I have a ATI ALL IN WONDER 128pro 16MB
I'm trying to use the guides for capturing with the ati cards and one of them says to change this that and the other thing. So I decided to try it anyways without changing anything and the picture got all scrambled which I know is macrovision I tried the mac hack with no luck.
So then I tried to capture with virtual dub and when I went to click on capture avi I got this message: No capture drivers.
Now I have a few questions
1.Has anyone got this card to be mac free?
2.Could my problem with athe ati software just be that I don't have capture drivers?
3. I looked in the tools section for capture drivers for virtual dub and didn't find any am I not seeing them or can someone tell me where to get them?
4. Is virtual dub mac free?
Any help would be greatly appreciated?
Thanks in advance
VCD4ME
Results 1 to 10 of 10
We were all NEWBIES once and the only stupid question is the one that's not asked?
tip: don't use the ati software, use showshifter. it has a generic wdm capture driver, which will work fine. don't know about macrovision, but what are you capping from?
I want to capture tv and vhs tapes mostly.
Are there any capture drivers for virtual dub?or
have you not used vdub?
showshifter isn't freeware though.
THANKS
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked? -
Do a search of this forum or the Rage3d.com forum for 'ATI wrapper' that will get you the capture driver that you need. Then I highly recommend getting ahold of AVI_IO AND Virtualdub....I prefer AVI_IO for capturing because it is simpler and holds your settings but Virtualdub is indispensable for manipulation of your captures.....all are quick downloads...you should be happily capturing within the hour. As for the ATI software...if you can watch TV well and capture with AVI_IO don't bother with Showshifter (it is a nice program though) If you have TV issues then by all means try it.
macros -
Why don't I alraady have a capture driver with the ati already.I used the set up disc. Also will the capture drivers work for both the AVI_IO AND Virtualdub programs
Tanks in advance
basically there's two different ways windows can talk to your capture card, as a VFW device, or a WDM device. the drivers supplied by ATI are WDM, which are incompatible with VFW programs like virtual dub. if you can get the wrapper to work, then yes vdub has tons of options, however it doesnt have a TV tuner module, so youll have to go into your ati software, select the tv channel you want then go back into virtual dub.
Thanks flaninacupboard
where can I get these vfw wraper for virtual dub?
I also read on another post that it is better to capyture in avi then convert to mpg is this true?
Thanks in advance
Yes, it is better to capture in .avi form and THEN convert to MPEG...in fact, if you want to capture directly to MPEG then you really have to use the ATI software (I think Showshifter can do this too...) but it order to get good results you have to make a very nonstandard disc. The best, IMHO, is to capture with AVI_IO (after you have the wrapper and installed it) using the MJEG codec at a quality setting of 18. I have tried Huffy and using and even higher quality setting in MJEG and find that it is a victim of the law of diminishing returns. When capturing in AVI_IO or VD you DON'T have to turn on your TV tuner software first...just select 'source' in the program (either AVI_IO or VD) and then hit the TV Tuner button and select whatever channel you want. If you have anymore questions just let me know.
Macros746 -
THANKS MACRO746
I hope you don't mind if I pm you.
Alsothanks for the post in my other thread
Thanks aagain
Capturing to AVI, what are my best options?
By jubbely2 in forum Capturing and VCRReplies: 6Last Post: 23rd Jun 2011, 05:51 -
question about adding prohibited user options (prevent pgc jumping)
By mazinz in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2010, 13:03 -
ATI Catalyst MC - Custom Profile options?
By justin81 in forum Capturing and VCRReplies: 0Last Post: 11th Jul 2009, 11:30 -
JVC GR-D850u first time user -- transfer to PC
By mister in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th May 2009, 11:33 -
Author to Control User DVD Options?
By yukon33 in forum Authoring (DVD)Replies: 0Last Post: 26th Nov 2008, 09:28
