If you saying there is semantic difference between
and
I am not going to argue
In any case, all this time I have been in agreement with you that QTGMC adds more functionality to the modules that it uses, and as such it cannot be compared to these modules taken separately. This is the topic of the thread.
Results 31 to 33 of 33
Why not compare ? What is the rationale ?
Yadifmod/ yadifmod2 with edeint interpolation using nnedi3 essentially uses yadif with nnedi3, why can you not compare the outputs of yadif, nnedi3 separately ? Same with bwdif plus edeint=whatever. or TDeint plus edieint=whatever. They all use the base model with alternate interpolation algorithm
Sometimes doing too much - adding other processes - "filteritis"- or overprocessing makes the quality worse. QTGMC is guilty of that in some cases - there can be problems such as smoothing out details, introducing temporal artifact errors and ghosting artifacts, wobbly mvtools2 temporal inconsistencies. In some cases it might be better by some criteria, but in others it's clearly worse . It's situation and source dependent. There are well know textbook QTGMC "fail" situations, and others where BWDif excels
Whatever you want to define "quality" as - it's important to evaluate and compare the output between whatever filter(s) /processes that you apply . In some cases , using an individual "module" might be better (there are clear cases of this, I can post examples) - but you'd never know that if you closed your eyes and never took the time to investigate. You would never know when to use one over another. Or what situations one is ideal for, or terrible for. You would never know the cost/benefit tradeoffs , the pros/cons etc... -
I should have stopped at "QTGMC adds more functionality to the modules that it uses"
@poisondeathray, point taken, and I stand corrected. It is not a black box with other boxes inside, but a cocktail. What is better: whiskey, Red Bull, or whiskey with Red Bull? It depends. I am going to pour myself some Irish coffee.
To add some meat to the message, I can say that as I am script-averse, I use VDub Yadif plugin for HD (fast and looks good enough) and VDub MSU Deinterlacer plugin for SD (slightly better than Yadif, but an order of magnitude slower), and I use Temporal Smoother separately. Maybe I should try using lollo's settings for QTGMC (they seem to be simple enough) and compare.
Is there a comprehensive How-To about QTGMC settings for different content types?
You don't need a TBC in 2023
By Marshalleq in forum Capturing and VCRReplies: 138Last Post: 12th May 2025, 02:06 -
Capturing in 2023, a few questions
By Snacky2Wacky in forum Capturing and VCRReplies: 16Last Post: 2nd Sep 2023, 15:49 -
PhotoToFilm - 3.9.8 ( Released 2023-04-02 )
By Kyle_Katarn in forum Newbie / General discussionsReplies: 0Last Post: 2nd Apr 2023, 09:51 -
Bob deinterlacing in AviSynth without doubling the frame-rate?
By orion44 in forum Video ConversionReplies: 11Last Post: 6th Dec 2021, 01:44 -
Different audio sampling rate in single capture file
By Subhash in forum Capturing and VCRReplies: 4Last Post: 14th Feb 2019, 08:47
