I just ripped THE ONE and the subtitles are green and hard to read. anybody else had this problem and found a solution?? :cry:
Yes, i had the problem once, but more likely they were yellow-light green and impossible to read. I used Subrip 0.97, but saved the subtitles as 8bit .BMPs. Then I switch to 4 bit .BMPs and used submux to add them to the .MPG. They are OK now. Hope this helps.
hrm....wanna elaborate further on which procedure you used to get the subtitles..did you use those all-in-one proggies like dvd2svcd or dvdx?
if you're using the traditional smartripper->dvd2avi->tmpgenc->nero...
here are two methods you should check out:
1) vobsub/vdub http://www.doom9.org/vobsub.htm
2) flaskmpeg/avisynth http://www.vcdhelp.com/dvdtovcdflask.htm -
I ripped the pan and scan version to the hard drive and used ifoedit to create new ifo files and then burnt the dvd. movie is great but when looking at the subtitles they are green and very hard to read.
I would have thought with this method it should be the same as the original
So what's a basic Tivo (read: DVD recorder with built-in Hard Drive) cost?
By snafubaby in forum DVD & Blu-ray RecordersReplies: 14Last Post: 18th Dec 2011, 13:53 -
Could I use a green fabric as a green screen? Where could I get fabric?
By bojadada in forum Off topicReplies: 2Last Post: 5th Dec 2009, 12:48 -
DVD recorder that will read movie files from ex hard drive?
By siratfus in forum DVD & Blu-ray RecordersReplies: 9Last Post: 3rd Oct 2008, 15:26 -
hard disc 1 died, hard disk 2 won't boot, halp!
By Yoroshiku in forum ComputerReplies: 6Last Post: 30th Oct 2007, 14:48 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04
