Results 1 to 11 of 11
  1. Okay, so I had issues with AVC last time. This time Xmedia Recode won't even burn-in the subtitles. The videos seem to convert just fine, mp4 to mp4. I can play the videos. I'm not sure why this problem just popped up. Does Xmedia use ffmpeg that's stored somewhere in the Windows folders? Or does it use its own?
    Windows 10, MPC-BE
  2. Write exactly what is not working and post a mediainfo report (text mode) of your video here.
  3. subtitles won't burn-in.
    HTML Code:
    General
    Complete name                            : C:\Users\kraco\Onedrive\Desktop\The.Running.Man.1987.720p.BluRay.x264-[YTS.AM]_1.mp4
    Format profile                           : Base Media
    Codec ID                                 : isom (isom/iso2/avc1/mp41)
    File size                                : 1 020 MiB
    Duration                                 : 1 h 40 min
    Overall bit rate                         : 1 416 kb/s
    Frame rate                               : 23.976 FPS
    Encoded date                             : 2023-09-08 12:26:50 UTC
    Tagged date                              : 2023-09-08 12:26:50 UTC
    Writing application                      : Lavf59.30.100
    Video
    Format profile                           : Main@L4
    Format settings                          : CABAC / 2 Ref Frames
    Format settings, Reference frames        : 2 frames
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Bit rate                                 : 1 300 kb/s
    Maximum bit rate                         : 2 400 kb/s
    Width                                    : 712 pixels
    Height                                   : 400 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 (24000/1001) FPS
    Bits/(Pixel*Frame)                       : 0.190
    Stream size                              : 924 MiB (91%)
    Writing library                          : x264 core 164 r3085
    Encoding settings                        : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x131 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=0 / weightb=1 / open_gop=0 / weightp=2 / keyint=239 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=1300 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=69 / qpstep=4 / vbv_maxrate=2400 / vbv_bufsize=24000 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=3:1.00
    Codec configuration box                  : avcC
    Audio
    Format                                   : AAC LC
    Format/Info                              : Advanced Audio Codec Low Complexity
    Codec ID                                 : mp4a-40-2
    Source duration                          : 1 h 40 min
    Bit rate mode                            : Constant
    Bit rate                                 : 128 kb/s
    Channel layout                           : L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 46.875 FPS (1024 SPF)
    Stream size                              : 92.2 MiB (9%)
    Source stream size                       : 92.2 MiB (9%)
    Default                                  : Yes
    Alternate group                          : 1
    Windows 10, MPC-BE
    Mar 2008
    To burn in subs using XMR, do not import the subs from the subtitle tab,
    instead load the subtitle filter on the filters/preview tab and load the external subs from there
  5. That's exactly what I did. I even did it 3 times with 2 different videos.
    Windows 10, MPC-BE
    Mar 2008
    Did you end up with soft subs instead?
  7. no, and besides MP4s can't use soft subtitles, I don't think.
    Windows 10, MPC-BE
    Mar 2008
    They can, it gets converted to timed text. So you should atleast have got that
    General
    Complete name                            : C:\Users\davex\Videos\Connected (short 720p).mp4
    File size                                : 42.9 MiB
    Duration                                 : 5 min 17 s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 1 133 kb/s
    Encoded date                             : 2016-08-15 12:10:56 UTC
    Tagged date                              : 2016-08-15 12:10:56 UTC
    Writing application                      : Lavf60.11.100
    Video
    Format profile                           : Main@L3
    Codec ID                                 : avc1
    Bit rate                                 : 938 kb/s
    Width                                    : 720 pixels
    Height                                   : 406 pixels
    Original display aspect ratio            : 16:9
    Bits/(Pixel*Frame)                       : 0.134
    Stream size                              : 35.5 MiB (83%)
    Writing library                          : x264 core 164 r3106
    Encoding settings                        : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x131 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=0 / weightb=1 / open_gop=0 / weightp=2 / keyint=239 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=cqp / mbtree=0 / qp=20 / ip_ratio=1.40 / pb_ratio=1.30 / aq=0
    Format                                   : Timed Text
    Muxing mode                              : sbtl
    Codec ID                                 : tx3g
    Duration                                 : 4 min 58 s
    Bit rate mode                            : Variable
    Bit rate                                 : 43 b/s
    Frame rate                               : 0.299 FPS
    Stream size                              : 1.58 KiB (0%)
    Title                                    : 0
    Default                                  : Yes
    Forced                                   : No
    Alternate group                          : 3
    Count of events                          : 44
  9. I must have selected the wrong thing or something. But the subtitles were not in the list when I viewed it with MPC BE. I'm not sure what to do.
    Windows 10, MPC-BE
    Mar 2008
    Use mediainfo in text view to see all the file details.
    If you're interested in solving it post a screen shot of each of the tabs
  11. what tabs? There's just File, View, Options at the top, and the left column isn't much different.
    But I have tried a newer version of XMR last night and that works properly. It just seems like AVC and XMR work at first but then over time they stop working properly. Maybe somehow my computer is messing with how these programs function.
    Windows 10, MPC-BE
