Is it possible to uses a Text *.sub file in win submux to make a CVD for a SVCD disc?
How can it be done?
What kind of subtitles dos win submus suport?
Tanks in advance for the answer to this questions.
This is a copy&paste from winsubmux's read.me:
The file format is similar to "PHILIPS SVCD DESIGNER 1.5 - 2.0 SUBTITLES FILE"
file format but it must contain ONLY the '[LIST]' section without the '[LIST]'
section identifier. Eg.:
ENG_000001.bmp 01:45:10:11 01:45:14:15 296 068 211 464
or
ENG_000001.bmp 01:45:10:11 01:45:14:15 296 068 211 464 0 255 255 255
where the columns are:
IMAGEFILE STARTTIME ENDTIME WIDTH HEIGHT X Y T0 T1 T2 T3
IMAGEFILE: filename of the subtitle picture without path
(the pictures and the script file MUST BE in the same directory!)
STARTTIME, ENDTTIME: Hour:Minute:Second:Hundredthsecond
WIDTH, HEIGHT: width, height of the bitmap
X,Y: X,Y position (on the movie) of the lower upper corner of the subtitle image
T0, T1, T2, T3: is the contrast (or transparency) value of the #0, #1, #2, #3 colors
0 means fully transparent
255 means fully non transparent
BE CAREFUL don't make subtitles with zero or negative duration they will be skipped.
(eg: SubRip 0.97b puts '00:00:00,00' time to the last subtitle ENDTIME)
so, I think it will not accept text files but saved .bmp-s from Subrip with its .sub file. -
Do you Know of any way to make this text *.sub files converted to Bmp *.sub files?Originally Posted by bwalti
Tanks for reply. -
There is a way, using I-Author's OGT Creator included in I-Author Deluxe, but you will be able to make only the .BMPs. Remember thats an idea, never tried it. Also, you can import text files, and manualy add the timing codes. Send me PM if you can't find I-Author.
I Will try to find this I-Author.Originally Posted by bwalti
So another question. How can i insert the permanent subtitles whit virtual dub without lossing picture quality.
Everytime e put the permanent subtitles to a DIVX avi de outpup quality video drops.
you can use maestrosbt also to render the bitmaps
download it and read the included textfile for more info
www.vcdhelp.com/tools.htm#other -
Tanks for the tip?
So if i conver my text *.sub to text *.ssa, maestroSBT can make me a bmp *.sub. Correct?
AVI to DVD with selectable subtitles
By egooxenos in forum ffmpegX general discussionReplies: 9Last Post: 5th Dec 2009, 03:04 -
AVI with selectable subtitles?
By davroglor in forum DVD RippingReplies: 1Last Post: 14th Jan 2009, 12:27 -
Adding a menu and selectable subtitles
By HAR in forum MacReplies: 0Last Post: 15th Sep 2008, 06:25 -
By macuser1960 in forum ffmpegX general discussionReplies: 8Last Post: 6th Feb 2008, 22:10 -
DVD selectable subtitles
By exekutive in forum ffmpegX general discussionReplies: 6Last Post: 24th Sep 2007, 13:36
