My dvd recorder are formatting my brand new Philips dvd-rw again and again in a loop when I put them in the dvd recorder for transfer videos from my 8mm tapes to the DVDs and my DVD recorder donīt let me to use them for it. My LG DR4800 is a early 2000s dvd recorder that support DVD-R and RW with a firewire port.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
I tried formatting it in my computer and in my recorder that format the DVD automatic when I put it in the recorder and is still in the loop. I will try putting archives from the PC to the DVD to see if is good and I will try to put them in the DVD and unplug the recorder while is doing the format.
I tried formatting the disk in the DVD recorder, it was in the loop obviusly, then I unplug the DVD recorder from the wall and plug them again and now it says is a unknown disk even if is a -RW and my recorder support -RW...
Edit: The thing of "unknown disk" happen when I used the DVD in the computer, another DVD that I never touched and I didnīt used it in a computer before it stay in the "format disk" loop even if I unplug from the wall the recorder or not.
All of this happening with Philips DVD-RW. I have some old Verbatim DVD-R and it works perfectly fine without any problem...Last edited by Joscraft_05; 6th Sep 2023 at 17:42.
be sure the recording mode will FIT on the disk. Also be sure the BRAND is supported by the original spec.
Sounds like your philips disc are hooped and your recorder just can't format it and keeps trying.
The endless quest for ac3/dts bistream capture from HDMI
By bani6809 in forum Capturing and VCRReplies: 1Last Post: 21st Feb 2022, 15:21 -
I fixed my Philips DVDR 3455H dvd/hdd recorder
By dphirschler in forum DVD & Blu-ray RecordersReplies: 72Last Post: 21st Apr 2021, 16:05 -
Panasonic DMR - EH59 DVD Recorder won't format double layer blank DVD's
By pelk12 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2019, 10:01 -
DVD disks play only B&W!
By alih786 in forum DVD & Blu-ray PlayersReplies: 29Last Post: 5th Jul 2019, 21:57 -
Macrovision VHS to DVD recorder + RF problems with Panasonic recorder
By guy24s in forum DVD & Blu-ray RecordersReplies: 16Last Post: 29th Oct 2018, 05:43
