encoding captured uncompressed files
How do I get the best quality? I only get very poor quality when I encode, with virtualDub and the Divx low-motion codec.
Help me!
depends on what you want to accomplish, any specif purpose?
... this copy of me hasn't been registered for the last 36 years! (no spamming please) -
I want to compress it with the divx codec.
How do I get the best quality? Is where a way to
get the divx/mpg file to look nearly like the uncompressed? -
i mostly work the other way around, so i am not much of a help here, but the reason why i asked is: why?
if you want to encode dvd rips, you have to go via the divx codecs, multi pass, and play around a little bit with the bitrate
if you want to grab some material and edit it, go via huffyuv... this copy of me hasn't been registered for the last 36 years! (no spamming please)
cannot burn or copy captured mpeg2 files
By DirtBikeMike in forum Capturing and VCRReplies: 12Last Post: 3rd May 2011, 07:49 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 08:20 -
How to edit/Remove Commercials from .ts files captured by ProgDVB?
By MounaLafi in forum DVB / IPTVReplies: 4Last Post: 2nd Oct 2009, 06:41 -
Hi8 captured DV to MPEG2 or x264 MKV files
By pred02 in forum Video ConversionReplies: 2Last Post: 9th Jul 2009, 15:09 -
Join 2 uncompressed wav audio files
By kidcash in forum AudioReplies: 13Last Post: 11th May 2008, 02:15
