Results 1 to 10 of 10
  1. Folks, I have a problem with rendering in Sony Vegas 13 Pro for the android.
    I'm taking the vertically videos via my phone without changing any video and audio options.
    On PC BEFORE and after rendering it looks like this: https://i.ibb.co/6DnfbJ3/Clipboard01.jpg
    After I upload it to any of my android phones it looks like this: https://i.ibb.co/QbLdmRw/Clipboard02.jpg
    I tried to change the codec, frame and bit rate and frame size but nothing helped.
    My Android keep showing me this small videos regarding of parameters i chose.
    Please advise what's wrong as on PC everything looks good.
  2. What video player are you using on your android phone?
    Extraordinary claims require extraordinary evidence -Carl Sagan
  3. I use 5 different players and different phones, but all I see is just: https://i.ibb.co/QbLdmRw/Clipboard02.jpg
    Mar 2008
    Post here a short sample of your source.
    It looks as if the problem is related to other project settings rather than those other items you mentioned
  5. Just following occam's razor approach, most simple cause, it would be: you have project settings set as wide (16:9 or something), then importing a video in it that is vertically oriented. When exporting, it is a proper wide video with a content in the middle, pillarboxed (two black pillars left and right). But if viewing on vertical screen you get what you got a specialty -> letterbox of pillarbox .
    Resolution (if that is the case): Load that video of yours into a Vegas project properties with the same width and height as you image is, also make sure your export is set with the same width and height.
    Just rule that one out, if it is not the case.
    May 2005
    Australia-PAL Land
    Easy way to check exactly what your video looks like: open it in VLC Player, then drag one of the VLC window sides in until the video itself starts reducing in size. Stop there. Any visible black sides or top/bottom have been burnt into the video during the encoding process and that is causing your problem.
  7. Changing the project setting do not help me to solve my problem
    here you go a piece of it: https://www.filemail.com/d/ojtuxylzbobwybz
    General
    Complete name : C:\Users\John\Downloads\Untitled.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (mp42/isom)
    File size : 1.16 MiB
    Duration : 467 ms
    Overall bit rate : 20.9 Mb/s
    Frame rate : 29.970 FPS
    Encoded date : 2023-09-11 23:49:51 UTC
    Tagged date : 2023-09-11 23:49:51 UTC
    Video
    Format : AVC
    Format profile : Baseline@L4
    Format settings : 3 Ref Frames
    Format settings, CABAC : No
    Format settings, Reference frames : 3 frames
    Codec ID : avc1
    Duration : 467 ms
    Bit rate mode : Variable
    Bit rate : 20.7 Mb/s
    Maximum bit rate : 18.0 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 (30000/1001) FPS
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.333
    Stream size : 1.15 MiB (99%)
    Language : English
    Color range : Limited
    Codec configuration box : avcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Duration : 427 ms
    Bit rate mode : Constant
    Bit rate : 192 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 9.91 KiB (1%)
    Language : English
    May 2005
    Australia-PAL Land
    That explains the display on your phone. The burned-in black side bars are stopping the vertical expansion of the actual video. There is nothing wrong with your phone/Android.
    I don't use Vegas so can't help with specifics, but based on other video editors I've used, you'd have to set up a project of 1080x1920, 9:16 ratio and make sure you exported to that as well.
  9. That download link is not working.
    Mar 2008
    I've never seen a portrait video inside a landscape frame like that -
    active picture area 608x1080
