i've converted several mpg's to vcd format using the panasonic encoder and they work fine on the computer for audio sync but after i burn them to cd and try them in a dvd player the audio seems to slowly outta sync, by the end of the vcd , its upto 2 secs outta sync. I would like them to be in sync on both the comp and the dvd player is their a way? these are converted mpgs to pal/vcd since they have 25 fps in case that helps and the audio is 44100.
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
audio sync issues after converting mkv to iso and burning to bd-r/dl disc..
By landocass in forum Newbie / General discussionsReplies: 1Last Post: 26th Jul 2010, 15:03 -
out of sync after burning
By agent222 in forum Authoring (DVD)Replies: 18Last Post: 10th Apr 2010, 11:58 -
audio sync prob AFTER burning !
By bluraid in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 05:28
