Has anyone used the program that is avialiable from the tools seciton on this site called Dup DVD.
I have tried the program "The full program" and it starts to read the DVD and I know from what i have read it takes a while to read and burn the DVD on a blank CD. Well it starts out ok but then it speeds up and finishes the read and burn, when u check the CD it has only read and burned about 1 min of the origrianl DVD.
Right now i am using version, 2.0.3.
If anyone has had luck with this program let me know, or if they knwo possibly why the program is doing what its doing on me?? Because i have tried everything possible to get it working.
Thanks in advance Novachemop426
Try search the forum for this issue, it has been discussed an uncountable amount of times..
Learn to use the search function.- Twin -
DUP 5990/37 - Pal & NTSC all the time?
By mraroid in forum DVD & Blu-ray PlayersReplies: 18Last Post: 12th Dec 2008, 11:56 -
Toshiba RDXS32 - High speed Dup freeze
By medare in forum DVD & Blu-ray RecordersReplies: 0Last Post: 14th Jun 2008, 12:33
