Results 1 to 11 of 11
  1. I received recently a digitized Soviet colour movie, released in 1980, from a Russian film archive. Although its size is good enough -- two files of about 80 Gbytes overall for 3 hours-long movie -- the movie's aspect ratio is ordinary 720x576. Perhaps, they digitized a Betacam videotape, according to the copy's title. They also mentioned HD in the copy's title. But, 720x576 is not HD, of course.
    Did they swindle me? Or 720x576 is good for a digital copy of Betacam? If I convert the files into 16x9 aspect ratio, for instance, then the movie's visual quality won't improve? I think the movie is on 35 mm film print. But, the Russians, perhaps, gave me a mediocre copy from Betacam TV version of the movie.
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt 2016.09 (qt )
    File size : 37.6 GiB
    Duration : 1 h 24 min
    Overall bit rate : 63.7 Mb/s
    Frame rate : 25.000 FPS
    Writing library : Apple QuickTime
    Video
    Format : ProRes
    Format version : Version 0
    Format profile : 422 HQ
    Codec ID : apch
    Bit rate mode : Variable
    Bit rate : 61.4 Mb/s
    Width : 720 pixels
    Clean aperture width : 703 pixels
    Height : 576 pixels
    Clean aperture height : 576 pixels
    Display aspect ratio : 4:3
    Clean aperture display aspect ratio : 4:3
    Frame rate mode : Constant
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:2
    Scan type : Interlaced
    Scan type, store method : Interleaved fields
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 5.921
    Stream size : 36.3 GiB (96%)
    Writing library : apd0
    Matrix coefficients : BT.709
    Audio
    Format : PCM
    Format settings : Little / Signed
    Codec ID : in24
    Bit rate mode : Constant
    Bit rate : 2 304 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Bit depth : 24 bits
    Stream size : 1.36 GiB (4%)
  2. That is the usual frame size for capturing from standard definition analog video tape. It's exactly what you want.
  3. Member Cornucopia's Avatar
    Depends on the quality and availability of the original film print. If still in good quality, and still available, a 16mm or 35mm film print could go back to the source and be (re-) digitized in HD and possibly achieve a higher quality than what you currently have (which is standard SD). We don't know the intended aspect ratio of the original.
    But that's a lot of IFs...
  4. Originally Posted by Daniyar View Post
    ProRes422HQ is an exchange standard (in PAL countries). If the title says, it's a copy of a DigiBeta, why not? But obviously they "lied" with the "HD" in the title.
    Yes. It is the original PAL DigiBeta resolution.
    There is nothing to improve. You might convert to a format that can be handled by standard players, but you have to know, what is the final purpose.
  5. Originally Posted by Cornucopia View Post
    Thank you. It was one of the major Soviet movies of the 1980s. Briefly: an honest district Communist governor in the Caucasus tries to bring order and prosperity to his region.
    I think it was filmed in Kodak or Agfa, some high-quality Western film print. Because, the Soviets usually indicated their native, mediocre quality Svema or Tasma film prints at the end of movies. But, if the Soviets used Western films, they didn't advertise the foreign producers.
    The moviemakers were awarded with the Lenin Prize in 1986 -- a kind of the Best Picture Oscar. Although, there is a faint possibility that the Russian film archive lost or destroyed the movie's negative. Sometimes the Russians -- intentionally or by accident -- have lost negatives of culturally and historically important movies. But, its TV-version is DEFINITTELY intact in a Russian TV-archive, not digitized. The Russian film archive provided me with its Betacam digitized copy. Maybe, it was cheaper for the Russians to digitize Betacam than to digitize 16 mm or 35 mm negative. Anyway, this archive provides ordinary customers with 720x576 copies, even if the original is a 70 mm negative.
    I can supply you with a link, where I posted the compressed version of the movie in a youtube-like quality. The publication itself is an achievement: I am the first on Internet to post this nearly forgotten masterpiece in Russian. Its Georgian-language poor-quality version has been already posted in a Russian social network.
  6. Originally Posted by Quint View Post
    Thank you. The movie is fine on a home TV-set. But, if to play it back on bigger screens in a lecture hall or restaurant? Worth to try?
    May 2005
    PAL User
    Be careful; to convert to 16:9 you're going to have to either crop away some of the top and bottom or if you don't crop, distort it by stretching it to fit the wider screen ratio.
    As it is, even though the actual pixel ratio is 720x576, it is encoded as 4:3, meaning the effective pixel ratio (or display aspect ratio) is 768x576.
    You could post that YT link so we can assess whether it "looks right" at the current 720x576, 4:3.
  8. Yes, if the original negatives or even prints are available, digitizing those could give much better, true HD results. But that would be much more expensive than starting with an SD video tape.
  9. Originally Posted by Alwyn View Post
    This link contains the movie in a compressed form with an accompanying article in Russian.
  10. The movie is clear 4:3. If you convert it somehow to 16:9 you have to crop parts up and down and the result will be that you have even less resolution...
    A real good SD, that uses every pixel of the 720*576, can also be beamed for a smaller audience, yes. Watch yourself and decide.
    May 2005
    PAL User
    Yes, that looks like a 4:3 movie to me. The frame is exactly 4:3 (1.33:1) and the heads look correctly proportioned. I would not suggest cropping or stretching it to 16:9.
    The quality of the Mega site's MP4 looks quite good to me, so if your copy is ~38GB for the 1hr 24min, yours will be very good. Depending on the upscaling, it should also look good on a big screen, left as-is. This of course requires the player to just fill to the top and bottom and not stretch the sides out. There should be black bars down the sides (pillarboxing). A dry run in the venue to check it would be a big help.
    No doubt others will have an opinion/guidance on what to so to it to improve the quality on the big screen.
