I'm working on restoration of Star Trek: Voyager, and as anyone who's worked on it knows, it's replete with rainbows and dot crawl. Last week I discovered the ASTDRmc AVS script, and it seems to work pretty much perfectly to reduce or eliminate rainbows without any noticeable artifacts. Now to address the dot crawl.
I've tried all the solutions I can find but nothing seems to be able to have much effect without also wiping out the rest of the image. ASTDRmc seems to do an excellent job of masking, both for edges and motion. But it only works with the UV chroma planes. I've looked through it and understand very little of what's happening in it, though I am doing a lot of searching and reading to try to learn.
Does anyone know if this script could be modified to work with the Y luma plane instead to try and address all the rampant dot crawl?
https://raw.githubusercontent.com/realfinder/AVS-Stuff/master/avs%202.5%20and%20up/ASTDR.avsi
https://vimeo.com/861803879
DDcomb() is an excellent technique for this type of dotcrawl. I like to mask it with an edge mask so that only the affected areas are hit by it. Just a preference.
https://forum.doom9.org/showthread.php?p=1673472#post1673472
And then there's TComb()
http://avisynth.nl/index.php/TComb -
Help with possible Dot crawl & rainbowing during capture
By HansensUniverse in forum Newbie / General discussionsReplies: 19Last Post: 11th Feb 2022, 02:19 -
Quick Dot Crawl /Antialiasing Avisynth Question
By Vaengence in forum Video ConversionReplies: 6Last Post: 15th Dec 2021, 21:26 -
more Dot Crawl removal help-laserdisc capture
By clashradio in forum Video ConversionReplies: 2Last Post: 27th Apr 2021, 21:30 -
Reducing severe dot crawl?
By GlitchBob in forum Video ConversionReplies: 6Last Post: 19th Apr 2021, 22:35 -
Best way to remove dot crawl and rainbow?
By embis2003 in forum RestorationReplies: 13Last Post: 27th Mar 2020, 11:12
