Results 1 to 1 of 1
  1. I just discovered that I downloaded Potplayer from the wrong website. I went to https://daumpotplayer.com/ instead of going to https://potplayer.daum.net/
    I downloaded this version https://daumpotplayer.com/wp-content/uploads/2023/04/PotPlayerSetup64.exe and this is the about info https://i.imgur.com/O791OFG.png. I am using the 64 bit version 230707. https://www.videohelp.com/download/PotPlayerSetup64-230707.exe is the download link for 64 bit version 230707 from the videohelp website. https://i.imgur.com/6WfcFK3.png is the comparison of both setup files. It looks like both are for 64 bit version 230707 but mine is a bit older than the other one. Why is that?
    Is my pc clean? The setup file that I used is clean and there are no viruses. https://www.virustotal.com/gui/file/235567ac43dcdfb35bddf221fe7bd4a4c6c8c22b49700ead7ccd35b8ddd9d761 says that my setup file is clean. I installed Potplayer a few weeks ago. The setup file contained no adware and Potplayer is working perfectly and there are no issues on my computer. Today I discovered that I downloaded Potplayer from the wrong website and I am upset and worried.
    Also what exactly is https://daumpotplayer.com/? I couldn't find anything on it. All I found was https://www.reddit.com/r/software/comments/fel2re/is_potplayer_safe_to_use_now/ and dtalee said that it's a fake website and he said that Potplayer is not safe because the setup file has adware. That is an old post and back then the setup file had adware. It doesn't have adware anymore.
