Results 751 to 780 of 1613
i see you have add --proxy on search.
got error from roku
Code:freevine.py get -t https://therokuchannel.roku.com/details/c3489391fe1b5f849da2923a671d62eb/cupcake-wars --proxy US
Code:content, title = stream.get_content(stream.url) File "services\roku\roku.py", line 198, in get_content content = self.get_series(url) File "services\roku\roku.py", line 92, in get_series episodes = asyncio.run(self.get_titles(data)) File "C:\Python\Python 3.09\lib\asyncio\runners.py", line 44, in run return loop.run_until_complete(main) File "C:\Python\Python 3.09\lib\asyncio\base_events.py", line 647, in run_until_complete return future.result() File "services\roku\roku.py", line 88, in get_titles return await asyncio.gather(*tasks) File "services\roku\roku.py", line 79, in fetch_titles return response.json() File "C:\Python\Python 3.09\lib\site-packages\httpx\_models.py", line 761, in json return jsonlib.loads(self.content, **kwargs) File "C:\Python\Python 3.09\lib\json\__init__.py", line 346, in loads return _default_decoder.decode(s) File "C:\Python\Python 3.09\lib\json\decoder.py", line 337, in decode obj, end = self.raw_decode(s, idx=_w(s, 0).end()) File "C:\Python\Python 3.09\lib\json\decoder.py", line 355, in raw_decode raise JSONDecodeError("Expecting value", s, err.value) from None json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0) -
Some platforms aggressively fend off VPN connections. This happens to me with iPlayer from USA.
They have implemented measures to block VPNs as they see multiple requests coming from the same IP suggesting some funny business. -
Thanks for the information. I gave up on BBC iPlayer and I suppose it is time to give up the ghost when it comes to Roku US. I had success with Plex but now it is not working for me. I will try to go back in and get "CHiPs" as they have all six seasons but as of now there are problems. However I got most of what I wanted. I bought the Complete Series of the original "Kung Fu" but the discs for season three were flawed so I couldn't back up all the episodes from them. Thankfully with Plex I got the ones that I couldn't back up and in better quality I would say then the DVDs. But I can live without CHiPs" if it will no longer work for me. On Roku they have one of my favorite cartoon series "The Raccoons" but maybe eventually it will show up on Tubi TV.
I found out what I did wrong with Plex. I don't need to us hola proxy and when I use it fails.
I came close earlier today with CWTV and hola proxy US. It was downloading an episode of Doc but it fails with hls issues and such.Last edited by Tom Saurus; 15th Jan 2024 at 20:56.
For anyone else like me who's not the most proficient with git, I have a little batch file I run to update Freevine which seems to work a treat:
Because I have a couple of custom batch files inside the folder I don't want the contents completely wiped and refreshed when I update, so this seems to do the job for me, updates Freevine correctly without removing my own files.Code:@echo off echo Updating the repository... git fetch echo Resetting local changes to tracked files... git reset --hard HEAD echo Checking out the main branch... git checkout main echo Pulling the latest changes without affecting local custom files... git stash git pull origin main git stash pop echo Updated files: git diff --name-only HEAD@{1}..HEAD echo Update complete. pause
Just save as something like Update_Repo.bat and run it when you want to check if there's been an update (or you've been notified by email there was).
Hope it's useful for someone, if not, just ignore me
Thanks go to Stabbedbybrick as always for this incredibly handy little tool!
ABC iView playing funny buggers with their audio on many series lately. Typically they'll show two audio streams like audio-en-mp4a-1 and audio-en-mp4a-2 where the second one is the descriptive audio. But on occasions the 2nd stream will be listed 1st or it'll be 1kbps greater in size so freevine will pick that up as the best quality. At least I'm becoming more familiar with the audio selection commands now
Just wanted to say a heartfelt thanks for this project. I've been using it for a little while, and find it to be infinitely helpful.
One very, very minor gripe that I've noticed in the latest version is when the video id of an episode has been stored in the cache.json file. If you then want to download a different quality, it tells you that the file "was found in cache. Skipping download..."
Is there any chance it would make sense to store the stream resolution(s) that have already been downloaded? -
@AlwaysDistracted:
Yeah, it started out having the quality stored as well, but became a huge mess for any video outside of the strict 360, 540, 720, 1080 formats. The point of the cache is to check for existing downloads without adding a bunch of API requests, and the only way to get the true resolution of a stream is to perform those requests. If a past download was 712p instead of 720p for example, there would be no way of checking if that resolution is already in cache without knowing that it exists first. If that makes any sense.
I have some ideas on how to fix it, though, so it'll probably be added later on. In the meantime, a quick "freevine.py clear-cache" will clear everything and let you download the same stream again. -
Is there any way to deal with this?
Multiple episodes all with the same episode name, so trying to download all of those ends up skipping half of them because it thinks it's already downloaded Pointless.Celebrities.S15.Special.720p.iP.WEB-DL.AAC2.0.H.264.Code:❯_freevine v1.1.3 21:11:32.247 INFO : BBC iPlayer 21:11:32.710 INFO : Pointless Celebrities: 4 Season(s), 34 Episode(s) 21:11:32.710 INFO : Pointless Celebrities S13 Impressionists 21:11:32.710 INFO : Pointless Celebrities S15 Special 21:11:32.711 INFO : Pointless Celebrities S15 Special 21:11:32.711 INFO : Pointless Celebrities S15 Special 21:11:32.711 INFO : Pointless Celebrities S15 Special 21:11:32.711 INFO : Pointless Celebrities S15 Special 21:11:32.712 INFO : Pointless Celebrities S15 Special 21:11:32.712 INFO : Pointless Celebrities S15 Special 21:11:32.712 INFO : Pointless Celebrities S15 Special 21:11:32.712 INFO : Pointless Celebrities S15 Special 21:11:32.712 INFO : Pointless Celebrities S15 Special 21:11:32.712 INFO : Pointless Celebrities S15 Special 21:11:32.712 INFO : Pointless Celebrities S15 Special 21:11:32.712 INFO : Pointless Celebrities S15 Special 21:11:32.713 INFO : Pointless Celebrities S15 Special 21:11:32.713 INFO : Pointless Celebrities S15 Special 21:11:32.713 INFO : Pointless Celebrities S15 News 21:11:32.713 INFO : Pointless Celebrities S15 Special 21:11:32.713 INFO : Pointless Celebrities S15 Special 21:11:32.713 INFO : Pointless Celebrities S15 Special 21:11:32.713 INFO : Pointless Celebrities S15 Broadcasters 21:11:32.714 INFO : Pointless Celebrities S15 Special 21:11:32.714 INFO : Pointless Celebrities S16 Christmas Special 2022 21:11:32.714 INFO : Pointless Celebrities S16 BBC Centenary Special 21:11:32.714 INFO : Pointless Celebrities S16E03 21:11:32.714 INFO : Pointless Celebrities S16E04 21:11:32.714 INFO : Pointless Celebrities S16E05 21:11:32.714 INFO : Pointless Celebrities S16E06 21:11:32.715 INFO : Pointless Celebrities S16E07 21:11:32.715 INFO : Pointless Celebrities S16E08 21:11:32.715 INFO : Pointless Celebrities S16E09 21:11:32.715 INFO : Pointless Celebrities S16E10 21:11:32.715 INFO : Pointless Celebrities S17 Eurovision 2023 21:11:32.715 INFO : Pointless Celebrities S17 Comedy
Obviously on iPlayer each of those titles has its own pid, so if the filenames could contain that pid, there'd be no dupe filenames. I don't believe the config.yaml filename lines allow you to specify that, but I couldn't find any documentation for those settings. -
That does get round the file duping issue, but then I end up with a list of files like:
Pointless.Celebrities.S15E01.Special.720p.iP.WEB-DL.AAC2.0.H.264
Pointless.Celebrities.S15E02.Special.720p.iP.WEB-DL.AAC2.0.H.264
Pointless.Celebrities.S15E03.Special.720p.iP.WEB-DL.AAC2.0.H.264
Pointless.Celebrities.S15E04.Special.720p.iP.WEB-DL.AAC2.0.H.264
etc, so I'll still have to play each one for a bit to see who the contestants are, then cross-reference with TVDB etc to work out what episode it actually is, then rename it.
At least putting the pid in the filename, as is the default with yt-dlp or get-iplayer - Pointless Celebrities, Series 15, Special [m001n9t1].mp4 for example - makes it a bit easier to work out what episode number it is, as per TVDB, to then be able to rename it.
Of course, the BBC are to blame in the first place for not giving those episodes proper episode numbers. It's Celebrity Pointless. They're all specials... -
The cache function is great, and will likely help a lot with sites like Channel4 that have pretty strict rate limiting stuff in my experience, but being able to ignore the cache on a per-run basis without wiping it would be really handy.
There's a slight issue with this new implementation. It looks like the only check it now does (or maybe the old bug I posted about before is back?) is to check the cache to see if something's already marked as having been downloaded. If the file's there, but was downloaded with a pre-cache version of freevine (or, I guess, if you've cleared the cache) then it'll still download, decrypt and mux it, but fail to rename the file because the destination filename already exists, leaving a hanging .MUX. file. -
Yup, all good suggestions. I'll see what I can do.
The latest commits added "--no-cache" and "--append-id" options. You can now ignore the cache checks, but it'll still skip any existing files while adding them to the cache.
Curious if there is another endpoint with my5? Noticed with some random episodes here and there (even new ones) they are SD only, even when the rest of the episodes are HD.
eg mpd url of HD:eg mpd url of SD:Code:https://akadash0.akamaized.net/hydra/
Or its just one endpoint and my5 is just a hopeless.Code:https://akadash0.akamaized.net/cenc/
@pauli3:
Do you have any specific examples? It's possible only an adjustment is needed. -
Please, someone may help me.. spent reading details here over 8 months and my stupid head still cant get the keys from link to watch fight this weekend:
https://dce-fs-live-dazn-cdn.dazn.com/dashdrm/dazn-linear-054/stream.mpd.
So far I can get max these details and stuck:
<?xml version="1.0" encoding="utf-8"?>
<MPD xmlns="urn:mpeg:dash
chema:mpd:2011" xmlns:ns1="http://www.w3.org/2001/XMLSchema-instance" ns1
chemaLocation="urn:mpeg:dash
chema:mpd:2011 DASH-MPD.xsd" profiles="urn:mpeg:dash
rofile:isoff-live:2011,urn:dvb:dash
rofile:dvb-dash:2014,urn:dvb:dash
rofile:dvb-dash:isoff-ext-live:2014,http://dashif.org/guidelines/dash-if-simple" xmlns:cenc="urn:mpeg:cenc:2013" xmlns:mspr="urn:microsoft
layready" timeShiftBufferDepth="PT1M0S" minimumUpdatePeriod="PT2S" maxSegmentDuration="PT2.11S" availabilityStartTime="1970-01-01T00:00:00Z" publishTime="2024-01-13T18:10:10Z" minBufferTime="PT1S" type="dynamic">
<Period start="PT0S" id="p_0_0">
<BaseURL>0/</BaseURL>
<AdaptationSet id="1" contentType="video" maxWidth="1920" maxHeight="1080" minFrameRate="25" maxFrameRate="50" par="16:9" mimeType="video/mp4" segmentAlignment="true" startWithSAP="1">
<ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc" cenc:default_KID="82f8e2a1-7dac-44c0-a18f-660479349c59"/>
<ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed">
<cenc
ssh>AAAARXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAACUIAR IQgvjioX2sRMChj2YEeTScWSIPZGF6bi1saW5lYXItMDU0</cenc
ssh>
</ContentProtection>
<ContentProtection schemeIdUri="urn:uuid:9a04f079-9840-4286-ab92-e65be0885f95" value="MSPR 2.0">
<cenc
ssh>AAACJnBzc2gAAAAAmgTweZhAQoarkuZb4IhflQAAAgYGAg AAAQABAPwBPABXAFIATQBIAEUAQQBEAEUAUgAgAHgAbQBsAG4A cwA9ACIAaAB0AHQAcAA6AC8ALwBzAGMAaABlAG0AYQBzAC4AbQ BpAGMAcgBvAHMAbwBmAHQALgBjAG8AbQAvAEQAUgBNAC8AMgAw ADAANwAvADAAMwAvAFAAbABhAHkAUgBlAGEAZAB5AEgAZQBhAG QAZQByACIAIAB2AGUAcgBzAGkAbwBuAD0AIgA0AC4AMAAuADAA LgAwACIAPgA8AEQAQQBUAEEAPgA8AFAAUgBPAFQARQBDAFQASQ BOAEYATwA+ADwASwBFAFkATABFAE4APgAxADYAPAAvAEsARQBZ AEwARQBOAD4APABBAEwARwBJAEQAPgBBAEUAUwBDAFQAUgA8AC 8AQQBMAEcASQBEAD4APAAvAFAAUgBPAFQARQBDAFQASQBOAEYA TwA+ADwASwBJAEQAPgBvAGUATAA0AGcAcQB4ADkAdwBFAFMAaA BqADIAWQBFAGUAVABTAGMAVwBRAD0APQA8AC8ASwBJAEQAPgA8 AEMASABFAEMASwBTAFUATQA+AHAASgBMAGcAKwB2AFYAVwAxAF MAQQA9ADwALwBDAEgARQBDAEsAUwBVAE0APgA8AC8ARABBAFQA QQA+ADwALwBXAFIATQBIAEUAQQBEAEUAUgA+AA==</cenc
ssh>
<mspr
ro>BgIAAAEAAQD8ATwAVwBSAE0ASABFAEEARABFAFIAIAB4AG0 AbABuAHMAPQAiAGgAdAB0AHAAOgAvAC8AcwBjAGgAZQBtAGEAc wAuAG0AaQBjAHIAbwBzAG8AZgB0AC4AYwBvAG0ALwBEAFIATQA vADIAMAAwADcALwAwADMALwBQAGwAYQB5AFIAZQBhAGQAeQBIA GUAYQBkAGUAcgAiACAAdgBlAHIAcwBpAG8AbgA9ACIANAAuADA ALgAwAC4AMAAiAD4APABEAEEAVABBAD4APABQAFIATwBUAEUAQ wBUAEkATgBGAE8APgA8AEsARQBZAEwARQBOAD4AMQA2ADwALwB LAEUAWQBMAEUATgA+ADwAQQBMAEcASQBEAD4AQQBFAFMAQwBUA FIAPAAvAEEATABHAEkARAA+ADwALwBQAFIATwBUAEUAQwBUAEk ATgBGAE8APgA8AEsASQBEAD4AbwBlAEwANABnAHEAeAA5AHcAR QBTAGgAagAyAFkARQBlAFQAUwBjAFcAUQA9AD0APAAvAEsASQB EAD4APABDAEgARQBDAEsAUwBVAE0APgBwAEoATABnACsAdgBWA FcAMQBTAEEAPQA8AC8AQwBIAEUAQwBLAFMAVQBNAD4APAAvAEQ AQQBUAEEAPgA8AC8AVwBSAE0ASABFAEEARABFAFIAPgA=</mspr
ro>
<Role schemeIdUri="urn:mpeg:dash:role:2011" value="main"/>
<SegmentTemplate timescale="180000" initialization="$RepresentationID$/init.cmfv" media="$RepresentationID$/D$Time$.cmfv" presentationTimeOffset="0">
<SegmentTimeline>
<S t="306930483532800" d="345600" r="29"/>
</SegmentTimeline>
</SegmentTemplate>
<Representation id="video_112kbps" bandwidth="112000" width="192" height="108" frameRate="25" sar="1:1" codecs="avc1.42001E" scanType="progressive"/>
<Representation id="video_288kbps" bandwidth="288000" width="480" height="270" frameRate="25" sar="1:1" codecs="avc1.4D001F" scanType="progressive"/>
<Representation id="video_480kbps" bandwidth="480000" width="640" height="360" frameRate="25" sar="1:1" codecs="avc1.4D001F" scanType="progressive"/>
<Representation id="video_840kbps" bandwidth="840000" width="960" height="540" frameRate="25" sar="1:1" codecs="avc1.4D001F" scanType="progressive"/>
<Representation id="video_1500kbps" bandwidth="1500000" width="960" height="540" frameRate="25" sar="1:1" codecs="avc1.4D001F" scanType="progressive"/>
<Representation id="video_2300kbps" bandwidth="2300000" width="1280" height="720" frameRate="25" sar="1:1" codecs="avc1.4D001F" scanType="progressive"/>
<Representation id="video_3000kbps" bandwidth="3000000" width="1280" height="720" frameRate="25" sar="1:1" codecs="avc1.4D001F" scanType="progressive"/>
<Representation id="video_4400kbps" bandwidth="4400000" width="1280" height="720" frameRate="50" sar="1:1" codecs="avc1.640020" scanType="progressive"/>
<Representation id="video_6500kbps" bandwidth="6500000" width="1280" height="720" frameRate="50" sar="1:1" codecs="avc1.640020" scanType="progressive"/>
<Representation id="video_8000kbps" bandwidth="8000000" width="1920" height="1080" frameRate="50" sar="1:1" codecs="avc1.64002A" scanType="progressive"/>
</AdaptationSet>
<AdaptationSet id="2" contentType="audio" lang="und" mimeType="audio/mp4" segmentAlignment="true" startWithSAP="1">
<cenc
ssh>
<cenc
ssh>
<mspr
ro>
<Label>Portuguese</Label>
<SegmentTemplate timescale="48000" initialization="$RepresentationID$/init.cmfa" media="$RepresentationID$/D$Time$.cmfa" presentationTimeOffset="0">
<SegmentTimeline>
<S t="81848128943104" d="92160" r="29"/>
</SegmentTimeline>
</SegmentTemplate>
<Representation id="audio_64kbps" bandwidth="64000" codecs="mp4a.40.2" audioSamplingRate="48000">
<AudioChannelConfiguration schemeIdUri="urn:mpeg:dash:23003:3:audio_channel_c onfiguration:2011" value="2"/>
</Representation>
<Representation id="audio_128kbps" bandwidth="128000" codecs="mp4a.40.2" audioSamplingRate="48000">
</Representation>
</AdaptationSet>
</Period>
<UTCTiming schemeIdUri="urn:mpeg:dash:utc:http-iso:2014" value="https://time.akamai.com/?iso"/>
</MPD> -
Noticed this myself with My5 too.
freevine.py get --episode S12E02 https://www.channel5.com/show/ben-fogle-new-lives-in-the-wild/ --no-cache -i
vs
freevine.py get --episode S12E03 https://www.channel5.com/show/ben-fogle-new-lives-in-the-wild/ --no-cache -i
E02 only goes up to 468p, E03 has 1080p like the other episodes. -
It does look like 1080p simply isn't available for some titles. I could understand if entire shows or seasons were in SD, but for random episodes in the middle is pretty strange. Maybe just a mistake on their part when upgrading their library this past year, who knows.
I get this:
Code:❯_freevine v1.1.3 13:06:23.062 [4m[32mINFO[0m : [1mMy5 TV[0m 13:06:23.444 [4m[32mINFO[0m : Ben Fogle: New Lives in the Wild: 14 Season(s), 89 Episode(s) 13:06:24.067 [4m[32mINFO[0m : Ben Fogle: New Lives in the Wild S12E02 Georgia 13:06:24.067 [4m[32mINFO[0m : 29e8660ec1cd4bde80f9cf4d32a2886a:85dcdcd1ca6b4245ccc3d47963afa3f9 13:06:24.067 [4m[32mINFO[0m : ebaf380829fd974de29bc0b7e3c9ac8a:85dcdcd1ca6b4245ccc3d47963afa3f9 13:06:24.412 INFO : N_m3u8DL-RE (Beta version) 20230628 13:06:24.423 INFO : Loading URL: https://akadash0.akamaized.net/hydra/C5255100002/C5255100002A/20230123151616/C5255100002.mpd 13:06:24.514 INFO : Content Matched: Dynamic Adaptive Streaming over HTTP 13:06:24.515 INFO : Parsing streams... 13:06:24.516 INFO : Extracted, there are 12 streams, with 9 basic streams, 2 audio streams, 1 subtitle streams 13:06:24.517 INFO : Vid *CENC 1920x1080 | 6000 Kbps | 1 | 25 | avc1.4d4028 | 1 Segment | ~45m00s 13:06:24.517 INFO : Vid *CENC 1280x720 | 4500 Kbps | 2 | 25 | avc1.4d401f | 1 Segment | ~45m00s 13:06:24.517 INFO : Vid *CENC 1280x720 | 2800 Kbps | 3 | 25 | avc1.4d401f | 1 Segment | ~45m00s 13:06:24.518 INFO : Vid *CENC 832x468 | 1500 Kbps | 4 | 25 | avc1.4d401e | 1 Segment | ~45m00s 13:06:24.518 INFO : Vid *CENC 640x360 | 1200 Kbps | 5 | 25 | avc1.4d401e | 1 Segment | ~45m00s 13:06:24.518 INFO : Vid *CENC 640x360 | 800 Kbps | 6 | 25 | avc1.4d401e | 1 Segment | ~45m00s 13:06:24.519 INFO : Vid *CENC 640x360 | 480 Kbps | 7 | 25 | avc1.4d401e | 1 Segment | ~45m00s 13:06:24.519 INFO : Vid *CENC 640x360 | 360 Kbps | 8 | 25 | avc1.4d401e | 1 Segment | ~45m00s 13:06:24.519 INFO : Vid *CENC 320x180 | 160 Kbps | 9 | 25 | avc1.4d400c | 1 Segment | ~45m00s 13:06:24.519 INFO : Aud *CENC 10 | 96 Kbps | mp4a.40.2 | en | 2CH | 1 Segment | ~45m00s 13:06:24.520 INFO : Aud *CENC 11 | 32 Kbps | mp4a.40.5 | en | 1CH | 1 Segment | ~45m00s 13:06:24.520 INFO : Sub 12 | en | 1 Segment | ~45m00s 13:06:24.520 INFO : Parsing streams... 13:06:24.521 INFO : Selected streams: 13:06:24.521 INFO : Vid *CENC 1920x1080 | 6000 Kbps | 1 | 25 | avc1.4d4028 | 1 Segment | ~45m00s 13:06:24.521 INFO : Aud *CENC 10 | 96 Kbps | mp4a.40.2 | en | 2CH | 1 Segment | ~45m00s 13:06:24.522 INFO : Sub 12 | en | 1 Segment | ~45m00s
I get the same as you for episode 3 - no 1080p stream.
I've also had it for the odd show and just downloaded a lower resolution. It does seem to be an odd episode which is a bit strange but I guess whoever uploaded it made a mistake.
Just a note as well - thank you so much for this Stabbedbybrick it is such a great tool and easy to use. The support is so good as well.
I've never found out how to actually merge updates with git on windows and thanks to this tool I finally know how it works and it makes it so easy to keep up to date. GitHub desktop is really easy to use.
Thanks again. -
UK Free to Air Downloader
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 654Last Post: 28th Oct 2025, 05:34 -
Video/Screenshot Guide to Freevine/N_m3u8DL-RE downloader for MacOS
By gwilliams1996 in forum Video Streaming DownloadingReplies: 16Last Post: 15th May 2024, 07:14 -
Forcing quality on streaming services
By qnufc in forum Video Streaming DownloadingReplies: 10Last Post: 8th Mar 2024, 18:27 -
Are we going to see all streaming services switching to L1 completely
By Loryanam2 in forum Video Streaming DownloadingReplies: 7Last Post: 5th Mar 2023, 08:37 -
Portable Streaming DownLoader for XMovies8?
By KermitJ in forum Video Streaming DownloadingReplies: 0Last Post: 27th Sep 2019, 11:44
