I've got an avi file that is in divx format. When I go into tmpeg to try and convert it, I get the error message that it is unsupported as soon as I try to select it as my source. Everywhere I look it says that tmpeg does support it. Do I need a codec or something? What am I doing wrong? Please help. Thanks
1) can you watch the avi in windows media player?
if no then
2) drag the file into VirtualDub -- what codec does it say you are missing?your pal,
Stinky -
I can play the avi in windows media player. I've got the divx 5.0 codecs installed. Any other suggestions?
TMPG > options > enviromental settings > increase the priority of the direct show multimedia file reader.
I am having the exact same problem with TMPGenc. The only thing is when I open the .avi in windows media player it is only sound. I have DiVX codec 5 and the .avi loads in Virtual Dub. I tried raising the priority also. When I dragged it into Virtual dub, it just opened the movie file, it didn't tell me what codec i'm missing. The FPS is 14.985 on my .avi.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
failure to convert flv to Avi file because of unsupported video codec
By 2thvideo in forum ffmpegX general discussionReplies: 10Last Post: 30th Jan 2009, 12:54 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 12:28 -
Tmpeg 2.5 will not encode .avi
By WuTangDvD in forum Newbie / General discussionsReplies: 9Last Post: 20th Jul 2007, 13:01
