Hey
I have the LG CD-RW CED 8120B and i looked on this site and it says that it supports 90 minutes cds, my question is if the only thing i have to do is to put on of those 90 minute cds in the drive and set the overburning option in nero to 90 minutes and just burn? and what about the thing at the bottom of the nero window that shows u if the cd is full (should i just ignore that)? And another question is if these cds will work like the regular 80 min cds?
Thanks a lot
Hi
just because it says 90minutes does not mean 90minutes, as you are already using nero select Nero toolkit from the start menu and select CD speed, across the top tabs is one called extra, select this and then select overburn test, this will test the CD in your drive and give you an accurate readout as to how many minutes you can burn (different CD's give different readings, i can 83minutes from a standard 80min CD). you will find that the slower you burn the more you can get on, I never go to the limit but leave 1min spare just in case
ps you have to set the CD speed first by using Drive Speed
hope this helpsDont feed the little Varmits too much
Longevity of CDs and DVDs? Are my old CDs starting to lose it?
By garybeck in forum DVD & Blu-ray RecordersReplies: 15Last Post: 25th Jan 2013, 13:38 -
Need a DVD 30 minutes after the game?
By Telemov in forum Newbie / General discussionsReplies: 56Last Post: 15th Feb 2012, 21:39 -
Only convert the first 10 minutes or so ...
By GMUET in forum ffmpegX general discussionReplies: 4Last Post: 8th Jun 2011, 14:13 -
How to shut down harddrives after 20 minutes
By mysts in forum ComputerReplies: 2Last Post: 20th Jan 2010, 02:19 -
Video crashes after a few minutes
By Diego123 in forum Software PlayingReplies: 16Last Post: 4th Jan 2008, 10:04
