I'm using TMPG 2.53 plus and normally when using 2pass the average bitrate it gives is quite close to the setting made.
Recently I made some DVD rips using DVD2AVI and its VFAPI-interface.
(MPEG2, SVCD-standart)
The results are strange: 1600kbit gives exactly 1600, 1550 gives 1500, 1500 gives 1400, and so on. More curious, one movie doesn't show this, two others show this behaviour.
Is there anybody else who sees this effect? It never showed up in AVI->MPEG conversions.
How exact are your kbit-results??
Sorry, this is a little off topic.
Is Tmpgenc Plus any faster than the free version? I'm thinking about purchasing a copy, if so. -
No, it's not faster, the only noticeable but quite important difference is a distinct new 2pass-encoding (with the above mentioned errors at least on my system)
Sorry, WarpEnterprises, but you are wrong.
Tmpgenc 2.54 IS faster than its predecessors, and ONLY in 2-pass VBR, due to the fact that it now has the option to set a hard-disk caching method for multipass encoding.
This shortens encoding times ONLY in 2-pass VBR from 20% to 40% and more.
Just try and have a look at this improvement.
Cheers
Ninja.rogue -
@ninja.rogue: You're right and I'm too - I was talking about 2.53plus.
But what about my observed bitrates??
winff not following target bitrate
By xero273 in forum Video ConversionReplies: 0Last Post: 28th Dec 2011, 22:23 -
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Xvid Setting: 1pass Quantizer vs Bitrate Mode, vs 2pass => Quality
By carlaron in forum Video ConversionReplies: 12Last Post: 4th Oct 2010, 08:12 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54 -
Divx 6.8: bitrate vs target quantizer?
By peggypwr1 in forum Video ConversionReplies: 1Last Post: 5th Feb 2008, 22:35
