HI i have got a question i need to ask everyone here if anyone knows how to remove theses 2 viruses from smart tv
a friend of mine got a nasty virus sent to him throgh facebook site
from a person and my friend got a silver badge sent to him to his facebook account that says top fan. anyway i said to my friend that it is a virus cos a few people on facebook have got a silver badges next to there name and it says top fan which is a virus i know that for sure anyway.
when i went to plug into my friends tv a usb stick a blank one or a usb stick with stuff on
which is a smart tv when i go to put a usb stick in the
back on my tv if you have a clean usb stick with nothing on it or if you have a usb stick
with stuff on it.
what happens is the smart tv puts some files onto the usb stick.
3 folders it puts onto a usb stick the first folder says the make of the tv which is a phillips
so the 1st folder says phillips smart tv then in that folder
there is a 2nd folder called data then 1 file in that called data base file
then a 3rd folder called db.info then in that
folder a file called info file then a 4th folder called data.DB-journal
then a file in that folder called DB-journal-file
and everytime
i go to put a usb stick in this tv theses folders and files come up on the tv
and puts them onto a usb stick even if you format the usb stick on a pc the files
are still in the tv when you put the same usb stick or a new one in the back on the 2 smart tvs it brings up thoses files so does anyone know what this virus is and what it does and
how to remove it from the 2 smart tvs the LG SMART TV AND THE PHILLIPS SMART TV.
the only thing i can think of is to smash the 2 tvs up cos the virus is in the tvs. i do also think it also goes into moniters and laptop screens aswell
cos there is some little black dots that appear from time to time on the 2 tvs screens also some channels go missing from time to time
so does anyone know how to remove this virus from theses 2 smart tvs
First, don't worry about the monitors. Monitors are not smart devices. Monitors don't have an OS and don't run apps. Their audio and video connections can't transmit viruses. The audio and video connections on TVs can't transmit viruses either. Connected PCs can't get a virus from a TV just by using it as a display.
Second, do some research to find out if the TVs normally write anything to USB sticks attached to them and what those files and folders contain.
Third, read this article: https://www.lifewire.com/can-a-smart-tv-get-a-virus-4777470#:~:text=In%20other%20words...20can%20access.
If after reading the article you really think your friend's TVs are infected with a virus, tell your friend to make notes listing all the apps he installed on each TV, and their settings. Your friend should also make notes about the TV settings he changed on each TV because they will need to be reapplied. After that, do a factory reset on the TVs as described in the article.Last edited by usually_quiet; 16th Sep 2023 at 10:39.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
The only reason tvs write anything to usb drives is for remembering the position of video files where they last played.
This is the dumbest thread I've read on VH in many years now.
Literally, I feel dumber for having read it. -
I'm guessing these TV's have the ability to record to USB, these folders would be normal when the TV initializes the USB stick ready for recording.
Laptop streaming to 4 TVs displaying youtube video, netflix, etc on 4 tvs
By steveeyes in forum Video Streaming DownloadingReplies: 7Last Post: 10th Feb 2022, 08:13 -
more fun with Panasonic TVs
By Truenorth179 in forum Newbie / General discussionsReplies: 13Last Post: 19th Feb 2021, 15:05 -
Are there any non-smart TVs being sold in 2020?
By ParadiseKendra in forum Off topicReplies: 10Last Post: 23rd Jan 2021, 06:18 -
Which of these 4K TVs is the best to use as a computer Monitor??
By DJboutit in forum Newbie / General discussionsReplies: 1Last Post: 28th Aug 2019, 03:59 -
TV dvd / dvr recorders & "smart" TVs' privacy policies
By natalia25 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 29th Dec 2018, 00:13
