I got problem here, hope someone could help.
I got smooth picture of avi but when i convert to mpg using TMPGENC, the result is a choppy mpg movie.
This is the setting of my TMPGEnc:-
MPEG-1 Video
352x288
4:3 625 line (PAL)
25 fps
CBR
1150 kbit/sec
Normal
T.I.A
Is your avi a downloaded movie by any chance? If so then there is a good chance that it is encoded at NTSC (film) standard of 23.97 fps. Encode your movie at the same framerate (and matching standards) as the source and the choppy playback problem will disappear.
Hi.
I had the same problem with mpg=choppy on PAL DVD rips. The solution is to ensure that in DVD2avi you have NOT selected Force Film in the video option.
Hope this helps.
Scotia
PROBLEM: AVI -> MPG by using TMPGEnc 4.0 XPRess (4.2.3.193)
By Hummelchen in forum Video ConversionReplies: 0Last Post: 14th Jun 2010, 07:10 -
mpg jerky choppy fast motion solved
By herdofem in forum Software PlayingReplies: 0Last Post: 4th May 2009, 21:38 -
choppy audio from mpg to DVD conversion - Help
By Warhammerx in forum Video ConversionReplies: 4Last Post: 7th Dec 2008, 19:25 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50 -
TMPGEnc not working.. what else is good for avi to mpg?
By andre477 in forum Video ConversionReplies: 10Last Post: 21st May 2007, 02:52
