Results 571 to 600 of 1613
Anyone else having issues with Pluto through a VPN? I have tried Surfshark (which can be quite crap, their servers often get busted by services which use VPN detection) and NordVPN (which I thought was a high quality service). I can download one episode of a show well, but when the next episode download starts my internet disconnects. So between episode downloads I have to kill the VPN, reconnect my internet and turn the VPN on again, which is a chore.
There is a possibility it's an issue with my router, but I thought I'd ask here in case it's something to do with a VPN or Pluto or something freevine-related.
Although BBC iPlayer, for example, is working like a charm for now with get_iplayer, multiple downoads without having to restart, and I usually can't DL anything from iP using Surfshark. -
@ampersand:
A VPN/geo block, or some kind of rate limit, on Pluto would just give you a 400 status response. If your entire connection gets killed, that points to another kind of issue. I guess you could try experimenting with lowering the --threads (default is 16) and see if makes any difference. I'm not sure why it would, but it's the only freevine-related setting I can think of that affects the network.
I just tested a few shows by downloading a handful of episodes in a row from each and didn't experience any issues. -
I see you changed commands.py
toCode:console.print(f"\n❯_ 𝕗𝕣𝕖𝕖𝕧𝕚𝕟𝕖 {__version__}\n")That still gave me the issue I had in my command window. Anyway it can be overcome by me commenting out that line but the strange thing is now the --titles results will not display in the window. All other functions work and display just fine.Code:click.echo(f"\n❯_ 𝕗𝕣𝕖𝕖𝕧𝕚𝕟𝕖 {__version__}\n")
I know it's not your problem to solve, but any pointers as to why you think that could be so ? -
Yeah I tried that originally but given the line is commented out doesn't make any difference anyway. I might end up just switching back to an external command window so your script(s) just work straight OOTB. I can still make the GUI useful for people scared (or lazy) of the CLI anyway
Just gotta figure out how to reuse the same external window each time, so it's more user friendly. -
Thank you for the upgrade! I've got it installed and working and been testing a few URLs and randomly this one doesn't want to download for some reason: https://www.channel4.com/programmes/a-place-in-the-sun/on-demand/72017-092 weird error:
[Attachment 75713 - Click to enlarge]
Edit: Aha my fault it's a SmartDNS issue apparently...Last edited by Grimbarian; 24th Dec 2023 at 04:36.
Hi Chaps,...
Could someone help me out please,... I'm trying to download the 1st season of top gear from the beeb.
And I'm at a loss as to what is the correct call request.
This seems to be the link for the first season:
https://www.bbc.co.uk/iplayer/episodes/b006mj59/top-gear?seriesId=p00whzyg
my first attempt was (obvious only to me)
C:\freevine-1.0.0>freevine.py --season https://www.bbc.co.uk/iplayer/episodes/b006mj59/top-gear?seriesId=p00whzyg
unfortunately this failed.
I know it has to be --season but what would one add next?? (I'm not after the whole series, I'm lacking in HD space to do that). -
You want 1 episode
Freevine.py -e s01e01 https://www.bbc.co.uk/iplayer/episodes/b006mj59
Or just 1 season
-s s01 -
I think I've sussed it iamghost....
first i used C:\freevine-1.0.0>freevine.py -t https://www.bbc.co.uk/iplayer/episodes/b006mj59/
to see the insane number of files available...
I then used C:\freevine-1.0.0>freevine.py -s01 https://www.bbc.co.uk/iplayer/episodes/b006mj59/
but this only downloaded E01 in 4 different variations... a 1080p that was just over 4gb... then it downloaded a 396p version of the same file...
it's still downloading, but E02 is only 396p so is E03.....
So It looks like the above command produced a 1080p of E01 then all the others are 396p.
edit:
Well i requested only S01 - but it's still going, and now it's jumped to S02E01 and now it's jumped to S03E01 and now to S04E01....
this is bananas.
I've checked the download folder, and I have the following
Season 01
Season 02
Season 03 ect, ect,
Inside Season 01 folder I have
Top.Gear.S01E01.396p.iP.WEB-DL.AAC2.0.H.264.mkv
to
Top.Gear.S01E10.396p.iP.WEB-DL.AAC2.0.H.264.mkv 10 files.
Season 02 folder only has Top.Gear.S02E01.396p.iP.WEB-DL.AAC2.0.H.264.mkv
Season 03 folder Top.Gear.S03E01.396p.iP.WEB-DL.AAC2.0.H.264.mkv all of the next folders only have 1 file in them.Last edited by LastResort; 24th Dec 2023 at 11:31.
Chaps,...
I wanted to see what is actually available for S01E01
https://www.bbc.co.uk/iplayer/episode/p00yzpg2/top-gear-series-1-episode-1
this is what came back...
[Attachment 75724 - Click to enlarge] -
I can understand your reasoning for upgrading,... but if everything is working there's no need to break it.
as you can see from another prog from the beeb, info is available...
[Attachment 75725 - Click to enlarge]
Looks like it's only top gear that's causing the problem. -
What I get from 1.10:
Code:python3 freevine.py get -i -e https://www.bbc.co.uk/iplayer/episode/p00yzpg2/top-gear-series-1-episode-1 ❯_ 𝕗𝕣𝕖𝕖𝕧𝕚𝕟𝕖 v1.1.0 17:13:20.779 INFO : BBC iPlayer 17:13:21.548 INFO : Top Gear S01E01 17:13:21.548 INFO : Filename: Top.Gear.S01E01.540p.iP.WEB-DL.AAC2.0.H.264 17:13:21.548 INFO : Subtitles: Yes 17:13:21.672 INFO : N_m3u8DL-RE (Beta version) 20230628 17:13:21.697 INFO : Loading URL: http://vod-hls-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_sd/f56ce9-p00yzpg3/vf_p00yzpg3_302f38d5-c7a1-4658-912f-66f148fb91f8.ism/hls/master.m3u8 17:13:21.729 INFO : Content Matched: HTTP Live Streaming 17:13:21.729 INFO : Parsing streams... 17:13:21.729 WARN : Master List detected, try parse all streams 17:13:21.734 INFO : Extracted, there are 9 streams, with 9 basic streams, 0 audio streams, 0 subtitle streams 17:13:21.734 INFO : Vid 960x540 | 1836 Kbps | 50 | mp4a.40.2 17:13:21.734 INFO : Vid 704x396 | 1800 Kbps | 50 | mp4a.40.2 17:13:21.734 INFO : Vid 704x396 | 1013 Kbps | 25 | mp4a.40.2 17:13:21.734 INFO : Vid 640x360 | 865 Kbps | 25 | mp4a.40.2 17:13:21.734 INFO : Vid 512x288 | 599 Kbps | 25 | mp4a.40.2 17:13:21.734 INFO : Vid 448x252 | 598 Kbps | 25 | mp4a.40.2 17:13:21.735 INFO : Vid 384x216 | 434 Kbps | 25 | mp4a.40.2 17:13:21.735 INFO : Vid 256x144 | 268 Kbps | 25 | mp4a.40.5 17:13:21.735 INFO : Vid 192x108 | 143 Kbps | 25 | mp4a.40.5 17:13:21.735 INFO : Parsing streams... 17:13:21.757 INFO : Selected streams: 17:13:21.757 INFO : Vid 960x540 | 1836 Kbps | 50 | mp4a.40.2 | 461 Segments | ~58m58s
Among other things in release notes from 1.10:
So, y'know...[iPlayer] Improve search for available versions and add status checks before committing to download -
Yes,... I've already read what 1.10 does.... I noticed that Get_Iplayer will pull down SD 540p.... Just cant work out why freevine will only pull 360p and not 540p. (I'm just having a "dog with a bone" time). Can't let it get the better of me. But thanks for your input pelago. Have a great xmas.
vinetrimmer showing 540p max
Code:2023-12-24 23:02:58 [I] download : + 1 Local Vaults 2023-12-24 23:02:58 [I] download : + 0 Remote Vaults 2023-12-24 23:02:59 [I] download : + Loaded LocalDevice: 4464 (L3) 2023-12-24 23:02:59 [I] iP : Creating a Python-requests Session 2023-12-24 23:02:59 [I] iP : + Set Common Headers 2023-12-24 23:02:59 [I] iP : + Set Cookies 2023-12-24 23:02:59 [I] iP : Obtaining a proxy to "gb" 2023-12-24 23:02:59 [I] iP : + Proxy was skipped as current region matches 2023-12-24 23:02:59 [I] iP : + Loaded [BBCiPlayer] Class instance 2023-12-24 23:02:59 [I] iP : Retrieving Titles 2023-12-24 23:03:01 [I] Titles : Title: Top Gear 2023-12-24 23:03:01 [I] Titles : Total Episodes: 261 2023-12-24 23:03:01 [I] Titles : By Season: 0 (26), 1 (10), 2 (10), 3 (10), 4 (10), 5 (9), 6 (11), 7 (7), 8 (9), 9 (7), 10 (10), 11 (6), 12 (8), 13 (7), 14 (7), 15 (7), 16 (6), 17 (6), 18 (7), 19 (7), 20 (6), 21 (7), 22 (9), 23 (6), 24 (7), 25 (6), 26 (5), 27 (5), 28 (6), 29 (5), 30 (4), 31 (5), 32 (5), 33 (5) 2023-12-24 23:03:01 [I] iP : Getting tracks for Top Gear S01E01 - Episode 1 2023-12-24 23:03:02 [I] iP : > All Tracks: 2023-12-24 23:03:02 [I] Tracks : 9 Video Tracks: 2023-12-24 23:03:02 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:02 [I] Tracks : VID | [avc1.64001F, SDR] | en | 704x396 @ 1570 kb/s, 50.000 FPS 2023-12-24 23:03:02 [I] Tracks : VID | [avc1.4D401F, SDR] | en | 704x396 @ 827 kb/s, 25.000 FPS 2023-12-24 23:03:02 [I] Tracks : VID | [avc1.42C01E, SDR] | en | 640x360 @ 688 kb/s, 25.000 FPS 2023-12-24 23:03:02 [I] Tracks : VID | [avc1.4D4015, SDR] | en | 512x288 @ 437 kb/s, 25.000 FPS 2023-12-24 23:03:02 [I] Tracks : VID | [avc1.42C015, SDR] | en | 448x252 @ 436 kb/s, 25.000 FPS 2023-12-24 23:03:02 [I] Tracks : VID | [avc1.42C015, SDR] | en | 384x216 @ 281 kb/s, 25.000 FPS 2023-12-24 23:03:02 [I] Tracks : VID | [avc1.42C015, SDR] | en | 256x144 @ 156 kb/s, 25.000 FPS 2023-12-24 23:03:02 [I] Tracks : VID | [avc1.42C015, SDR] | en | 192x108 @ 86 kb/s, 25.000 FPS 2023-12-24 23:03:02 [I] Tracks : 3 Audio Tracks: 2023-12-24 23:03:02 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:02 [I] Tracks : AUD | [mp4a.40.5] | 96 kb/s | en 2023-12-24 23:03:02 [I] Tracks : AUD | [mp4a.40.5] | 48 kb/s | en 2023-12-24 23:03:02 [I] Tracks : 1 Text Track: 2023-12-24 23:03:02 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:02 [I] iP : > Selected Tracks: 2023-12-24 23:03:02 [I] Tracks : 1 Video Track: 2023-12-24 23:03:02 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:02 [I] Tracks : 1 Audio Track: 2023-12-24 23:03:02 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:02 [I] Tracks : 1 Text Track: 2023-12-24 23:03:02 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:02 [I] iP : Getting tracks for Top Gear S01E02 - Episode 2 2023-12-24 23:03:03 [I] iP : > All Tracks: 2023-12-24 23:03:03 [I] Tracks : 9 Video Tracks: 2023-12-24 23:03:03 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:03 [I] Tracks : VID | [avc1.64001F, SDR] | en | 704x396 @ 1570 kb/s, 50.000 FPS 2023-12-24 23:03:03 [I] Tracks : VID | [avc1.4D401F, SDR] | en | 704x396 @ 827 kb/s, 25.000 FPS 2023-12-24 23:03:03 [I] Tracks : VID | [avc1.42C01E, SDR] | en | 640x360 @ 688 kb/s, 25.000 FPS 2023-12-24 23:03:03 [I] Tracks : VID | [avc1.4D4015, SDR] | en | 512x288 @ 437 kb/s, 25.000 FPS 2023-12-24 23:03:03 [I] Tracks : VID | [avc1.42C015, SDR] | en | 448x252 @ 436 kb/s, 25.000 FPS 2023-12-24 23:03:03 [I] Tracks : VID | [avc1.42C015, SDR] | en | 384x216 @ 281 kb/s, 25.000 FPS 2023-12-24 23:03:03 [I] Tracks : VID | [avc1.42C015, SDR] | en | 256x144 @ 156 kb/s, 25.000 FPS 2023-12-24 23:03:03 [I] Tracks : VID | [avc1.42C015, SDR] | en | 192x108 @ 86 kb/s, 25.000 FPS 2023-12-24 23:03:03 [I] Tracks : 3 Audio Tracks: 2023-12-24 23:03:03 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:03 [I] Tracks : AUD | [mp4a.40.5] | 96 kb/s | en 2023-12-24 23:03:03 [I] Tracks : AUD | [mp4a.40.5] | 48 kb/s | en 2023-12-24 23:03:03 [I] Tracks : 1 Text Track: 2023-12-24 23:03:03 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:03 [I] iP : > Selected Tracks: 2023-12-24 23:03:03 [I] Tracks : 1 Video Track: 2023-12-24 23:03:03 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:03 [I] Tracks : 1 Audio Track: 2023-12-24 23:03:03 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:03 [I] Tracks : 1 Text Track: 2023-12-24 23:03:03 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:03 [I] iP : Getting tracks for Top Gear S01E03 - Episode 3 2023-12-24 23:03:04 [I] iP : > All Tracks: 2023-12-24 23:03:04 [I] Tracks : 9 Video Tracks: 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.64001F, SDR] | en | 704x396 @ 1570 kb/s, 50.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.4D401F, SDR] | en | 704x396 @ 827 kb/s, 25.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.42C01E, SDR] | en | 640x360 @ 688 kb/s, 25.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.4D4015, SDR] | en | 512x288 @ 437 kb/s, 25.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.42C015, SDR] | en | 448x252 @ 436 kb/s, 25.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.42C015, SDR] | en | 384x216 @ 281 kb/s, 25.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.42C015, SDR] | en | 256x144 @ 156 kb/s, 25.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.42C015, SDR] | en | 192x108 @ 86 kb/s, 25.000 FPS 2023-12-24 23:03:04 [I] Tracks : 3 Audio Tracks: 2023-12-24 23:03:04 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:04 [I] Tracks : AUD | [mp4a.40.5] | 96 kb/s | en 2023-12-24 23:03:04 [I] Tracks : AUD | [mp4a.40.5] | 48 kb/s | en 2023-12-24 23:03:04 [I] Tracks : 1 Text Track: 2023-12-24 23:03:04 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:04 [I] iP : > Selected Tracks: 2023-12-24 23:03:04 [I] Tracks : 1 Video Track: 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:04 [I] Tracks : 1 Audio Track: 2023-12-24 23:03:04 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:04 [I] Tracks : 1 Text Track: 2023-12-24 23:03:04 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:04 [I] iP : Getting tracks for Top Gear S01E04 - Episode 4 2023-12-24 23:03:04 [I] iP : > All Tracks: 2023-12-24 23:03:04 [I] Tracks : 9 Video Tracks: 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.64001F, SDR] | en | 704x396 @ 1570 kb/s, 50.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.4D401F, SDR] | en | 704x396 @ 827 kb/s, 25.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.42C01E, SDR] | en | 640x360 @ 688 kb/s, 25.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.4D4015, SDR] | en | 512x288 @ 437 kb/s, 25.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.42C015, SDR] | en | 448x252 @ 436 kb/s, 25.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.42C015, SDR] | en | 384x216 @ 281 kb/s, 25.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.42C015, SDR] | en | 256x144 @ 156 kb/s, 25.000 FPS 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.42C015, SDR] | en | 192x108 @ 86 kb/s, 25.000 FPS 2023-12-24 23:03:04 [I] Tracks : 3 Audio Tracks: 2023-12-24 23:03:04 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:04 [I] Tracks : AUD | [mp4a.40.5] | 96 kb/s | en 2023-12-24 23:03:04 [I] Tracks : AUD | [mp4a.40.5] | 48 kb/s | en 2023-12-24 23:03:04 [I] Tracks : 1 Text Track: 2023-12-24 23:03:04 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:04 [I] iP : > Selected Tracks: 2023-12-24 23:03:04 [I] Tracks : 1 Video Track: 2023-12-24 23:03:04 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:04 [I] Tracks : 1 Audio Track: 2023-12-24 23:03:04 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:04 [I] Tracks : 1 Text Track: 2023-12-24 23:03:04 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:04 [I] iP : Getting tracks for Top Gear S01E05 - Episode 5 2023-12-24 23:03:05 [I] iP : > All Tracks: 2023-12-24 23:03:05 [I] Tracks : 9 Video Tracks: 2023-12-24 23:03:05 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:05 [I] Tracks : VID | [avc1.64001F, SDR] | en | 704x396 @ 1570 kb/s, 50.000 FPS 2023-12-24 23:03:05 [I] Tracks : VID | [avc1.4D401F, SDR] | en | 704x396 @ 827 kb/s, 25.000 FPS 2023-12-24 23:03:05 [I] Tracks : VID | [avc1.42C01E, SDR] | en | 640x360 @ 688 kb/s, 25.000 FPS 2023-12-24 23:03:05 [I] Tracks : VID | [avc1.4D4015, SDR] | en | 512x288 @ 437 kb/s, 25.000 FPS 2023-12-24 23:03:05 [I] Tracks : VID | [avc1.42C015, SDR] | en | 448x252 @ 436 kb/s, 25.000 FPS 2023-12-24 23:03:05 [I] Tracks : VID | [avc1.42C015, SDR] | en | 384x216 @ 281 kb/s, 25.000 FPS 2023-12-24 23:03:05 [I] Tracks : VID | [avc1.42C015, SDR] | en | 256x144 @ 156 kb/s, 25.000 FPS 2023-12-24 23:03:05 [I] Tracks : VID | [avc1.42C015, SDR] | en | 192x108 @ 86 kb/s, 25.000 FPS 2023-12-24 23:03:05 [I] Tracks : 3 Audio Tracks: 2023-12-24 23:03:05 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:05 [I] Tracks : AUD | [mp4a.40.5] | 96 kb/s | en 2023-12-24 23:03:05 [I] Tracks : AUD | [mp4a.40.5] | 48 kb/s | en 2023-12-24 23:03:05 [I] Tracks : 1 Text Track: 2023-12-24 23:03:05 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:05 [I] iP : > Selected Tracks: 2023-12-24 23:03:05 [I] Tracks : 1 Video Track: 2023-12-24 23:03:05 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:05 [I] Tracks : 1 Audio Track: 2023-12-24 23:03:05 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:05 [I] Tracks : 1 Text Track: 2023-12-24 23:03:05 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:05 [I] iP : Getting tracks for Top Gear S01E06 - Episode 6 2023-12-24 23:03:06 [I] iP : > All Tracks: 2023-12-24 23:03:06 [I] Tracks : 9 Video Tracks: 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.64001F, SDR] | en | 704x396 @ 1570 kb/s, 50.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.4D401F, SDR] | en | 704x396 @ 827 kb/s, 25.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.42C01E, SDR] | en | 640x360 @ 688 kb/s, 25.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.4D4015, SDR] | en | 512x288 @ 437 kb/s, 25.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.42C015, SDR] | en | 448x252 @ 436 kb/s, 25.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.42C015, SDR] | en | 384x216 @ 281 kb/s, 25.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.42C015, SDR] | en | 256x144 @ 156 kb/s, 25.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.42C015, SDR] | en | 192x108 @ 86 kb/s, 25.000 FPS 2023-12-24 23:03:06 [I] Tracks : 3 Audio Tracks: 2023-12-24 23:03:06 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:06 [I] Tracks : AUD | [mp4a.40.5] | 96 kb/s | en 2023-12-24 23:03:06 [I] Tracks : AUD | [mp4a.40.5] | 48 kb/s | en 2023-12-24 23:03:06 [I] Tracks : 1 Text Track: 2023-12-24 23:03:06 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:06 [I] iP : > Selected Tracks: 2023-12-24 23:03:06 [I] Tracks : 1 Video Track: 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:06 [I] Tracks : 1 Audio Track: 2023-12-24 23:03:06 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:06 [I] Tracks : 1 Text Track: 2023-12-24 23:03:06 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:06 [I] iP : Getting tracks for Top Gear S01E07 - Episode 7 2023-12-24 23:03:06 [I] iP : > All Tracks: 2023-12-24 23:03:06 [I] Tracks : 9 Video Tracks: 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.64001F, SDR] | en | 704x396 @ 1570 kb/s, 50.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.4D401F, SDR] | en | 704x396 @ 827 kb/s, 25.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.42C01E, SDR] | en | 640x360 @ 688 kb/s, 25.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.4D4015, SDR] | en | 512x288 @ 437 kb/s, 25.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.42C015, SDR] | en | 448x252 @ 436 kb/s, 25.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.42C015, SDR] | en | 384x216 @ 281 kb/s, 25.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.42C015, SDR] | en | 256x144 @ 156 kb/s, 25.000 FPS 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.42C015, SDR] | en | 192x108 @ 86 kb/s, 25.000 FPS 2023-12-24 23:03:06 [I] Tracks : 3 Audio Tracks: 2023-12-24 23:03:06 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:06 [I] Tracks : AUD | [mp4a.40.5] | 96 kb/s | en 2023-12-24 23:03:06 [I] Tracks : AUD | [mp4a.40.5] | 48 kb/s | en 2023-12-24 23:03:06 [I] Tracks : 1 Text Track: 2023-12-24 23:03:06 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:06 [I] iP : > Selected Tracks: 2023-12-24 23:03:06 [I] Tracks : 1 Video Track: 2023-12-24 23:03:06 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:06 [I] Tracks : 1 Audio Track: 2023-12-24 23:03:06 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:06 [I] Tracks : 1 Text Track: 2023-12-24 23:03:06 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:06 [I] iP : Getting tracks for Top Gear S01E08 - Episode 8 2023-12-24 23:03:07 [I] iP : > All Tracks: 2023-12-24 23:03:07 [I] Tracks : 9 Video Tracks: 2023-12-24 23:03:07 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:07 [I] Tracks : VID | [avc1.64001F, SDR] | en | 704x396 @ 1570 kb/s, 50.000 FPS 2023-12-24 23:03:07 [I] Tracks : VID | [avc1.4D401F, SDR] | en | 704x396 @ 827 kb/s, 25.000 FPS 2023-12-24 23:03:07 [I] Tracks : VID | [avc1.42C01E, SDR] | en | 640x360 @ 688 kb/s, 25.000 FPS 2023-12-24 23:03:07 [I] Tracks : VID | [avc1.4D4015, SDR] | en | 512x288 @ 437 kb/s, 25.000 FPS 2023-12-24 23:03:07 [I] Tracks : VID | [avc1.42C015, SDR] | en | 448x252 @ 436 kb/s, 25.000 FPS 2023-12-24 23:03:07 [I] Tracks : VID | [avc1.42C015, SDR] | en | 384x216 @ 281 kb/s, 25.000 FPS 2023-12-24 23:03:07 [I] Tracks : VID | [avc1.42C015, SDR] | en | 256x144 @ 156 kb/s, 25.000 FPS 2023-12-24 23:03:07 [I] Tracks : VID | [avc1.42C015, SDR] | en | 192x108 @ 86 kb/s, 25.000 FPS 2023-12-24 23:03:07 [I] Tracks : 3 Audio Tracks: 2023-12-24 23:03:07 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:07 [I] Tracks : AUD | [mp4a.40.5] | 96 kb/s | en 2023-12-24 23:03:07 [I] Tracks : AUD | [mp4a.40.5] | 48 kb/s | en 2023-12-24 23:03:07 [I] Tracks : 1 Text Track: 2023-12-24 23:03:07 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:07 [I] iP : > Selected Tracks: 2023-12-24 23:03:07 [I] Tracks : 1 Video Track: 2023-12-24 23:03:07 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:07 [I] Tracks : 1 Audio Track: 2023-12-24 23:03:07 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:07 [I] Tracks : 1 Text Track: 2023-12-24 23:03:07 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:07 [I] iP : Getting tracks for Top Gear S01E09 - Episode 9 2023-12-24 23:03:08 [I] iP : > All Tracks: 2023-12-24 23:03:08 [I] Tracks : 9 Video Tracks: 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.64001F, SDR] | en | 704x396 @ 1570 kb/s, 50.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.4D401F, SDR] | en | 704x396 @ 827 kb/s, 25.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.42C01E, SDR] | en | 640x360 @ 688 kb/s, 25.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.4D4015, SDR] | en | 512x288 @ 437 kb/s, 25.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.42C015, SDR] | en | 448x252 @ 436 kb/s, 25.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.42C015, SDR] | en | 384x216 @ 281 kb/s, 25.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.42C015, SDR] | en | 256x144 @ 156 kb/s, 25.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.42C015, SDR] | en | 192x108 @ 86 kb/s, 25.000 FPS 2023-12-24 23:03:08 [I] Tracks : 3 Audio Tracks: 2023-12-24 23:03:08 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:08 [I] Tracks : AUD | [mp4a.40.5] | 96 kb/s | en 2023-12-24 23:03:08 [I] Tracks : AUD | [mp4a.40.5] | 48 kb/s | en 2023-12-24 23:03:08 [I] Tracks : 1 Text Track: 2023-12-24 23:03:08 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:08 [I] iP : > Selected Tracks: 2023-12-24 23:03:08 [I] Tracks : 1 Video Track: 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:08 [I] Tracks : 1 Audio Track: 2023-12-24 23:03:08 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:08 [I] Tracks : 1 Text Track: 2023-12-24 23:03:08 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:08 [I] iP : Getting tracks for Top Gear S01E10 - Episode 10 2023-12-24 23:03:08 [I] iP : > All Tracks: 2023-12-24 23:03:08 [I] Tracks : 9 Video Tracks: 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.64001F, SDR] | en | 704x396 @ 1570 kb/s, 50.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.4D401F, SDR] | en | 704x396 @ 827 kb/s, 25.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.42C01E, SDR] | en | 640x360 @ 688 kb/s, 25.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.4D4015, SDR] | en | 512x288 @ 437 kb/s, 25.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.42C015, SDR] | en | 448x252 @ 436 kb/s, 25.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.42C015, SDR] | en | 384x216 @ 281 kb/s, 25.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.42C015, SDR] | en | 256x144 @ 156 kb/s, 25.000 FPS 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.42C015, SDR] | en | 192x108 @ 86 kb/s, 25.000 FPS 2023-12-24 23:03:08 [I] Tracks : 3 Audio Tracks: 2023-12-24 23:03:08 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:08 [I] Tracks : AUD | [mp4a.40.5] | 96 kb/s | en 2023-12-24 23:03:08 [I] Tracks : AUD | [mp4a.40.5] | 48 kb/s | en 2023-12-24 23:03:08 [I] Tracks : 1 Text Track: 2023-12-24 23:03:08 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:08 [I] iP : > Selected Tracks: 2023-12-24 23:03:08 [I] Tracks : 1 Video Track: 2023-12-24 23:03:08 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS 2023-12-24 23:03:08 [I] Tracks : 1 Audio Track: 2023-12-24 23:03:08 [I] Tracks : AUD | [mp4a.40.2] | 128 kb/s | en 2023-12-24 23:03:08 [I] Tracks : 1 Text Track: 2023-12-24 23:03:08 [I] Tracks : SUB | [ttml] | en-GB | United Kingdom (SDH) 2023-12-24 23:03:08 [I] iP : Processed all titles!
Merryxmas all!
Any ideas on STV errors constant init failed and 403 response errors. Even tohugh I created an account and even though using a SmartDNS linked to scotland.
"13:09:12.229 WARN : Response status code does not indicate success: 403 (Forbidden).
13:09:12.235 ERROR: Download init file failed!
(venv) C:\freevine-1.0.6>"
even browser struggles to play them, just spins a cog for ages then errors...
Cheers!
Edit: Fixed, was indeed IP issueLast edited by SE14man; 24th Dec 2023 at 22:35.
I'm Having a small problem with stv.....
Not had this before,... and I get the same error using either 1.06 or the latest version. I also have set a username and password for stv. and the programme plays within chrome browser.
C:\freevine-1.1.0>freevine.py get -i -e https://player.stv.tv/episode/4j9p/the-1-club
❯_ v1.1.0
10:40:23.927 ←[4m←[32mINFO←[0m : ←[1mSTV Player←[0m
10:40:23.927 ←[4m←[32mINFO←[0m : + Loading user profile
File "C:\freevine-1.1.0\freevine.py", line 17, in <module>
cli()
File "C:\Users\xxxxxxxxxx\AppData\Local\Programs\Python \Python311\Lib\site-packages\click\core.py", line 1157, in __call__
return self.main(*args, **kwargs)
File "C:\Users\xxxxxxxxxx\AppData\Local\Programs\Python \Python311\Lib\site-packages\click\core.py", line 1078, in main
rv = self.invoke(ctx)
File "C:\Users\xxxxxxxxxx\AppData\Local\Programs\Python \Python311\Lib\site-packages\click\core.py", line 1688, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "C:\Users\xxxxxxxxxx\AppData\Local\Programs\Python \Python311\Lib\site-packages\click\core.py", line 1434, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "C:\Users\xxxxxxxxxx\AppData\Local\Programs\Python \Python311\Lib\site-packages\click\core.py", line 783, in invoke
return __callback(*args, **kwargs)
File "C:\freevine-1.1.0\utils\commands.py", line 77, in get
Service(config, **kwargs)
File "C:\freevine-1.1.0\services\stv\stv.py", line 43, in __init__
self.get_options()
File "C:\freevine-1.1.0\services\stv\stv.py", line 224, in get_options
downloads, title = get_downloads(self)
File "C:\freevine-1.1.0\utils\options.py", line 160, in get_downloads
downloads, title = stream.get_episode_from_url(stream.episode)
File "C:\freevine-1.1.0\services\stv\stv.py", line 206, in get_episode_from_url
season=int(content["playerSeries"]["name"].split(" ")[1])
ValueError: invalid literal for int() with base 10: 'Episodes'
C:\freevine-1.1.0>
Side note:
I tried with a different episode from a different programme and everything works okay.
C:\freevine-1.1.0>freevine.py get -i -e https://player.stv.tv/episode/46rz/the-tower
❯_ v1.1.0
10:45:06.877 ←[4m←[32mINFO←[0m : ←[1mSTV Player←[0m
10:45:06.879 ←[4m←[32mINFO←[0m : + Loading user profile
10:45:07.811 ←[4m←[32mINFO←[0m : The Tower S01E01
10:45:07.811 ←[4m←[32mINFO←[0m : No encryption found
10:45:08.556 INFO : N_m3u8DL-RE (Beta version) 20230628
10:45:08.587 INFO : Loading URL: http://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/clear/1486976045/8207b4...lkNjFiMg%3D%3D
10:45:08.619 INFO : Content Matched: Dynamic Adaptive Streaming over HTTP
10:45:08.623 INFO : Parsing streams...
10:45:08.787 INFO : Extracted, there are 9 streams, with 5 basic streams, 3 audio streams, 1 subtitle streams
10:45:08.788 INFO : Vid 1920x1080 | 3387 Kbps | 421c6669-64dc-4ba9-b24c-aeabd1f41f12 | 25 | avc1.640028 | 1402 Segments |
~46m44s
10:45:08.789 INFO : Vid 1280x720 | 1699 Kbps | 53f26320-c40c-47f5-8307-35e6e4b599b2 | 25 | avc1.4d001f | 1402 Segments |
~46m44s
10:45:08.790 INFO : Vid 1024x576 | 853 Kbps | 08d62de7-753b-4609-bd34-157f4e1fddbf | 25 | avc1.4d001f | 1402 Segments |
~46m44s
10:45:08.790 INFO : Vid 640x360 | 471 Kbps | 02289bc1-6eb7-4570-8f72-08b21494c16f | 25 | avc1.4d001e | 1402 Segments |
~46m44s
10:45:08.791 INFO : Vid 384x216 | 241 Kbps | 017bb31b-aed8-407b-a673-83951cc99d38 | 25 | avc1.42000d | 1402 Segments |
~46m44s
10:45:08.792 INFO : Aud c70f8205-8f75-4984-8c18-4d7a9b1b1adc | 127 Kbps | mp4a.40.2 | en | 1413 Segments | ~46m43s
10:45:08.792 INFO : Aud 4d85df0f-ecba-40ac-9d05-66abd18ee38c | 96 Kbps | mp4a.40.2 | en | 1413 Segments | ~46m43s
10:45:08.793 INFO : Aud 4d961ba0-6ba5-4923-bc22-8e163f268759 | 63 Kbps | mp4a.40.2 | en | 1413 Segments | ~46m43s
10:45:08.793 INFO : Sub 04d2ce34-4a78-4b40-9aed-453e4a06ef41 | en | 1 Segment | ~46m42s
10:45:08.794 INFO : Parsing streams...
10:45:08.804 INFO : Selected streams:
10:45:08.806 INFO : Vid 1920x1080 | 3387 Kbps | 421c6669-64dc-4ba9-b24c-aeabd1f41f12 | 25 | avc1.640028 | 1402 Segments |
~46m44s
10:45:08.807 INFO : Aud c70f8205-8f75-4984-8c18-4d7a9b1b1adc | 127 Kbps | mp4a.40.2 | en | 1413 Segments | ~46m43s
10:45:08.807 INFO : Sub 04d2ce34-4a78-4b40-9aed-453e4a06ef41 | en | 1 Segment | ~46m42s
C:\freevine-1.1.0>
(Is it something to do with ValueError: invalid literal for int() with base 10: 'Episodes') -
The STV issue has been fixed in the main branch.
I've also fixed Channel4 so that if it doesn't find 1080p on the android API, it switches to the web endpoint automatically. So there's no longer any need to change the client manually in the yaml file.
And I've added a new option to read commands from a text file. This is useful if you want to batch download movies or from multiple services.
Create a text file and name it whatever. Put each command on its own line:
And then use the "file" command:Code:get --movie https://www.example.com get --episode S01E01 --select-video res=720 https://www.example2.com get --season S01 https://www.example3.com
I suspect there will be some issues with these so I don't want to commit to a new full release. Feel free to test them out and report any bugs.Code:freevine.py file "path/to/file.txt"
Getting an error with any All4 download at the moment. Could my IP be banned maybe ? Not that I've grabbed much recently from them to cause that.
Code:freevine.py get --episode s25e01 https://www.channel4.com/programmes/grand-designs/on-demand/70447-007 -sv res=720:for=best
Code:❯_ 𝕗𝕣𝕖𝕖𝕧𝕚𝕟𝕖 v1.1.0 16:51:59.127 INFO : ALL4 16:51:59.128 INFO : + Loading user profile 16:52:02.483 INFO : Grand Designs: 24 Season(s), 232 Episode(s) 16:52:02.483 INFO : Cache is empty, aquiring new tokens... 16:52:02.483 INFO : Authenticating with service... Traceback (most recent call last): File "C:\Python312\Lib\site-packages\urllib3\connectionpool.py", line 467, in _make_request self._validate_conn(conn) File "C:\Python312\Lib\site-packages\urllib3\connectionpool.py", line 1096, in _validate_conn conn.connect() File "C:\Python312\Lib\site-packages\urllib3\connection.py", line 642, in connect sock_and_verified = _ssl_wrap_socket_and_match_hostname( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Python312\Lib\site-packages\urllib3\connection.py", line 782, in _ssl_wrap_socket_and_match_hostname ssl_sock = ssl_wrap_socket( ^^^^^^^^^^^^^^^^ File "C:\Python312\Lib\site-packages\urllib3\util\ssl_.py", line 470, in ssl_wrap_socket ssl_sock = _ssl_wrap_socket_impl(sock, context, tls_in_tls, server_hostname) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Python312\Lib\site-packages\urllib3\util\ssl_.py", line 514, in _ssl_wrap_socket_impl return ssl_context.wrap_socket(sock, server_hostname=server_hostname) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Python312\Lib\ssl.py", line 455, in wrap_socket return self.sslsocket_class._create( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Python312\Lib\ssl.py", line 1046, in _create self.do_handshake() File "C:\Python312\Lib\ssl.py", line 1317, in do_handshake self._sslobj.do_handshake() ssl.SSLEOFError: [SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1000) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "C:\Python312\Lib\site-packages\urllib3\connectionpool.py", line 790, in urlopen response = self._make_request( ^^^^^^^^^^^^^^^^^^^ File "C:\Python312\Lib\site-packages\urllib3\connectionpool.py", line 491, in _make_request raise new_e urllib3.exceptions.SSLError: [SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1000) The above exception was the direct cause of the following exception: Traceback (most recent call last): File "C:\Python312\Lib\site-packages\requests\adapters.py", line 486, in send resp = conn.urlopen( ^^^^^^^^^^^^^ File "C:\Python312\Lib\site-packages\urllib3\connectionpool.py", line 844, in urlopen retries = retries.increment( ^^^^^^^^^^^^^^^^^^ File "C:\Python312\Lib\site-packages\urllib3\util\retry.py", line 515, in increment raise MaxRetryError(_pool, url, reason) from reason # type: ignore[arg-type] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='api.channel4.com', port=443): Max retries exceeded with url: /online/v2/auth/token (Caused by SSLError(SSLEOFError(8, '[SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1000)'))) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "D:\Downloads\freevine-1.1.0\freevine.py", line 15, in <module> cli() File "C:\Python312\Lib\site-packages\click\core.py", line 1157, in __call__ return self.main(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Python312\Lib\site-packages\click\core.py", line 1078, in main rv = self.invoke(ctx) ^^^^^^^^^^^^^^^^ File "C:\Python312\Lib\site-packages\click\core.py", line 1688, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Python312\Lib\site-packages\click\core.py", line 1434, in invoke return ctx.invoke(self.callback, **ctx.params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Python312\Lib\site-packages\click\core.py", line 783, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "D:\Downloads\freevine-1.1.0\utils\commands.py", line 79, in get Service(config, **kwargs) File "D:\Downloads\freevine-1.1.0\services\channel4\channel4.py", line 60, in __init__ self.get_options() File "D:\Downloads\freevine-1.1.0\services\channel4\channel4.py", line 359, in get_options self.download(download, title) File "D:\Downloads\freevine-1.1.0\services\channel4\channel4.py", line 362, in download self.res, manifest, token = self.get_mediainfo(stream.id, self.quality) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "D:\Downloads\freevine-1.1.0\services\channel4\channel4.py", line 289, in get_mediainfo manifest, token = self.android_playlist(video_id) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "D:\Downloads\freevine-1.1.0\services\channel4\channel4.py", line 248, in android_playlist token = self.authenticate() ^^^^^^^^^^^^^^^^^^^ File "D:\Downloads\freevine-1.1.0\services\channel4\channel4.py", line 219, in authenticate r = self.client.post(self.login, data=data) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Python312\Lib\site-packages\requests\sessions.py", line 637, in post return self.request("POST", url, data=data, json=json, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Python312\Lib\site-packages\requests\sessions.py", line 589, in request resp = self.send(prep, **send_kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Python312\Lib\site-packages\requests\sessions.py", line 703, in send r = adapter.send(request, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Python312\Lib\site-packages\requests\adapters.py", line 517, in send raise SSLError(e, request=request) requests.exceptions.SSLError: HTTPSConnectionPool(host='api.channel4.com', port=443): Max retries exceeded with url: /online/v2/auth/token (Caused by SSLError(SSLEOFError(8, '[SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1000)'))) D:\Downloads\freevine-1.1.0> -
I was getting those too... I thought that my Channel 4 and 5 had blacklisted my DNS. I think that is the case. When I tried VPN it actually seemed to fix that issue. I think its possible CH5 and ALL4 have now blocked dns4me if thats what you're using? I tried multiple DNS servers on dns4me and still the same error. Only VPN resolved it.
Works for me with SmartDNSProxy and Getflix (they're basically sister companies). ControlD started downloading ok but then failed which isn't usual for ControlD, they don't really have the bandwidth for downloading just the handshake part is good for getting keys and MPD URLs and things like that...
UK Free to Air Downloader
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 691Last Post: 13th Nov 2025, 13:25 -
Video/Screenshot Guide to Freevine/N_m3u8DL-RE downloader for MacOS
By gwilliams1996 in forum Video Streaming DownloadingReplies: 16Last Post: 15th May 2024, 07:14 -
Forcing quality on streaming services
By qnufc in forum Video Streaming DownloadingReplies: 10Last Post: 8th Mar 2024, 18:27 -
Are we going to see all streaming services switching to L1 completely
By Loryanam2 in forum Video Streaming DownloadingReplies: 7Last Post: 5th Mar 2023, 08:37 -
Portable Streaming DownLoader for XMovies8?
By KermitJ in forum Video Streaming DownloadingReplies: 0Last Post: 27th Sep 2019, 11:44
