Please go to https://cyberraidentech.blogspot.com/2020/09/potplayer-best-settings.html.
In 8. Use GPUs Video decoder to decode video files it says to enable dxva under hardware acceleration. If I enable it then potplayer uses my nvidia gtx 1080 graphics card and if I disable it then potplayer uses my intel uhd 630 graphics card.
I want to ask does potplayer using the nvidia graphics card improve the video quality or it doesn't matter and I get the same quality as potplayer using the intel graphics card?
Also will potplayer behave if I enable hardware acceleration? Some programs like Google Chrome can misbehave if they use hardware acceleration and they can freeze or crash.
Hardware acceleration has nothing to do with video quality, only with decoding/encoding speed.
720p Option Missing in the Quality Settings in Potplayer How do i fix?
By ayzick in forum Software PlayingReplies: 0Last Post: 30th Apr 2023, 13:24 -
How can I improve image quality of PotPlayer vs. WMP?
By DSperber in forum Software PlayingReplies: 27Last Post: 28th Jul 2022, 13:45 -
Potplayer - Bookmark Editor Questions
By Jack66 in forum Software PlayingReplies: 0Last Post: 23rd Jun 2021, 11:23 -
MadVR, MPC-HC, PotPlayer questions
By holycow in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2020, 22:14 -
Video Lags at Fullscreen on Potplayer When Switching Video Render.
By YellowDragon in forum Newbie / General discussionsReplies: 33Last Post: 4th Jan 2019, 18:13
