My DVD player doesn't play SVCDs. Since it seems the movement from VCD to SVCD is underway, is it possible for me to download SVCD Mpegs and convert them to VCD mpegs with TMPGenc or something?
In the past I have used DVD 2 AVI to frameserve them to TMPG as you would a DVD rip.
Also, if you have an Mpeg 2 codec installed (see TOOLS area) there should be no reason you couldn't straight encode it in TMPG, but Framserving via a Project file worked well.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
try a search for "SVCD with VCD header" --this is a workaround that might allow you to watch SVCD's on your non SVCD capable player
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
VCD o SVCD with extra data (installers)
By pmaril in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th May 2008, 18:17 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
