Hello,
I want to put this NCAA gymnastics meet on DVD-R.
Can someone D/L the highest quality version: 1999 NCAA championship
https://www.youtube.com/watch?v=HGGeL6rwuIo&t=647s&ab_channel=Gymgold07
and convert to DVD-R for me.
And if you can maybe host DL link on google drive, media fire, etc so i can DL
I work part time..i can pay for your time and effort if its difficult to do.
Please let me know.
Thank you!
Thank you.
Results 1 to 15 of 15
Hello, yes I have a DVD burner.
I plan on watching on a standalone DVD player. Tha knyou -
For the forum, does anybody have a quick AVS that could tidy up this YT video a bit? It looks like there is some interlacing burnt in.
Thanks! -
Try
Code:bilinearresize(640,360) awarpsharp(depth=8) spline36resize(640,480) QTGMC(InputType=2)
Yes. Above script is just a proposal (quick AVS in response of post#4) for "fixing" the interlacing artifacts of that source, and to check the result on PC.
For NTSC DVD compliance one would scale it as 704x480 or 720x480 (non-square pixels), encode it as mpeg2, 29.97 fps, DAR 4:3, encode the audio in a DVD compliant format (e.g. AC3), mux and author it as DVD with the .VOB and .IFO file structure, and fulfill other DVD constraints like bitrate etc. One would usually use some DVD authoring tool for this (AVS2DVD or DVDStyler for example), and eventually burn it to a Disc.Last edited by Sharc; 15th Sep 2023 at 17:44.
@peggypwr1, does your DVD player not have SD card slot or a USB port? Or do you just like shiny discs?
Back in the day some US DVD players could play music, display JPEG photos, or play SD DivX or Xvid files from a USB flash drive but not any more. Recent US DVD players are inexpensive machines that only play shiny discs (JPEG photo CDs, music CDs, or DVD video discs.) Today one needs a Blu-ray player to play media files from USB storage devices or SD cards.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Very good Sharc, a person of many talents!
I'm burning the full video to ISO now with Magix. -
I used AVStoDVD if I needed to author a disc with a simple menu or no menu as an ISO (or as files and folders) and then burned to DVD with ImgBurn after testing. AVSto DVD can reencode audio and video to fit on a DVD and for compliance Of course, problems with the video need to be addressed prior to authoring.
MakeMKV convert DVD video to MKV - naming
By vhwul62 in forum Video ConversionReplies: 1Last Post: 15th Jan 2023, 08:14 -
Convert DVD Files to Video
By Cptjimkirk363 in forum Video ConversionReplies: 2Last Post: 22nd Oct 2021, 22:20 -
Convert progressive video to interlaced for a DVD
By Mr Magnétoscope in forum Authoring (DVD)Replies: 35Last Post: 2nd Sep 2020, 18:34 -
Noob: Can someone pls help me save this video program to Hard Disk?
By peggypwr1 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Apr 2020, 15:15 -
Noob Needs DVD Burn Help
By MikeInThe901 in forum Newbie / General discussionsReplies: 1Last Post: 9th Dec 2018, 08:04
