Hi,
I have an old (obviously) Panasonic PV-GS150 and a bunch of old tapes that I want to get the videos off of. The camcorder has a Firewire port and have I an old laptop with a Firewire port. I connect the two together, ran WinDV, and everything worked perfectly fine.
However, a few minutes later, I tried again, and I'm stuck with the ever-popular Can't find DV output pin error. Lots of errors online but no actual solutions. I tried every combination of rebooting while the camcorder was connected or not, powered on or not, etc. I just can't get it to work any more.
I also tried ClipChamp and OBS. ClipChamp sees the camcorder but says another application is using it. OBS sees it but just shows a black screen when I add it.
Does anyone have any ideas what might be wrong and if there's anything else I can try to get this to work?
If nothing else, I do have an HDMI capture device that I guess I can use the multimedia output on the camcorder, into the HDMI converted and then into the HDMI capture device, but if I don't have to dink around with all that, I'd prefer not to.
Thanks.
Forget about OBS. Try Scenalyzer Live, it seems to be more reliable when finding a Firewire device.
You can also capture over USB if you want. -
WinDV has become increasingly finnicky as Windows has evolved. With the 150, you have a couple of options.
1. Using your Firewire port, try Scenalyzer. I've found it is more robust than WinDV and will work when WinDV doesn't. It is another DV transfer program.
2. Try the USB connection. No, I'm not going mad. You'll need a USB Mini B plug on one end and a standard A on the other. Connect your 150 to the PC and then WinDV may pick up the camera as a "video edit" device.
I have written a detailed overview of this on my website here:
http://aaproductions.net/dvtransfer.htm
Revert to a non-DV capture only as a last resort. -
Thanks for the ideas. Took a couple tries but I got Scenalyzer to work. If only it was for the giant logo that keeps flashing on the screen every few seconds. Might try the USB or HDMI version because of that.
Ah, just noticed the license was in the zip file so trying again
You can also download it from here.
Problems with WinDV
By multitech in forum Capturing and VCRReplies: 8Last Post: 12th May 2023, 19:58 -
Is WinDV the best for old laptop?
By WolfSpring in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 19th Apr 2020, 16:54 -
Sony Camcorder TRV815 Hi8 old tapes won't playback in camcorder
By Dforsythe in forum Newbie / General discussionsReplies: 11Last Post: 9th Dec 2019, 17:21 -
BD3D2MK3D not recognizing 3D from MakeMKV
By sardon68 in forum Video ConversionReplies: 1Last Post: 26th Aug 2019, 07:05 -
DVD Recorder not recognizing dvds
By JDiane in forum DVD & Blu-ray RecordersReplies: 29Last Post: 15th Apr 2019, 15:02
