Hi, i have video from super 8 scanned to 4k with a very good machine, but the camera that shot the video had a fault, so the picture comes out very randomly.
Its very jumpy. Need to stabilise it. I've been trying depanstabilise with vapoursynth and deshaker in virtualdub, but doesnt seem my settings are good enough.
How do you stabilise this kind of video where its so off?
Any suggestions on deshaker max settings and mv.Analyse , DepanAnalyse , DepanStabilise max settings for y axis?
Or any other filters i should try?
Results 1 to 10 of 10
Mercalli v6 has very good stabilization I had very good results with jumpy 8mm films some say Topaz Video AI but I didn't try it.
For Avisynth try VideoFred scripts has only for stabilization if you want or all with denoise and interpolation https://www.super-8.be/ -
If you can share a sample others might be able to suggest something, but I agree depending on the severity, Mercalli might be the best choice.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Ive tried them all, not working good enough.
Trying After Effects now, but not sure what to do.
Seems I need Mocha, and that costs 700$. Not paying that for 3-4 clips with 3 minute duration.
It is only white frame not moving or my work pc is not playing it as it should. I will try it from home to run it trough Mercalli but another sample my be needed. I don't think ae or premiere can do better ( far worse ) than Mercalli stabilization
This guy uses Avid Media Composer with good results: https://youtu.be/zjx5fy7u9p4?si=E6tNFeDwuNFj_KkU
helping in downloading video
By killua in forum Video Streaming DownloadingReplies: 18Last Post: 25th Aug 2023, 00:51 -
8mm, Super8 to DVD and restoration
By DVNKLE in forum RestorationReplies: 10Last Post: 25th Jan 2022, 05:26 -
Helping with download link
By ghostrewel in forum Video Streaming DownloadingReplies: 1Last Post: 29th Oct 2021, 01:41 -
Good 8mm/super8 scanners?
By rrats in forum Capturing and VCRReplies: 0Last Post: 18th Aug 2021, 14:10 -
advice re vapoursynth cleaning up old noisy vhs/super8 footage
By hydra3333 in forum Newbie / General discussionsReplies: 14Last Post: 21st May 2021, 02:23
