Page 1 of 5
1 2 3 ... LastLast
Results 1 to 30 of 132
  1. Last edited by _stream_; 4th Oct 2023 at 03:51.
    Sep 2023
    Spain
    Originally Posted by _stream_ View Post
    Thanks.
    Sep 2023
    spain
    Thank you very much, I was looking for something like that, could you update this key of this MPD, the ones that appear do not work, please, thank you
    https://b46178-p52-h93-aefpwpov-te50cfb.1.cdn.telefonica.com/_46178/dash/2plus.isml/manifest.mpd
  4. Originally Posted by djcalmix View Post
    You can decrypt the contents yourself and get the keys
    Add to the site
    PSSH+LICENSE+HEADERS
    and get the keys
    Sep 2023
    spain
    pssh
    AAAAOnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABoIARIQTU 7Z9FsWQJaKlWnUjLaNZCIENTI2NA==
    licence
    https://wv-ottlic-f3.imagenio.telefonica.net/TFAESP/wvls/contentlicenseservice/v1/licenses
    mpd
    https://b46178-p52-h93-aefpwpov-t2d2d3e.1.cdn.telefonica.com/_46178/dash/2plus.isml/manifest.mpd
    HEADERS I don't know how to get it out
  6. Originally Posted by djcalmix View Post
    pssh
    licence
    mpd
    in the line of the license
    You have HEADERS
    You should copy it here.
    Sep 2023
    spain
    HTTP/1.1 200 OK
    Server: nginx
    Date: Sat, 16 Sep 2023 12:59:50 GMT
    Content-Type: application/octet-stream
    Content-Length: 692
    Connection: keep-alive
    Access-Control-Allow-Origin: *
    Access-Control-Allow-Credentials: true
    drmDeviceId: 2/5svVYPW8Zq7XacDRkUjeCszr9CXsFys5Sxe4FUqX0=
    model: ChromeCDM
    x-correlation-id: d18d7339-d413-41dc-8ba4-961446ed23fb
    Access-Control-Expose-Headers: ETag, nv-tenant-id
    nv-tenant-id: TFAESP
  8. Originally Posted by djcalmix View Post
    HTTP/1.1 200 OK
    Server: nginx
    Content-Length: 692
    model: ChromeCDM
    4d4ed9f45b1640968a9569d48cb68d64:04d99b897cc16983950a5f4b0c72d698
    Sep 2023
    spain
    thanks
  10. Originally Posted by _stream_ View Post
    HTTP/1.1 200 OK
    Server: nginx
    Content-Length: 692
    model: ChromeCDM
    Thanks, but how did you do it?
    I try it and always gives me an error in the header.
    In what format should the header be put?
  11. Hi everyone. I'm trying to download something from the same movitarplus, but I've heard that I need to retrieve a token and use that token manually in wks-key?
    The only thing I'm not able to figure out is where to get that token and how to use it, where to put it.
    Do anybody know how to do it?
  12. Originally Posted by javidial View Post
    You need the mpd, and also use the headers for extract the keys
  13. I have the pssh, the license url and the header, and this is what I get:
    unable to parse license - check protobufs
    Movistar in particular needs a token to be extracted
    The license is incomplete:
    Sep 2023
    spain
    Hello colleagues, do you know how to get the pssh, when it is not in an mpd url? Thanks in advance
  15. It's inside the first video fragment. You can use mp4dump to find it. Read here: https://forum.videohelp.com/threads/405001-How-to-get-the-widevine-pssh-from-init-mp4-...-python-script
    Sep 2023
    spain
    Thanks, I'll take a look to see if I can clarify.
  17. Hi guys, just for the sake of knowledge, If i own the kid and the key and the mpd manifest would it be possible to retrieve the widevine license server url?
  18. I’m more concerned about the token than need to be extracted. Without it, vomistar won’t work
    Sep 2023
    spain
    Someone who uses movistar pr drm url mpd has stopped working, as I have heard that it only works with residential IP... some of them still work. Thank you
  20. how is this different than keysdb.net? imaybe the access? I got the same result, without changing the header field at all.
    [Attachment 74075 - Click to enlarge]
  21. Originally Posted by tad108 View Post
    Is that a url license from vomistar spain? How did you get it? In chrome the url is https://wv-ottlic-f3.imagenio.telefonica.net/TFAESP/wvls/contentlicenseservice/v1/licenses only, nothing else. Your url has the token in it.
  22. Originally Posted by javidial View Post
    no that's a different video, i was talking about the keysdb page
  23. Originally Posted by tad108 View Post
    They are accessing the same DB. So you will get the same Cached Keys. BTW, you get cached keys with only the PSSH; the other infomatiion (license url & headers) were correctly input by the person who provided the information and generated the keys that were saved.
  24. Originally Posted by _stream_ View Post
    HTTP/1.1 200 OK
    Server: nginx
    Content-Length: 692
    model: ChromeCDM
    can you explain how did you get it? thanks
  25. I'm trying to get the keys for this Widevine-protected video on a Dutch public broadcaster, and there seems to be an extra authorisation step. Maybe I screwed something else up, but the server comes back with "401 Authorization Required".
    https://www.bnnvara.nl/zembla/artikelen/het-transgenderprotocol
  26. Member
    Dec 2021
    england
    --key e910aea4aa61a9e72d89179b893b2d76:e0a9f05764dc31c267a56ccaf9824c29
  27. Originally Posted by iamghost View Post
    Wow, I'm not sure what I missed, but thanks so much!
  28. pssh
    AAAANHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABQIARIQQe H0lZq1SjGpHonz2kpRKA==
    license
    https://license.ha.abema.io/playout/widevine?t=5MGFvYRLKcmHUtqaPaWgV5L3UcSdHzVUNw1MdCR...tcnHTwfhBrFL8g
    mpd
    https://vod-playout-abematv.akamaized.net/tokyo/v5/vod/channel/01HBYWADERGEYD4RWEFA72D...t/manifest.mpd
    Response headers
    HTTP/1.1 200 OK
    Access-Control-Allow-Origin: https://abema.tv
    Content-Length: 656
    Date: Sat, 28 Oct 2023 04:19:19 GMT
    Via: 1.1 google
    Request headers
    POST /playout/widevine?t=5MGFvYRLKcmHUtqaPaWgV5L3UcSdHzVUNw1MdCR uWq9pmmbbbrB8zuj6qX7TBbcYtUM3jbtTtjsSVgLFvP5S5syFL GwxEC3jHJqJ6WxzrW2qMXJNAQG9Yhp55XJ8cCtzG&pt=eyJhbG ciOiJFUzI1NiIsInR5cCI6IkpXVCJ9.eyJpc3MiOiJwcmQucHB 2LmFiZW1hLnR2L3YxIiwic3ViIjoiQ2ZYTmcxSG5pWEJMelQiL CJleHAiOjE2OTg1NjI2NjksImlhdCI6MTY5ODQ2Njc0OCwicmV mcmVzaEF0IjoxNjk4NDczNjk3LCJsaXZlRXZlbnRJRCI6IjczO GNiNTFkLWE1MGQtNDhhNy04MTU0LWVhODM4OThmZjYyYyIsIml 0ZW1JZHMiOlsiYWJtMS5wcHYuaXRlbS5XVFp3UGl6RVA1MlI4d ThZNEhldnFEIl0sIkdyYW50VHlwZSI6MX0.-WddhFIzm3gYQ9X44eBXqGY9uUpzS4NpJRxZBZL9gpfyQs8dNrD 8c2-Ai0FKv_PpnPRg8u-SabeFVR6JQEMOUw HTTP/1.1
    Accept: */*
    Accept-Encoding: gzip, deflate, br
    Accept-Language: zh-TW,zh;q=0.9,en-US;q=0.8,en;q=0.7
    Content-Length: 4252
    Host: license.ha.abema.io
    Referer: https://abema.tv/
    Sec-Fetch-Dest: empty
    Sec-Fetch-Mode: cors
    Sec-Fetch-Site: cross-site
    User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36
    sec-ch-ua: "Chromium";v="118", "Google Chrome";v="118", "Not=A?Brand";v="99"
    sec-ch-ua-mobile: ?0
    sec-ch-ua-platform: "Windows"
    i dont know where to get the HEADERS
  29. @stacen
    your key
    41e1f4959ab54a31a91e89f3da4a5128:41e5e300c54439e9361dac195b815e18
    you don't need headers to get the key
  30. Thanks so much, Cedric! sorry to bother if you dont mind to another key..
    I'll try and find out a little more later.
    mpd
    pssh
    AAAANHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABQIARIQVK NTagReSu+VPYfPOGPeEg==
    license
    https://license.ha.abema.io/playout/widevine?t=5MGFvYRLKcmHUtqaPaWgV5L3UcSdHzVUNw1MdCR...abeFVR6JQEMOUw
