So here's a question for the experts out there:
I'm encoding some SVCDs at near the max bitrate (2400) but I'm still seeing significant artifacting during high motion scenes.
Is there any way to reduce this? Would 2 pass variable bit rate make any difference at all if I'm using the max bitrate for the whole disc?
Thanks!
If your using TMPGenc then you can click on settings, go to the quantize matrix tab, and enable the 'soften block noise' option. This should make the artifacts less visable.
You dont say what encoding you are using. If using CBR, try CQ which is a single pass VBR style. If this isnt good enough 2pass VBR should help even more. And yes, as mikewalker84, 'soften block noise' will make the aretfacts less visible but costs in terms of overall picture quality. Try the different options on a short test clip (with lots of motion) and see which you prefer.
s-video artifacts?
By VCRcomp in forum Capturing and VCRReplies: 235Last Post: 29th Oct 2013, 11:42 -
Removing artifacts
By IsAB in forum EditingReplies: 6Last Post: 15th Feb 2011, 03:24 -
Removing artifacts
By IsAB in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2011, 10:51 -
Looking for artifacts
By Caple in forum RestorationReplies: 18Last Post: 1st Oct 2010, 21:27 -
Artifacts in Video
By arturjose in forum Video ConversionReplies: 6Last Post: 17th Feb 2008, 20:03
