  1. Basically these settings:
    The option to disable the audio channel, and setting the output resolution to 720p. Is there any way to make these the default? Just so I don't have to manually set them over and over and over every time I go to convert something.
  2. What program is this?
  3. Originally Posted by orion44 View Post
    XMedia Recode
    Mar 2008
    I don't think it's possible in XMR.
    Why don't you create a simple batch file and use FFmpeg?
  5. There are several ini files in the XMR Format folder.
    I changed the # of reference frames default from 2 to 4 in the mkv.ini file.
    t wasn't easy to find what to change and perhaps you can't change everything.
    Give it a look.
