Hi
please be patient: I'm a cat
I wonder if is there a way, commandline, windows 64bit, possibly via ffmpeg or another commandline-batch encoder
to do a standard PAFF encoding of mp4/h264 files
and the audio part AAC
In this case I need to avoid MBAFF encoding
thanks
You can do it with an adobe media encoder jsx script, but the h264 encoding quality is low too
Seem there is x264 with PAFF support https://github.com/kierank/x264-paff - not sure if it works...
(VERY) wrong bitrate when encoding H264
By sharoni in forum Video ConversionReplies: 6Last Post: 19th Aug 2022, 23:37 -
Problem with FFmpeg while converting interlaced videos using MBAFF
By FFtvuser in forum Video ConversionReplies: 5Last Post: 19th Jan 2022, 05:45 -
Problem re-encoding MBAFF
By mugz8391 in forum Video ConversionReplies: 9Last Post: 26th Mar 2021, 21:29 -
Fixing unmarked interlaced frames in h264 stream without re-encoding
By hedgehog90 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jan 2021, 13:54 -
Re-encoding h264 Without Colour Blocks ?
By blewyn in forum Video ConversionReplies: 7Last Post: 26th Nov 2020, 07:39
