Hello, I have a set of 7 srt files which are all the subtitle languages of a video.
Is there any software that allows comparison between more than 2 subtitle files, like Subtitle Workshop does but with 5-6 srt files at the same time?
Thank you
I know of NO true subs software that does more than 2 in a compare. However, since that app can do 2, and it is open source, you could build a custom version of it that compares simultaneously more streams.
Or, if building custom apps is not your thing, but you only need some basic differencing tools, iirc, WinMerge or Notepad++ should be able to do more than 2 (haven't tried, just a guess).
How do I compare two audio spectrum?
By maudit in forum AudioReplies: 3Last Post: 21st Jun 2023, 13:28 -
Subtitle Edit - compare subs
By maudit in forum SubtitleReplies: 0Last Post: 3rd Apr 2022, 05:13 -
How to compare 2 videos
By UserName351 in forum Video ConversionReplies: 16Last Post: 13th Dec 2021, 09:49 -
How do I compare and sync two srt subtitles?
By wiznbone in forum SubtitleReplies: 5Last Post: 19th Feb 2020, 06:05 -
Compare two videos
By ziggy1971 in forum Video ConversionReplies: 1Last Post: 23rd Sep 2018, 18:17
