  1. Hi,
    pleaes be patient: I'm a cat
    I'm referring to this mxf:
    https://www.swisstransfer.com/d/1c47ca5b-265c-467e-9e32-aa3db3a1c21f
    or this:
    https://www.swisstransfer.com/d/ac58b60f-3e99-4b9d-b64e-d8f874234034
    if possible, I need to see something like VU meters audio levels to check if the peak levels of audio CH1 and CH2 (that contain the mix of the audio CH3 and CH4) is -12Db.
    Or howevere to see the levels
    is there a way to have an audio levels VU meter - thanks
  2. thanks but is VLC, is there a way to see audio levels overlayed to video?
  3. Don't most good video editors have a sound level display?
    Extraordinary claims require extraordinary evidence -Carl Sagan
  4. Member Cornucopia's Avatar
    @Treetops, but that requires using a good editor, which, knowing the OP's history, is anathema.
  5. Originally Posted by marcorocchini View Post
    Use avisynth under VLC? You can overlay 'ebur128' and eventually 'showvolume' on top of your video in ffmpeg.
  6. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    In AviSynth, Histogram("audiolevels")
