Results 91 to 120 of 132
Hi. I am also new doing this stuff, but I can't seem to get WKS-KEY working. I already have the encrypted audio and video.
Its from this Dutch broadcaster: https://npo.nl/start/serie/first-dates/seizoen-30_1/kerst_49/afspelen
PSSH: AAAAXHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADwIARIQil zm29wAZg6R/IHMPRFJ5BoIdXNwLWNlbmMiGGlsem0yOXdBWmc2Ui9JSE1QUkZ KNUE9PSoAMgA=
License:
https://npo-drm-gateway.samgcloud.nepworldwide.nl/authentication?custom_data=eyJhbGciO...4U6aqIwiaoE7jg
Thank you very much if anyone could help me. -
What is the situation in this case?
[Attachment 75666 - Click to enlarge] -
Can anyone help me get the key for the same Dutch site? I've had success on other sites but there seems to be authentication that is baffling me?
https://npo.nl/start/serie/argos-medialogica/seizoen-10/strijd-om-transgenderzorg/afspelen -
Thank you so much!
Are you able to get the keys for this one? It seems to be region-locked.
https://npo.nl/start/serie/2doc/seizoen-10_1/2doc-genderpoli/afspelen
it's here too
https://www.2doc.nl/documentaires/2023/11/genderpoli-they-and-them.html -
https://npo.nl/start/serie/2doc/seizoen-10_1/2doc-genderpoli/afspelen --key ddf4b2cdadcc44406f159c1b87e33f64:d68bd4ba207af4c213aed9f2a4eb3758 https://www.2doc.nl/documentaires/2023/11/genderpoli-they-and-them.html --key ddf4b2cdadcc44406f159c1b87e33f64:d68bd4ba207af4c213aed9f2a4eb3758
Hi I got an weird issue:
when I try to get key from PSSH and license URL by cdrm-project
I got this message:
Please let me know what is issue behind it, would very appreciateError 400: {"message":"認証エラーです。"}
PSSH:
License URLCode:AAAAcnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAFIIARIQIaASc4JrTk+AOVAFc5oL5yI1eyJ2ZW5kb3JfY29kZSI6InRyYW5jZXZpZGVvIiwicHJvZHVjdF9jb2RlIjoic2FtcGxlIn0qBVNEX0hE
MPD
<?xml version='1.0' encoding='utf-8'?>
<MPD type="static" profiles="urn:mpeg:dash
rofile:isoff-on-demand:2011" minBufferTime="PT2S" mediaPresentationDuration="PT2M30.167S" xmlns="urn:mpeg:dash
chema:mpd:2011" xmlns:cenc="urn:mpeg:cenc:2013" xmlns:mspr="urn:microsoft
layready">
<!-- {"content_info":{"vendor_code":"trancevideo","prod uct_code":"sample"},"created_at":"2020-02-05T14:18:03+09:00","packaging_id":"17e48e1a-9184-463c-adf6-f4571c6a75f1"} -->
<Period>
<AdaptationSet minWidth="1280" minHeight="720" maxWidth="1280" maxHeight="720" startWithSAP="1" segmentAlignment="true" mimeType="video/mp4">
<ContentProtection value="cenc" schemeIdUri="urn:mpeg:dash:mp4protection:2011" cenc:default_KID="21a01273-826b-4e4f-8039-5005739a0be7"/>
<ContentProtection value="PlayReady" schemeIdUri="urn:uuid:9a04f079-9840-4286-ab92-e65be0885f95">
<mspr
ro>9AIAAAEAAQDqAjwAVwBSAE0ASABFAEEARABFAFIAIAB4AG0 AbABuAHMAPQAiAGgAdAB0AHAAOgAvAC8AcwBjAGgAZQBtAGEAc wAuAG0AaQBjAHIAbwBzAG8AZgB0AC4AYwBvAG0ALwBEAFIATQA vADIAMAAwADcALwAwADMALwBQAGwAYQB5AFIAZQBhAGQAeQBIA GUAYQBkAGUAcgAiACAAdgBlAHIAcwBpAG8AbgA9ACIANAAuADA ALgAwAC4AMAAiAD4APABEAEEAVABBAD4APABQAFIATwBUAEUAQ wBUAEkATgBGAE8APgA8AEsARQBZAEwARQBOAD4AMQA2ADwALwB LAEUAWQBMAEUATgA+ADwAQQBMAEcASQBEAD4AQQBFAFMAQwBUA FIAPAAvAEEATABHAEkARAA+ADwALwBQAFIATwBUAEUAQwBUAEk ATgBGAE8APgA8AEsASQBEAD4AYwB4AEsAZwBJAFcAdQBDAFQAM AA2AEEATwBWAEEARgBjADUAbwBMADUAdwA9AD0APAAvAEsASQB EAD4APABDAFUAUwBUAE8ATQBBAFQAVABSAEkAQgBVAFQARQBTA CAAeABtAGwAbgBzAD0AIgAiAD4APABwAHIAbwBkAHUAYwB0AF8 AYwBvAGQAZQA+AHMAYQBtAHAAbABlADwALwBwAHIAbwBkAHUAY wB0AF8AYwBvAGQAZQA+ADwAdgBlAG4AZABvAHIAXwBjAG8AZAB lAD4AdAByAGEAbgBjAGUAdgBpAGQAZQBvADwALwB2AGUAbgBkA G8AcgBfAGMAbwBkAGUAPgA8AC8AQwBVAFMAVABPAE0AQQBUAFQ AUgBJAEIAVQBUAEUAUwA+ADwAQwBIAEUAQwBLAFMAVQBNAD4AV wAzAGsARABWADYAUQBhAHMAVAA4AD0APAAvAEMASABFAEMASwB TAFUATQA+ADwALwBEAEEAVABBAD4APAAvAFcAUgBNAEgARQBBA EQARQBSAD4A</mspr
ro>
</ContentProtection>
<ContentProtection value="Widevine" schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed">
<cenc
ssh>AAAAcnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAFIIAR IQIaASc4JrTk+AOVAFc5oL5yI1eyJ2ZW5kb3JfY29kZSI6InRy YW5jZXZpZGVvIiwicHJvZHVjdF9jb2RlIjoic2FtcGxlIn0qBV NEX0hE</cenc
ssh>
<Representation width="1280" height="720" frameRate="30/1" id="3000_v" codecs="avc1.64001F" bandwidth="3036000">
<BaseURL>3000_v.mp4</BaseURL>
<SegmentBase indexRange="1726-1985">
<Initialization range="0-1725"/>
</SegmentBase>
</Representation>
</AdaptationSet>
<AdaptationSet startWithSAP="1" segmentAlignment="true" mimeType="audio/mp4">
<mspr
ro>
<cenc
ssh>
<Representation id="3000_a" codecs="mp4a.40.2" bandwidth="128000" audioSamplingRate="44100">
<BaseURL>3000_a.mp4</BaseURL>
<AudioChannelConfiguration value="2" schemeIdUri="urn:mpeg:dash:23003:3:audio_channel_c onfiguration:2011"/>
<SegmentBase indexRange="1646-1989">
<Initialization range="0-1645"/>
</SegmentBase>
</Representation>
</AdaptationSet>
</Period>
</MPD>Last edited by basaraheroes; 19th Jan 2024 at 03:01.
Hello,
I try to use a license server with a given pssh key with correct header, but I get this error: Error 403: {"code":130301,"message":"Content is not available in this location."}.
Do you know how can I use the proxy field? Where do I authenticate, etc.? For the current licence server, a Greek proxy is required. -
Use https://github.com/Snawoot/hola-proxy it has a Greek proxy. Just run:
and then set 127.0.0.1:8080 as your system proxy.Code:hola-proxy.windows-amd64.exe -country gr
I mean for this site http://108.181.133.95:8080/ which has a proxy field, will I insert there the localhost link when I am connected to proxy? I tried it but it's not working. I get 403 when trying to connect to this site.
greek... try that one
Code:http://user-uuid-4cc4b3044cb04d2095652029d52fe432:bee06548cb61@46.101.76.139:22223
For this proxy I get this when trying to connect to the website:
Code:PROXY : 2024/02/03 18:38:56 handler.go:104: INFO Request: 127.0.0.1:58278 HTTP/1.1 GET http://108.181.133.95:8080/ PROXY : 2024/02/03 18:38:58 handler.go:95: INFO 127.0.0.1:58278 GET http://108.181.133.95:8080/ 403 Bad Port
--key 5a2c4814dae44b3798b6c1f69ec84c5a:7f81506cbdbab82600948b7223879941
Thanks for the key, but I would like to know how I get this alone with proxy?
Sure, I had it too
, but how can I get it from license server? If anyone knows how to use proxy... I have tried from Linux hola-proxy and add localhost to firefox settings. It works as proxy, but when I go to this specific link with the 8080 port I get:
handler.go:95: INFO 127.0.0.1:38080 GET http://108.181.133.95:8080/ 403 Bad Port
If I do not use proxy in browser and add it to proxy field in website, I get 404 not found -
Ok, I found how to use proxy, but now I get this:
Error 403: {"code":130302,"message":"Content is not available via the proxies."}
So, there is no way getting license from this server? (not cached ofc)Last edited by LinUser; 3rd Feb 2024 at 12:35.
if you use the proxy method correct, then most probably that proxy blacklist by license server.
help in getting widevine keys
By Sandy sai in forum Video Streaming DownloadingReplies: 8Last Post: 8th Dec 2023, 10:45 -
By Sandy sai in forum Video Streaming DownloadingReplies: 7Last Post: 10th Sep 2023, 08:28 -
By Sandy sai in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Oct 2022, 04:21 -
By Sandy sai in forum Video Streaming DownloadingReplies: 3Last Post: 10th Aug 2022, 08:12 -
Help with getting widevine keys
By lerman in forum Video Streaming DownloadingReplies: 4Last Post: 28th Jun 2022, 10:48
