IN Subtitle Edit:
Hello,
when I try to paste 'A in italics with a dash on top' (the sign for A-complement in maths), I can only get an A with a dash TO THE RIGHT, and at the top. I can't get the dash to be on top of the A.
I've tried doing it successfully in word, and then copying and pasting, but the dash always moves to the top right hand side of the letter. This is how it copies:
A−
but the dash needs to be above the A.
How do I do this? Thank you.
To be able to do this correctly, some conditions must be met:
1: You must use Unicode or utf-8 character encoding
[Attachment 73740 - Click to enlarge]
2: You have to use Character Map program (included in every windows installation)
[Attachment 73741 - Click to enlarge]
Find the wanted character -> Select and the Copy.
Paste the character into Subtitle Edit.
3: Try your video with a suitable video-player and hope for the best.
The video-player has to support subtitles with utf-8 encoding. -
Subtitle Edit : Capitalize Subtitle to Normal Subtitle incomplete
By kalemvar1 in forum SubtitleReplies: 6Last Post: 5th Aug 2023, 13:28 -
Subtitle Edit - Shortcut to set a subtitle minimum gap
By tren in forum SubtitleReplies: 2Last Post: 1st Aug 2023, 07:44 -
Copy a range from one subtitle to another in Subtitle Edit
By loninappleton in forum SubtitleReplies: 7Last Post: 4th Jul 2023, 02:29 -
How to hide codes like <br/> />, etc. in subtitle file in subtitle edit?
By Pusat in forum SubtitleReplies: 0Last Post: 10th May 2023, 02:34 -
Subtitle edit, warning subtitle contains negative timing codes fix please
By jraju in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2019, 19:52
