Results 1 to 9 of 9
  1. Hello, rookie here,
    I manually download the .mpd file using yt-dlp, best-video.mp4, and best-audio.m4a
    Then I decrypt them using mp4decrypt
    Lastly, I join them using ffmpeg
    Is there any way to do all these things automatically?
    So that when I put the .mpd url and decryption key the remaining steps get completed automatically and produce the final output video.
    Feb 2022
    Search the forum first!
    See https://forum.videohelp.com/threads/407216-Decryption-The-Dungeon-of-Despair especially the second post for examples. A few other users here are posing scripts too. Look at them and adapt to your own needs
  3. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Originally Posted by Jelov View Post
    Hello, rookie here,
    If you insist on using yt-dlp then I'm not sure, but N_m3u8DL-RE does all that (when using the needed parameters)
  4. Originally Posted by Karoolus View Post
    Okay I'm ready to adapt to new things. Kindly tell me the procedure I will try that out.
  5. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    https://github.com/nilaoda/N_m3u8DL-RE
  6. Originally Posted by Karoolus View Post
    Thank you so much brother N_m3u8DL-RE has saved me a lot of effort. Really appreciate
    Dec 2021
    Scotland
    I did compose this python script yonks ago. It's fairly generic: but it automatically does what you do. You run it. It asks for mpd. It'll download bestvideo & bestaudio using yt-dlp (of course, it does not select if best audio has AD, etc.), it'll ask for KEY#. Then it decrypts. It asks what name do you want to give file (yes, you can include spaces). then it'll place the decrypted file in a folder called Completed within the same folder that your python file resides:
    ####version (20230205-1)  do checks for dupe filename and illegal characters
    ####version (20230129-1)  replace aria2c with -N 6
    ####version (20221117-1)
    #### remove y/n option to remove crap (it auto removes it now)
    #### use shutil for moving crap to ./Throwaway and for removing ./Throwaway and its contents
    #### allow you to call final file name to include spaces
    #### at the end, it will now delete the Throwaway folder
    import os
    import shutil
    import glob
    ##########useful when used within VS Code to tell it which directory you're in
    abspath = os.path.abspath(__file__)
    dname = os.path.dirname(abspath)
    os.chdir(dname)
    def cls():
        # posix is os name for Linux or mac
        if(os.name == 'posix'):
            os.system('clear')  # clear is the bash command
        # else screen will be cleared for windows (os name is actually nt for Windows)
        else:
            os.system('cls')  # cls is the batch command
    def filename():
        output_name = input("What do you want to call your final file? (do not include file .extension like .mp4) ")
        output_name = f"{output_name}.mp4"
        path = f"./Completed/{output_name}"
        # look to see if duplicate filename
        if os.path.isfile(path):
            print(f"\nyou already have a file called {output_name}. Choose another name\n")
            return filename()
        #look to see if any illegal characters in filename
        illegals = "@$%\/:*?\"<>|~`#^+=\{\};!"
        any_illegals = (set(output_name) & set(illegals))
        if not any_illegals:
            return output_name
        else:
            list_illegals = ' '.join(any_illegals)
            print(f"\nyou have included the following which are not legal characters:       {list_illegals}\n")
            return filename()
    os.system('cls')
    print("\n\n")
    mpd_url = input("what is mpd URL? ")
    os.system(f'yt-dlp --allow-u -f bestvideo -N 6 "{mpd_url}" -o encryptVid.mp4')
    os.system(f'yt-dlp --allow-u -f bestaudio -N 6 "{mpd_url}" -o encryptAud.m4a')
    key = input("\n\nwhat is the KEY? ")
    print("==============================\n\n Decrypting\n\n==============================")
    os.system(f"mp4decrypt --show-progress --key 1:{key} encryptVid.mp4 video_decrypt.mp4")
    os.system(f"mp4decrypt --show-progress --key 1:{key} encryptAud.m4a audio_decrypt.m4a")
    if not os.path.exists("Throwaway"):
       os.makedirs("Throwaway")
    if not os.path.exists("Completed"):
       os.makedirs("Completed")
    print("\n\n\n\n")
    output_name = filename()
    os.system(f"ffmpeg -i video_decrypt.mp4  -i audio_decrypt.m4a -c:v copy -c:a copy mux_file.mp4")
    os.rename("mux_file.mp4", f'{output_name}')
    shutil.move(f'{output_name}', "./Completed")
    for data in glob.glob("*_decrypt*.*"):
            shutil.move(data,"./Throwaway")
    for data in glob.glob("encrypt*.*"):
    shutil.rmtree("./Throwaway")
    print(f"All done.\n\n Your final file '{output_name}' is in 'Completed' folder")
  8. Originally Posted by deccavox View Post
    import os
    import shutil
    import glob
    os.chdir(dname)
    def cls():
        else:
    def filename():
            return filename()
            return output_name
        else:
            return filename()
    os.system('cls')
    print("\n\n")
    print("\n\n\n\n")
    thanks for the script
    instead of using "mp4decrypt and ffmpeg" can u switch it to "mkvmerge and shaka-packager"
  9. Originally Posted by deccavox View Post
    import os
    import shutil
    import glob
    os.chdir(dname)
    def cls():
        else:
    def filename():
            return filename()
            return output_name
        else:
            return filename()
    os.system('cls')
    print("\n\n")
    print("\n\n\n\n")
    Can u add upload to googledrive option which will use token pickle and after its uploaded it'll print the gdrive url
