    Aug 2022
    Slovakia
    I tried normalize about 1500 of my MP3 files with MediaMonkey 5 free edition. Result is not good.
    Any suggestion for software for Windows 10/11 or Ubuntu? Thanks.
    May 2005
    Australia-PAL Land
    Foobar2000 is what you want. It works really well. It can be run as a portable program if you don't want to install it.
    Workflow:
    Copy all your files into another folder as Foobar writes the replay gain info to them (I'm not so sure whether this is necessary; whether it actually affects the original file or just sets a Replay Gain flag).
    Start Foobar2000 exe
    File Open
    Select all files to be balanced>Open. A playlist will be created.
    Select all files in the playlist
    Right click> Replay gain>Scan per-file track gain
    Click Update file Tags
    Right click Replay Gain>Apply Gain to File Content
    Done.
    It will also level MP4s. Great for music videos!
    Aug 2022
    Slovakia
    Thanks.
    Is there some software, that shows visually a waves of my files, for quicks overview before - after (normalize)?
    Aug 2022
    Slovakia
    finally I used Audition, result is very good. In about an hour I normalized all ~1500 tracks, with visual control.
    Thanks to all for help.
