I save thumbnail. subtitle is not appear
MediaInfo
General
Unique ID : 98542588349362187832023627913658597158 (0x4A229CB72B6A434A37885D44EE477F26)
Complete name : Z:E1 - Gojo Satoru.mkv
Format : Matroska
Format version : Version 4
File size : 525 MiB
Duration : 23 min 55 s
Overall bit rate : 3 067 kb/s
Frame rate : 23.976 FPS
Description : Packed by Bilibili XCoder v2.0.2
Writing application : Lavf60.3.100
Writing library : Lavf60.3.100
ErrorDetectionType : Per level 1
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L5.1@Main
Codec ID : V_MPEGH/ISO/HEVC
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (23976/1000) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
VENDOR_ID : [0][0][0][0]
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Default : Yes
Forced : No
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Duration : 23 min 54 s
Compression mode : Lossless
Language : ENG
Default : No
Forced : No
Results 1 to 1 of 1
Looking For a Thumbnail Maker Similar Like MPC-HC
By Daringbaaz in forum Newbie / General discussionsReplies: 4Last Post: 29th Dec 2024, 09:13 -
Subtitle Edit Can't Save As SRT
By Gildor57 in forum SubtitleReplies: 2Last Post: 7th May 2023, 00:08 -
[MPC-HC] Looking for alternate subtitle filter
By Compositor in forum Newbie / General discussionsReplies: 27Last Post: 8th Jul 2022, 17:14 -
How to save files as .SUP from Subtitle Editor?
By DiodE in forum SubtitleReplies: 4Last Post: 14th Nov 2020, 07:21 -
MPC-HC Subtitle delay when seeking
By mpcfun in forum Software PlayingReplies: 1Last Post: 1st Oct 2020, 04:05
