Results 1 to 15 of 15
  1. Good night friends,
    I recently discovered that Avisynth brings incredible results if you know how to use it and have knowledge of the lines of code.
    Well, unfortunately I have almost zero of this knowledge but I'm trying to learn, because my dream is to reach 20% of the experts here haha
    Let's go to my problem...
    So that I can take the first step, I followed the steps to install the plugins and software following the information in this video: https://www.youtube.com/watch?v=C4PyyQoz6eo
    I followed all the steps and did a test with my video to see the result, but when I click ''F5'' to view the video on the screen, this error appears for me (Photo attached)
    There is the detail that when I open AvsPmod before pasting the Script, this message appears: "Cannot read the avisynth plugins directory from the registry HKLM\Software\Avisynth'plugindir2_5' or 'plugindir+' is missing or wrong. You should set the plugins path under options manually or register it."
    Thank you if you have the patience to help me
Name:	Sem título.png
    canada
    Next time you post a thread use a more descriptive title to explain your situation,for now i changed it so you can get more help.
  3. Originally Posted by johns0 View Post
    Oh, okay, I'm sorry 🤦🏻
  4. That error message is telling you that you need ffmpeg2source:
    http://avisynth.nl/index.php/FFmpegSource
    https://github.com/FFMS/ffms2/releases/download/2.40/ffms2-2.40-msvc.7z
    If you downloaded that already, make sure you installed the correct version, 32 bit (x86) ffms2.dll for 32 bit AviSynth+, in the plugins+ folder, 64 bit (x64) ffms2.dll for 64 bit AviSynth+, in the plugins64+ folder. And copy the FFMS2.avsi file into both plugins folders.
  5. Originally Posted by jagabo View Post
    Thank you my friend, when I get home I will try.
  6. Originally Posted by jagabo View Post
    Friend, I followed the steps you indicated, adding the filters in the correct folders (32 and 64 bits), but I still receive the same error. Then I installed the FFTW3 libraries again but the error continues. I do not know what to do
  7. I'm not sure how you get that "Cannot read the avisynth plugins directory from the registry.." message. Did you install AviSynth+ or are you using some other program's portable version of AviSynth+? Here's what RegEdit shows for me:
    [Attachment 73844 - Click to enlarge]
    That's normally when you install AviSynth+. Try running AviSynth Info Tool and see what it says about your AviSynth installation -- especially the error/warning section.
  8. Originally Posted by jagabo View Post
    Hi friend, I downloaded this version of Avisynth = ''AviSynthPlus_3.7.3_20230715_vcredist.exe''
    Attached are the photo of the registry editor and the photos of the Avisynth Info Tool
Name:	Info 32 bits.png
Name:	info 64 bits.png
    Oct 2024
    Canada
    Hi guys can anyone please help me with this
    Hi I'm new to avi Synth i used auto overlay plugin to overlay Bluray scope on openmatte and it worked but when I'm opening the script in virtual dub to save as avi it's showing all the details on the video about parameters and alignment even when I'm opening in virtual dub to save as avi it's showing all those info after saving the file
    The script that I have used for auto overlay
    LoadPlugin("%plugin folder%\AvsFilterNet.dll")
    LoadNetPlugin("%plugin folder %\AutoOverlay_netautoload.dll"
    OM=AviSource("c:\test\OpenMatte.avs") # YV12 clip
    WS=AviSource("c:\test\Widescreen.avs") # YV12 clip
    OverlayEngine(OM.ConvertToY8(), WS.ConvertToY8(), configs=OverlayConfig(subpixel=2))
    OverlayRender(OM.ConvertToYV24(), WS.ConvertToYV24(), debug=true)
    ConvertToYV12()Image
    [Attachment 82837 - Click to enlarge]
    Oct 2024
    Canada
    So in this code(OverlayRender(OM.ConvertToYV24(), WS.ConvertToYV24(), debug=true) i kept debug as false and it's not showing anything like before thanks for that but can you please check other codes lines are fine or should I need to change?
  11. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Provide content if OpenMatte.avs and Widescreen.avs for completeness
    Oct 2024
    Canada
    I didn't get it can please say in detail
  13. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Inside the main code, you are loading 2 avisynth scripts, called OpenMatte.avs and Widescreen.avs. Probably they just open/load a clip, but is not clear what else they may do without looking at them.
    Oct 2024
    Canada
    Bro can I overlay 4k widescreen on 1080p open matte by using the same code?
