Hi, everyone!! I have a lot of files, mainly satellite backhaul/fronthaul feeds at 1080/25i that I'd like to convert to 1080/50i. (or for some, to 1080/59.94i, as I have 29.97i footage too) I know I can use Handbrake with Yadif and Bob to achieve that, but I don't want to deinterlace, I need my outputs to be interlaced. I've spent hours looking for a solution, tried ffmpeg for this, but the output always ends up progressive even when I explicitly had told it to interlace or to at least preserve the interlaced frames/fields. I also used ffmpeg Clever GUI, which was a lot less confusing, and created different files each time; once, the output would be progressive, the other time, it would come out interlaced and with interleaved fields, but also have severe scanline and combing artifacts all over the place that I couldn't seem to get rid of regardless of what deinterlacing filter or just media player was used.
Here's the MediaInfo log of one of the files that I'm working with:
And here's what I want my output to "look" like:HTML Code:Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : MPEG Video Format version : Version 2 Format profile : Main@High Format settings : BVOP Format settings, BVOP : Yes Format settings, Matrix : Default Format settings, GOP : M=4, N=28 Format settings, picture structure : Field Codec ID : 2 Duration : 4 min 15 s Bit rate mode : Constant Bit rate : 37.5 Mb/s Maximum bit rate : 33.1 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.724 Time code of first frame : 02:57:46:18 Time code source : Group of pictures header Stream size : 1.12 GiB (89%) Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
I need the scan order to be "Top Fields First," and the Scan Type, store method, "Separated fields." The video needs to be losslessly re-encoded either back to source MPEG2 or to H.264.HTML Code:Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : 3 Ref Frames Format settings, CABAC : No Format settings, Reference frames : 3 frames Codec ID : V_MPEG4/ISO/AVC Duration : 3 min 2 s Bit rate mode : Constant Bit rate : 31.3 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 50 FPS Original frame rate : 25 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan type, store method : Separated fields Scan order : Top Field First Bits/(Pixel*Frame) : 0.252 Stream size : 682 MiB (94%) Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
I've also "heard" that AviSynth can do this better than ffmpeg can, but am not very familiar with it. If anybody knows of the right plugin and the right script to get this done, I'd be INFINITELY grateful to you. Just PLEASE, include all the tiny little steps so I don't get confused. Thanks a lot, in advance.
Results 1 to 30 of 42
25i and 50i are two terms to describe the exact same thing, so I don't understand what you are trying to archive.
25i = 50 fields in 25 interlaced frames
50i = 50 fields in 25 interlaced frames -
Yes, the request is absolutely a non sense
With the new frames being interpolated from the existing? To what purpose?
"I've seen things you people wouldn't believe..."
Okay, so, if you're going to act like a jerk, then PLEASE keep your help to yourself. Thank you!
Thank you, but you were in fact rude. I'm sorry if I was rude, too.
I'm just talking about something I saw myself and continue to see regularly.
Here's the MediaInfo log of one example:
HTML Code:Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : 3 Ref Frames Format settings, CABAC : No Format settings, Reference frames : 3 frames Codec ID : V_MPEG4/ISO/AVC Duration : 3 min 2 s Bit rate mode : Constant Bit rate : 31.3 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 59.940 (60000/1001) FPS Original frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan type, store method : Separated fields Scan order : Top Field First Bits/(Pixel*Frame) : 0.252 Stream size : 682 MiB (94%) Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
Post the sample please
I don't have the before, and am not sure if the metadata would be preserved if I were to try cutting the video myself, so am sending a link to the file:
https://5qwt55-my.sharepoint.com/:v:/g/personal/dream66_5qwt55_onmicrosoft_com/EerRVaJ...43I8A?e=Oe3QY8
P.S. I don't do torrents from the scene or something haha, this file's from Sharemania where people post backhauls of awards shows, performances, etc. -
That video has interlaced frames and is encoded interlaced at 29.97 fps. MediaInfo shows the frame rate as variable but every frame has the same duration ~33 ms. MediaInfo also shows the frame rate as 59.95 fps -- but it is reporting the field rate, not the frame rate. This is how you can tell:
Code:Scan type, store method : Separated fields
Played back correctly you get smooth motion with 59.94 different pictures per second. It does not play correctly in my browser (Firefox). But after downloading the video and playing it with MPCHC it plays properly. -
Master jagabo already said everything. Once more, "I've seen things you people wouldn't believe..." -
Thank you very much!! That was very clear, and gave me a better understanding. Now what am interested in is how do I go on about processing/encoding the 25i and 29.97i files in my possession to be like that one, as in having a field rate that's double the frame rate? All for the video to be smoother? And WITHOUT DE-INTERLACING.
Thanks for your help, and again sorry for the misunderstanding we first had.
Since 25p (or 25p frames encoded as 25i) only have 25 different pictures per second. Simply duplicating frames to make 50p or 60p will not give you smooth motion. You have to create new frames with motion interpolation. There are various methods of doing this but they sometimes generate gross distortions. You can try FrameRateConverter(), InterFrame(), or RIFE() in AviSynth. Topaz and Vegas have such features.
After making it 60p use:
Code:AssumeTFF() SeparateFields() SelectEvery(4,0,3) Weave()
Assuming the frames are already progressive and you want to double the frame rate, a full script might look like:
Code:LWlibavVideoSource("filename.ext") InterFrame(cores=4) # defaults to double frame rate AssumeTFF() SeparateFields() SelectEvery(4,0,3) Weave()
Code:LWlibavVideoSource("filename.ext") FrameRateConverter() # defaults to double frame rate AssumeTFF() SeparateFields() SelectEvery(4,0,3) Weave()
Code:LWlibavVideoSource("filename.ext") z_ConvertFormat(pixel_type="RGBPS", colorspace_op="709:709:709:l=>rgb:709:709:f") Rife(gpu_thread=1, model=6, sc=true, sc_threshold=0.12) # defaults to double frame rate z_ConvertFormat(pixel_type="YUV420P8", colorspace_op="rgb:709:709:f=>709:709:709:l") AssumeTFF() SeparateFields() SelectEvery(4,0,3) Weave()
But why would you want interlaced video when you can just leave your video at 50p or 60p and have smooth motion with no interlace artifacts, reduced resolution, and worse encoding?
And as I mentioned before, motion interpolation like this often creates very ugly artifacts. I don't really recommend it. -
thanks, I manage to load it as 60p by ffms2, as you mentioned, then at the end actually output it as 60p :
Code:from havsfunc import QTGMC import vapoursynth as vs from vapoursynth import core clip = core.ffms2.Source("Bebe Rexha - I'm A Mess.mkv", fpsnum=60000, fpsden=1001) clip = clip.std.SeparateFields(tff=True) clip = clip.std.SelectEvery(cycle=4, offsets=[0, 3]) clip = clip.std.DoubleWeave(tff=True) clip = clip.std.SelectEvery(cycle=2, offsets=0) clip = QTGMC(clip, TFF=True) clip.set_output()
I failed to understand he has no knowledge on the matter, so your detailed explanation should convince him now. Thanks.
Converting 4k HDR to 1080 HDR
By strudo76 in forum Video ConversionReplies: 2Last Post: 31st Dec 2022, 02:24 -
Need help converting a 16.10 1080p res to 1440p res (1680 x 1080)
By Joakim in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2022, 12:35 -
Disney browser and 1080 ?
By ahmedani in forum Video Streaming DownloadingReplies: 2Last Post: 3rd Aug 2022, 08:04 -
Convert 1080/60p to 1080/30p ???
By NewTwoVideo in forum Video ConversionReplies: 19Last Post: 24th Nov 2021, 15:55 -
1080 Project Stting
By biferi in forum Newbie / General discussionsReplies: 0Last Post: 5th Jun 2021, 12:23
