but adding this new variant to an already pretty rough codebase is... not fun.
I think I'm going to hold back a bit and see if they keep adding more DRM content before I start rewriting a bunch of stuff. This is so far the only title I've seen on CBC that is encrypted. -
I ran into the same issue with 2 other shows on cbc gem:
HTML Code:https://gem.cbc.ca/wild-cards
HTML Code:https://gem.cbc.ca/allegiance
Easy enough to download with N_m3u8DL-RE. So if you can work y our magic and add back to freevine, that would be great! Only getting 720p versions, which is all I normally had downloaded for space reasons. I think freevine had picked up 1080p if I am not mistaken. -
@ehurdler:
I'm not sure what you mean? Neither of those shows use DRM and they work fine in the current version of the script. -
hmmmm, you are right, I guess NOT the same. My bad.
I get the following, even after I clear-cache.
Code:(venv) C:\freevine>python freevine.py clear-cache ❯_freevine v1.1.8 13:11:06.474 ←[4m←[32mINFO←[0m : Download cache has been cleared! (venv) C:\freevine>python freevine.py get --season S01E06 https://gem.cbc.ca/allegiance ❯_freevine v1.1.8 13:11:10.374 ←[4m←[32mINFO←[0m : ←[1mCBC Gem←[0m 13:11:10.375 ←[4m←[32mINFO←[0m : + Adding service config 13:11:10.383 ←[4m←[32mINFO←[0m : + Adding service profile 13:11:10.407 ←[4m←[32mINFO←[0m : Refreshing expired login tokens... Traceback (most recent call last): File "C:\freevine\freevine.py", line 15, in <module> cli() File "C:\freevine\venv\Lib\site-packages\click\core.py", line 1157, in __call__ return self.main(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\freevine\venv\Lib\site-packages\click\core.py", line 1078, in main rv = self.invoke(ctx) ^^^^^^^^^^^^^^^^ File "C:\freevine\venv\Lib\site-packages\click\core.py", line 1688, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\freevine\venv\Lib\site-packages\click\core.py", line 1434, in invoke return ctx.invoke(self.callback, **ctx.params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\freevine\venv\Lib\site-packages\click\core.py", line 783, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\freevine\utils\commands.py", line 90, in get Service(config, **kwargs) File "C:\freevine\services\cbc\cbc.py", line 61, in __init__ self.get_options() File "C:\freevine\services\cbc\cbc.py", line 425, in get_options downloads, title = get_downloads(self) ^^^^^^^^^^^^^^^^^^^ File "C:\freevine\utils\options.py", line 163, in get_downloads content, title = stream.get_content(stream.url) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\freevine\services\cbc\cbc.py", line 406, in get_content content = self.get_series(url) ^^^^^^^^^^^^^^^^^^^^ File "C:\freevine\services\cbc\cbc.py", line 232, in get_series data = self.get_data(url) ^^^^^^^^^^^^^^^^^^ File "C:\freevine\services\cbc\cbc.py", line 224, in get_data access_token = self.authenticate() ^^^^^^^^^^^^^^^^^^^ File "C:\freevine\services\cbc\cbc.py", line 204, in authenticate auth_token = self.refresh_auth_token(cache["login"]["refresh"]) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\freevine\services\cbc\cbc.py", line 176, in refresh_auth_token access_token = auth.get("access_token") ^^^^^^^^ AttributeError: 'Response' object has no attribute 'get'
Last edited by ehurdler; 19th Mar 2024 at 13:14. Reason: Fixed it, or Understood and fixed it! :-)
UK Free to Air Downloader
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 641Last Post: 4th Sep 2025, 16:53 -
Video/Screenshot Guide to Freevine/N_m3u8DL-RE downloader for MacOS
By gwilliams1996 in forum Video Streaming DownloadingReplies: 16Last Post: 15th May 2024, 06:14 -
Forcing quality on streaming services
By qnufc in forum Video Streaming DownloadingReplies: 10Last Post: 8th Mar 2024, 17:27 -
Are we going to see all streaming services switching to L1 completely
By Loryanam2 in forum Video Streaming DownloadingReplies: 7Last Post: 5th Mar 2023, 07:37 -
Portable Streaming DownLoader for XMovies8?
By KermitJ in forum Video Streaming DownloadingReplies: 0Last Post: 27th Sep 2019, 10:44
