lo ppl,
bought a few days ago a philips dvd 762.
i have plenty of films on vcd/svcd which should run on the player.
Just half of them run without problems. The other half is taken by the player, it recognizes correctly vcd / svcd but when u press play, i can just see a screen like u see it when u switch to a pay-tv channel in tv without having a decoder. I can hear the sound correct but the picture is totally fekked. (Looks a bit like if u wouldnt have the frequency right adjusted in the TV. u hear sound but just silly pics.)
These CD´s work properly in the PC and on the stand alone player at a friend of mine. Some films, which have more then one CD, just one CD runs, the other not. But they are burned same way, same CD type.
Somebody an idea ??
thx,
lev
well, meanwhile found the problem.....and maybe in the future some may consider the same problem so here is the solution i found.
i use a Loewe tv, capable of both pal/ntsc. it was adjusted to PAL, like the player also. Ripped films have also been in PAL.
So dont ask me the fekk why, but putting player/tv both to ntsc worked. all cds run now.
greetz
lev
Just can't get stabilization work properly.
By Jim Halpert in forum Newbie / General discussionsReplies: 9Last Post: 24th Nov 2009, 12:58 -
Can't get DGIndex to work properly
By iTayb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 38Last Post: 22nd Aug 2009, 22:38 -
Restored videos dont work!
By BVG in forum Video Streaming DownloadingReplies: 5Last Post: 7th Jan 2009, 20:50 -
DVD menus and RTMs dont work right
By shashgo in forum Authoring (DVD)Replies: 0Last Post: 20th Dec 2008, 13:54 -
Last 20-15minutes dont play Properly!
By Ace-Of-Spades in forum Authoring (DVD)Replies: 7Last Post: 5th Nov 2007, 12:22
