Hey users! I need to record a video to train an AI, my colleague has explained me that the algorithm its not very good processing variable frame rate videos and we have to train it more. I was wondering how can I record or transform a video to a frame rate variable video, you know, the ones that low quality CCTV cameras record. Thank you very much!
Well... use low quality CCTV cameras, VFR can be related to at least two basic reasons, first errors in CFR video - such errors may be related to poor software processing (software is unable to cope with high number of data in real time), second primary source is dropping frames where no scene change is detected (usually scene change threshold is set high). Buy or rent such cheap CCTV cameras, alternatively as operators for content - who knows, maybe shops, neighbors will share such footage with you.
Most phone footage IS vfr, especially if the light level is lacking. This has been discussed here a number of times.
Audio and Video sync issues with both Constant and Variable Frame Rate
By atomicBRblaster in forum Video ConversionReplies: 6Last Post: 12th Apr 2023, 14:29 -
Converting .TS with variable frame rate to .MKV
By MeltdownSpectre in forum Video ConversionReplies: 3Last Post: 4th Jun 2020, 02:11 -
Need variable frame rate ffmpeg
By Budman1 in forum Video ConversionReplies: 15Last Post: 9th Mar 2020, 05:10 -
FFmpeg is changing the frame rate to Variable when copying video?
By kkiller23 in forum Newbie / General discussionsReplies: 5Last Post: 1st Dec 2019, 13:14 -
Making a Variable Frame Rate video
By Mr. Anderssarian in forum Video ConversionReplies: 3Last Post: 1st Jan 2019, 17:17
