I've been using my ES15 as a passthrough for my Betamax for it's "TBC-ish" qualities, and have been using the S-Video OUT from my ES15 to my capture device. Am I getting the benefits of luma/chroma separation by doing this? I read somewhere that s-video doesn't need to be a part of every machine, but just needs to be part of the chain. Is this accurate?
Results 1 to 11 of 11
Not quite exactly, The reason of having Y-C at the machine level is to avoid the composite output all together, So you are missing on that, what you are getting with the ES15 is a better comb filter for your composite signal if the one in your capture card is not that good, plus you are getting some sort of video stabilization at the line level and probably some DNR. Though, I'm not familiar with DVD recorders.
I don't think he has S-Video out from the Beta, otherwise he wouldn't be using composite. Also component is not better, it's a different analog processing scheme that the DVD recorder has to perform, I don't own one to speak of but I don't see why it would better than S-Video or HDMI 480i for that matters if equipped?
If the Betamax has only composite output "in the chain", would that not be the "weakest link" ? outputing s-video from ES15 to capture has still any good use for quality ?
btw. companda doesn't mention the composite output from the Betamax..
"I don't think he has S-Video out from the Beta, otherwise he wouldn't be using composite" > what's the logic of that ?Last edited by Eric-jan; 2nd Sep 2023 at 23:42.
The logic is in the exact statement I made.
S-Video from composite is pretty straight forward, you can literally achieve it using one capacitor, but a better active comb filter is way better, Component not so much, it has to be processed and converted from Y-C to Y-Cb-Cr and this process is much more involved than getting Y-C from composite, which essentially a composed Y-C or composite. -
S-Video on Beta machines are very rare. Only the SL-HF2100 and ED-Beta series have it. Not sure about industrial machines, but other than the EDW-30, which is the EDV-9500 without the tuner and timer, I don't believe any non-BetaSP, et. al. machines have S-Video because it came so late in the life of Beta.
His Beta has most probably composite output. Composite video shares the same wire for luma and chroma in overlapping frequency bands using the frequency-interleaving principle. For decoding the luma has to be separated from the chroma by filtering. Some capture devices do have poor separating filters. With poor filtering there will be residual luma/chroma crosstalk, producing the typical dotcrawl and rainbows artefacts. The Comb Filter of the ES15 (in passthrough) provides a high quality (3D) Comb Filter which delivers a clean Y/C signal at its S-video output. So the configuration is: Player composite video OUT -> ES15 composite video IN -> ES15 S-video OUT -> Capture device S-Video IN.
In addition, the ES15 in passthrough eliminates the horizontal wiggling and flagging which is often seen in absence of any TBC(-ish) functionality.
How effectivley the Comb filter works for separating luma and chroma may also depend how the tape player converts the color-under format of VHS and Betamax to the CVBS (composite) signal at its output.Last edited by Sharc; 4th Sep 2023 at 02:53.
Capturing video from Betamax to laptop
By techmot in forum CapturingReplies: 10Last Post: 27th May 2022, 19:15 -
Snapshots with and without DMR-ES15 in setup
By brockway in forum CapturingReplies: 6Last Post: 10th Nov 2021, 10:16 -
Lossless AC3 channel separation/split tool
By yukichigai in forum AudioReplies: 3Last Post: 22nd Sep 2020, 01:13 -
DMR-ES15 or TBC 1000
By Beyonder123 in forum CapturingReplies: 2Last Post: 24th Apr 2020, 03:25 -
Questions about TBCs, Panasonic ES15, ezcap, etc.
By Gameshow Host in forum CapturingReplies: 7Last Post: 24th Feb 2019, 11:36
