Results 1 to 9 of 9
    Aug 2018
    Wrocław
    I ripped a protected WinX DVD Ripper to an mpg file.
    This file (subtitles) plays fine in MPC-HC, MPC-BE and VLC.
    When converting to MP4, the subtitle stream was invisible, but I managed this way:
    ffmpeg.exe -analyzeduration 2147483647 -probesize 2147483647 -i source.mpg -map 0:v -map 0:a? -map 0:s? -c:s copy "out.mp4"
    However, in the mp4 file, only the subtitles placed in the upper part of the screen will appear or not at all (MPC-HC, depending on the renderer), while in VLC they are strongly shifted in time (as if the subtitle track was shifted from the starting point to the beginning of the file).
    If I save to a mkv file, VLC displays everything correctly, and in MPC-HC without changes (only the subtitles placed in the upper part).
    How do I cure it and compress it to MP4 properly?
  2. Post a mediainfo report (text mode) from your ripped mpg file here.
    Your commandline should be:
    ffmpeg.exe -i source.mpg -map 0 -dn -c copy "out.mp4"
    Aug 2018
    Wrocław
    Video: MPEG2 Video 720x576 (4:3) 25fps [V: mpeg2 main, yuv420p, 720x576]
    Audio: Dolby AC3 48000Hz stereo 192kbps [A: ac3, 48000 Hz, stereo, 192 kb/s]
    Subtitle: VobSub [S: vobsub]
    Subtitle: UTF-8 [S: No subtitles]
    General
    Complete name : C:\_na pena\_klienta134\DVD\3711523763_Title1.mpg
    Format : MPEG-PS
    File size : 3.77 GiB
    Duration : 1 h 40 min
    Overall bit rate : 5 368 kb/s
    Frame rate : 25.000 FPS
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings : CustomMatrix / BVOP
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=12
    Format settings, picture structure : Frame
    Bit rate mode : Variable
    Bit rate : 5 069 kb/s
    Maximum bit rate : 9 600 kb/s
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 4:3
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.489
    Time code of first frame : 09:59:59:00
    Time code source : Group of pictures header
    GOP, Open/Closed : Open
    GOP, Open/Closed of first frame : Closed
    Stream size : 3.56 GiB (94%)
    Audio
    ID : 189 (0xBD)-128 (0x80)
    Format : AC-3
    Format/Info : Audio Coding 3
    Commercial name : Dolby Digital
    Muxing mode : DVD-Video
    Bit rate mode : Constant
    Bit rate : 192 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 31.250 FPS (1536 SPF)
    Stream size : 138 MiB (4%)
    Service kind : Complete Main
    Menu
    Format : DVD-Video
    Aug 2018
    Wrocław
    But when "Full parsing" is checked, the subtitle stream appears.
    Text
    ID : 189 (0xBD)-32 (0x20)
    Format : RLE
    Format/Info : Run-length encoding
    Duration : 1 h 37 min
    Delay relative to video : 16 s 760 ms
    Menu
    Format : DVD-Video
  5. Try to remux you mpg to mp4 with my commandline above.
    Aug 2018
    Wrocław
    And during the conversion I get:
    Stream #0:1: Audio: ac3 (ac-3 / 0x332D6361), 48000 Hz, stereo, fltp, 192 kb/s
    Stream #0:2: Subtitle: dvd_subtitle (mp4s / 0x7334706D)
    [in#0/mpeg @ 00000231f31efd00] New subtitle stream with index 3 at pos:10450958 and DTS:17.0473s
    Aug 2018
    Wrocław
    No effect.
  8. Rerip the movie with makemkv, then remux to mp4.
    Aug 2018
    Wrocław
    I use VobSub Ripper to rip the subtitles, muxed them and they started working fine.
