    Aug 2008
    Greece
    Hi.
    Is there any program simple as makemkv that has more audio convert options?
    For example:
    01. Everything to ac3 stereo
    02. Dts-hd to dts-core
    03. Truehd to ac3
    And many more.
    Cause i want to teach use it a person that don't use match the pc if there any program simple as makemkv and has more features of makemkv mostly at audio pleate tell me which is this program.
    A lot of thanks for your time and your answers.
    Aug 2008
    Greece
    No one knows?????
  3. BOX4 might be a solution for your needs.
    Aug 2008
    Greece
    Unfortunately this program has almost 3 year to update so at new codecs of video files and audio it can do anything at all.
    I look a program that updated frequently with new codecs e.t.c.
  5. You don't need do convert video and BOX4 is just a remuxer like MakeMKV and most of the audio options are available...you can also manually update the embedded FFMpeg. Anyway I'm not related to that software and I don't have to convince you. Someone else wil give you better suggestions for sure.
    Aug 2008
    Greece
    But i don't tell you i want to convert video.
    Please read my first post.
    I just want to convert mostly audio not video.
    If there is any gui program that use ffmpeg(I believe all that kind program use this).
  7. Originally Posted by fits79 View Post
    Hi.
    For example:
    03. Truehd to ac3
    And many more.
    You could try clever FFmpeg-GUI.
    Aug 2008
    Greece
    No no no no.
    I try to give this app to my friend and really is more confused than solve the puzzle.
    Like makemkv.
    Simple as makemkv but with more audio options.
